Go Back   Team-BHP > Buckle Up > Motor-Sports > Indian Motorsport
Old 15th October 2009, 01:12   #106
pranavt's Avatar
Thanked: 274 Times
Originally Posted by v1p3r View Post
I don't understand the sarcasm. He's done a 13.3x run, and it's soon going to be a 12.xx run. That's no mean feat for an Indian 1.5. I think we should just appreciate the effort put in by the owner, tuner and team behind the car.
Absolutely.
Originally Posted by ssjr0498 View Post
First and foremost, he aint running a "D" series engine to be precise.
Of all things, pedantry?
Secondly, please dont get me wrong, but, I guess you need to upgrade your knowledge"intake" by a big big margin. I am sure you would not have commented in that fashion if you knew that a "FEW MM's" changed in ur intake system can give/take some serious amount of juice to/from your engine.
Dude, it was a joke. Regardless, thanks for the advice, I will upgrade my intake (of) knowledge. I do not know that the varying the length, diameter and shape of intake runners can move the powerband around (like increasing the diameter and reducing runner length shifts the powerband higher up and vice versa, law of diminishing returns still applicable) will make sure to study it.
Originally Posted by Ford Rocam View Post
It might look ugly pranav, but infact its a very smart move by an ace tuner. I am sure he wont be running any air filter in between, the intake is facing at front of the vehicle so when car is at speed the air is forcibly inducted in to the intake thereby increasing amount of CFM going in to engine & more power. since its a drag race, every bit of cfm is important.
At the risk of sounding like an armchair critic, (since the owner is not looking for throttle response during the drags,) don't you think a better place to have the intake would be either through the front bumper or at the top of the hood where it meets the windshield, owing to the fact that those 2 zones are at a much higher pressure than the middle of the hood? The height of that intake probably invites the high-pressure air, so it might be moot, but still.
pranavt is online now   Reply With Quote
Old 15th October 2009, 02:42   #107
furioussphinx's Avatar
Here are another three.
furioussphinx is offline   Reply With Quote
Old 15th October 2009, 03:47   #108
v1p3r's Avatar
Thanked: 27 Times
Front bumper is too far away from the intake. Velocity will drop by the time the air reaches the throttle body.
The back of the hood, where the windshield begins, is BEHIND the throttle body. The airflow will have to reverse in direction, which would pretty much negate any effect.
Here's a pic I took. This is currently my wallpaper.
Old 15th October 2009, 05:21   #109
foby.sebastian's Avatar
Thanked: 1,105 Times
Awsome snaps mate , BTW good to see a Kerala registered Merc there in Hydrabad
foby.sebastian is offline   Reply With Quote
Old 15th October 2009, 06:00   #110
bigmoose85's Avatar
They came on Sunday evening. Hung around for some time and left.
bigmoose85 is offline   Reply With Quote
Old 15th October 2009, 09:59   #111
pranavt's Avatar
Thanked: 274 Times
The fact that he is going against the wind means that the direction of air will have to reverse anyways. Secondly, and spare my ignorance about his build, but if he is still running the stock OHC manifold (his intake is leading to the centre of the hood, which is where the TB of the OHC is located) the air is probably doing amazing gymnastics just to get into the cylinder in the first place, and would negate the argument of velocity as the crap IM kills velocity more than any restrictive intake.
Does anyone have more pics of the hood?
Old 15th October 2009, 13:57   #112
fieroid's Avatar
Thanked: 287 Times
That hood projection was initially planned for a new intake system which was for Ramming in a controlled manner and the contraption would pop over the engine bay (hence the projection on the hood). However with lack of time, it was not done. Its however true that, this will cause a reverse flow since, the intake was not facing the opening given on the hood. Effectively this will run like its running without a bonet lid . What matters most is that the car improved its time and whatever said, the car was faster.
Lets just respect the concept and the attempt in the right direction. I'm sure, the next drag this car will be a killer.
fieroid is offline   Reply With Quote
Old 15th October 2009, 15:07   #113
pulsar56's Avatar
Thanked: 319 Times
Default Timings list for 4 Wheelers
Managed to compile the timings list for 4 wheelers from APMSC site for archiving here.
DQMD_4Wheelers_Timings.xls
pulsar56 is offline   Reply With Quote
Old 16th October 2009, 03:10   #114
v1p3r's Avatar
Thanked: 27 Times
The intake is not stock. First thing on the Indian Vtec is to replace the intake manifold with a D series OE or aftermarket manifold. This car runs an Edelbrock.
Old 16th October 2009, 03:46   #115
Thanked: 152 Times
Clear Case Of Substance over Style. That City looks Menacing. Really Really Menacing.
Cyrus43 is offline   Reply With Quote
Old 18th October 2009, 19:14   #116
pulsar56's Avatar
Thanked: 319 Times
More Pictures:
pulsar56 is offline   (1) Thanks Reply With Quote
Old 18th October 2009, 20:03   #117
pulsar56's Avatar
Thanked: 319 Times
Next Set:
Old 18th October 2009, 21:44   #118
pulsar56's Avatar
Thanked: 319 Times
Another Set:
Old 19th October 2009, 21:18   #119
Ravveendrra's Avatar
Thanked: 406 Times
Thanks Pulsar for the pics and the timing sheet compiled by you.
Any more pics coming?
Cheers,
Ravveendrra is offline   Reply With Quote
Old 25th October 2009, 19:05   #120
syedhafeez's Avatar
Thanked: 343 Times
Few more pics from my side.
syedhafeez is offline   Reply With Quote
Cruise in 3rd gear, or keep shifting between 3rd & 4th? syravi Technical Stuff 11 29th September 2011 10:44
Wheel War II - Kolkata Drag 3rd October. EDIT : Postponed to 31st October 2010. NOS Power Indian Motorsport 82 6th November 2010 21:33
Deccan Quartermile Drag - January 17 & 18th 2009 DKG Indian Motorsport 413 21st February 2010 15:59
Deccan Quarter Mile Drag IV -12th & 13th Dec v1p3r Indian Motorsport 126 25th January 2010 19:45
Deccan Quartermile Drag II- June 20th and 21st 2009 suren181 Indian Motorsport 161 21st September 2009 13:17
