Go Back   Team-BHP > Buckle Up > Motor-Sports > Indian Motorsport
Old 28th May 2004, 13:38   #1
Can somebody here throw some light on the official rules
in Drag racing? As per the scene in India?
I mean, say for example we have this thing called reaction
time. is reaction time added to the final ET?
In other words, when exactly does the clock start? Does it
start when the green light goes on? Or does it start only
when the front wheel cuts the start line?
Any info would be appreciated.
Maamukkoya is offline   Reply With Quote
Old 29th May 2004, 02:31   #2
Thanked: 16 Times
"Maamukkoya" ... Oh... Tom, you were reffering to him when u said (For Maamukkoya)
hmmm....
Well Maamukkoya,
Originally Posted by [b
Quote[/b] ]I mean, say for example we have this thing called reaction
If you apply your mind and a bit of logic, you will get the answer to your own question.
Quote[/b] ]Can somebody here throw some light on the official rules
Probably only the participants can tell you, if the rules were different here from the worldwide rules that are used. (but as far as I can recollect, there werent much rules for the actual race, but after finishing, while returning there were few rules u had to follow like a speed limit for egs.) Thats all that I can tell you.
Pferdestärke is offline   Reply With Quote
Old 31st May 2004, 12:54   #3
Tom
Tom's Avatar
isnt that funny? we all talk so much abt the Speed 93 drags and we dont even know how the timing works?
Tom is offline   Reply With Quote
Old 31st May 2004, 13:11   #4
Rtech's Avatar
Thanked: 221 Times
OK Tom,
Ideally, the Reaction time (RT) is not added to your elapsed time (ET). THe RT is only used when the ET's of 2 cars are the same. So the RT is used as the tie breaker.
However, what i noticed from the autocar drag is that they added the RT to the ET and used this combined time for the results. Although I can't confirm this 100%, but it seemed pretty obvoius in a few instances when a guy stalled at the line before he crossed the beam, and his time showed up as 30+ secs, when it would have been about 18 secs. So they added the 2 sec RT to his ET.
For the level drags are running at, there are no hard and fast rules that they have to follow. However, once things become more professional, then they would have to follow a set rule with regards to timing.
Hope that answers your question
Rtech
Old 31st May 2004, 13:39   #5
Tom
Tom's Avatar
ok...we know how it works at the international level.
We actually required more clarity on how the Speed 93 guys timed the runs.
None of the participants seemed to know for sure too. Mr. Bathena was too busy when he was here to answer any of our questions.
Old 31st May 2004, 14:33   #6
Rehaan's Avatar
Thanked: 25,043 Times
Hey Maamukkoya,
Rtech, correct me if i am wrong, but i think -
The RT is the time taken from when the light turns green till the front wheels cross the starting line.
The overall time of the drag (that autocar mentioned ie 13secs etc) it the time taken from when the lights turn green till the car crosses the finishing line.
The RT is just a interesting bit of info to know, but serves no official purpose other than a tie-breaker as Rtech mentioned.
Think about it, if they only measured the time from when the car crosses the start line till the time it crosses the finish line, then a person could chill for 5mins at the start after the lights go green and then do i fast run and still beat his competitor! lol! The lights would be of no use then!
So basically i think the RT is just a part of a breakup of the overall time that is useful information when isolated from the total time.(for drivers especially)
cya
R
ps - i think i have the official rules for the drag that were sent out to competitors, let me know if you want them and i shall hunt for them, although im not sure that they go into the specifics like this, but interesting nevertheless.cya
Old 31st May 2004, 15:46   #7
Rtech's Avatar
Thanked: 221 Times
aaargh,,,i just typed a long reply and then I pressed the wrong button!!!!!
Old 31st May 2004, 15:49   #8
Tom
Tom's Avatar
YEs Rehaan.
I guess everybody is pretty clear of how RT is calculated and how the actual run tim is calculated.
Confusion is......whether the Speed 93 organisers included the RT in the run time or not.
Old 31st May 2004, 15:51   #9
Quote[/b] (Pferdestärke @ May 29 2004,01:01)]If you apply your mind and a bit of logic, you will get the answer to your own question.
Now where is this bugger I would like to see him apply his mind and logic and clear up this confusion. Waiting for you, boss...
Old 31st May 2004, 16:07   #10
Rtech's Avatar
Thanked: 221 Times
lets simplify shall we..!
The first person to cross the finish lines wins! Just as long as he hasn't "fouled" the start and got DQ'd.
Thats all you need to know
However, in the Autocar drags, it is only the overall time that counts, which is the RT added to the ET to give the overall time. They don't run qualifiers or eliminations, so they only go by time, which, for them, is the simplest way to run the event.
Old 31st May 2004, 16:20   #11
Tom
Tom's Avatar
Rtech....thats the problem
I think thr were some cases where the guy finsihing second won cos his run time was quicker.
We also have the rules issued by the organisers of Speed 93 as we had a team entry.
But sadly these things are not mentioned anywhere in it.
Old 31st May 2004, 16:27   #12
It may have nothing to do with crossing the line ahead of the other guy. Because for all you know, the other person might not be in your class at all.
You might be racing a 350 and the other guy can be say a shogun belonging to the 110cc class.
The point of interest is the Timing, and those guys havent properely mentioned whether they add the RT or not...
In the Autocar issue, they have mentioned that "RT was not measured, and only the Total time was measured".
Again that leaves a doubt to as what the "total" time is. The clock can start either at the green light or when the wheels cross the start line.
Old 31st May 2004, 16:42   #13
Rtech's Avatar
Thanked: 221 Times
Total time, as already mentioned, is the RT + ET.
Autocar said they did not "publish" the RT, but that was taken into account fro the timings. The RT was measured, that I am 100% sure off.
Quote[/b] ]I think thr were some cases where the guy finsihing second won cos his run time was quicker.
The regulations clearly state that "the cars will be judged by timings". So who cross's the line first don't make a diff., although, i think I'm correct when i say that the car with the lower overall time will cross the line first! Right?
Quote[/b] ]You might be racing a 350 and the other guy can be say a shogun belonging to the 110cc class.
this will only happen in the "open" category.
Old 31st May 2004, 18:17   #14
Rehaan's Avatar
Quote[/b] (Tom @ May 31 2004,14:19)]YEs Rehaan.
Well i think i gave the reasons but just did not mention what i felt was quite obvious after stating my reasons -
I think its RT+line2line which decides the winner.
cya
Rehaan
A few DRAG Race rules I have put together. Need your suggestions! mclaren1885 Indian Motorsport 37 4th September 2007 03:13
You decide - Make your own drag race classes & rules Rtech Indian Motorsport 62 13th December 2005 13:16
Awesome Drag Racing Game nikibusa Shifting gears 1 8th November 2005 17:03
General discussion on drag racing Rtech Indian Motorsport 45 17th March 2005 10:54
Drag Racing Meet-up,Mumbai gTr The Indian Car Scene 0 9th May 2004 20:50
