Go Back   Team-BHP > BHP Worldwide > The International Automotive Scene
Old 9th May 2014, 12:46   #1
Gannu_1's Avatar
Thanked: 10,520 Times
Default General Motors - Ignition switch recall thread
Most of us are aware of the ongoing GM's infamous recall for vehicles which were equipped with a faulty ignition switch. It has already been brought out in the other thread (The Global *Recalls* Thread) but I believe this one deserves its own thread for the gravity of the situation which would be apparent as you read through. I have compiled all the information from various sources which have been mentioned at the end of the thread.
Estimated number of vehicles affected: 2.6 million.
Cars affected:
(Clockwise from top-left) 2006-10 Pontiac Solstice, 2007-10 Pontiac G5/2005-06 Pontiac G4/Pursuit (Canada & Mexico only), 2006-11 Chevrolet HHR, 2005-10 Chevrolet Cobalt, 2003-07 Saturn Ion and 2007-10 Saturn Sky.
Parts involved: Ignition switch, ignition lock cylinder and key.
General Motors - Ignition switch recall thread-partsinvolvedingmignitionswitchrecalls_100463270_l.jpg
Cause of recall: A component inside the ignition switch manufactured by Delphi Automotive - the switch indent plunger designed to provide sufficient torque for the key to remain in the engine ON position fails to do so and the key would automatically revert back to the ACC (accessory) position shutting off the engine and preventing the airbags from deflating. The key would move back to the ACC position in case of a heavily-weighted key ring or if the car goes over rough roads.
This is the official statement from GM from their press release:
GM is recalling these vehicles because the ignition switch torque performance may not meet GM specifications. If the torque performance is not to specification, and the key ring is carrying added weight or the vehicle goes off road or experiences some other jarring event, the ignition switch may inadvertently be moved out of the “run” position.
This image should make it clear:
Aftermath: At least 13 people have been killed in 31 accidents linked to this component since 2004, and the world's second largest automaker is currently slapped with criminal charges. The recall has also cost the shareholders $3 billion over four weeks!
The irony: The fault had been known to GM for at least a decade prior to the recall being declared! Some have even suggested that the company actually approved the switches in 2002 even though they knew they might not meet safety standards.
GM failed to respond to a special order from NHTSA (dated March 4 2014) and claimed that litigation lawyer Anton R. Valukas and his team was investigating the issue and thus, they couldn't respond. NHTSA has clearly responded that this excuse is "irrelevant to GM's legal obligation to timely respond to the Special Order and fully cooperate with NHTSA". As a result, GM has been fined with $28,000 and will continue to be fined at a rate of $7,000 per day until it meets the requests in the said letter. If GM doesn't comply, NHTSA could refer the case to the Department of Justice.
This is the best part from the letter "Moreover, it is deeply troubling that GM is unwilling or unable to tell NHTSA whether the design of the switch changed at any other time."
Read the entire letter here - 217114568-NHTSA-Letter-To-GM-April-8-2014.pdf
The timeline of events (courtesy Jalopnik):
2001: An official GM document records an ignition switch cutting power to a car, in this case a pre-production Saturn Ion, the Wall Street Journal reports.
2002: Saturn Ion production starts.
2003: A GM service technician observes a Saturn Ion stalling while driving and figures out that the ignition switch was worn down by a heavy key chain. The service technician replaces the ignition switch and the file is closed.
2004: A GM engineer is driving a Cobalt and experiences the switch cutting off the car's power. This includes the engine, power steering, power brakes, ABS, and airbags. Other engineers replicate the cutoff. In 2014, GM claimed that this 2004 incident was the first instance of this problem being recorded.
2005: Cobalts go on sale, GM gets more complaints about the cars losing power, GM issues a service bulletin on how to fix the problem with a key insert. Only 474 people get the insert.
One GM engineer analyzes the cost of fixing the switch altogether. The number rings up to a mere 57 cents. The engineer's report concludes this fix does not represent "an acceptable business case."
2006: A GM design engineer approves a change to the ignition switch. The changes are small, including a new detent plunger and a tougher spring. The new ignition switch does not get a new part number. The head of the Cobalt program also starts a program that puts pressure on engineers to reduce the number of parts changes within the design process. That executive's husband brags about slashing GM's engineering budget to the tune of a $1 billion savings.
2007: NHTSA alerts GM of the first ignition switch-related fatality.
2008: Zilch, according to this NHTSA document.
2009: The birth of 'New GM,' GM starts officially looking into weighty key chains turning off cars. GM then meets with the supplier that makes the switch and discusses the problem as it directly relates to fatal crashes.
2010: GM stops making the Cobalt. Brooke Melton dies at the wheel of her 2005 Cobalt. The switch shuts off the car's power and in the crash, the airbag does not deploy. This will become the case that brings the ignition switch mess to light.
2011: GM's legal department meets with their recall teams to look into airbags not deploying in Cobalts and Pontiac G5s during crashes. GM assesses that the switching-off ignitions could be the cause.
2012: A GM engineer assigned to the case of the no-airbag crashes figures out that a number of ignition switches on Cobalts, G5s, and other cars dating back to 2003 turn off too easily. That is, that the switches were built below GM's standards.
2013: After extensive testing, GM's team assigned to the no-airbag-deployment cars problem figures out that there's a significant number of Cobalts from before 2007 have substandard ignition switches. This GM team then discovers, possibly for the first time, that a different engineering team approved a change to the ignition switch back in 2006 without changing the parts number. GM settles the Brooke Melton case.
2014: Mary Barra becomes GM's CEO (related thread (1st Female CEO in the Auto Industry - Mary Barra @ General Motors)), only two weeks before she claims she first hears about the ignition switch problem. News of the Melton case comes to light. GM starts recalling millions of cars that could have faulty switches, fully a decade after the problem is first recognized.
US Senator Barbara Boxer questioned Mary Barra on rental car safety at a hearing and eventually slams her. Watch the video below:
Barra's testimony also stated that she doesn't know why it took nearly a decade to try to initiate a recall, but that she has accelerated efforts to fix the switches and that she offers "my sincere apologies to everyone who has been affected by this recall, especially to the families and friends of those who lost their lives or were injured. I am deeply sorry."
Departure of Executives and Engineers: On April 10 2014, GM had announced that two engineers Gary Altman and Ray DeGiorgio, have been placed on paid leave (that means a vacation in the middle of an investigation?!) and that it was a "difficult decision." And one of them appears to be the Cobalt and Cruze's engineering manager! Bloomberg says, DeGiorgio had approved a design change in 2006 that improved the spring in the faulty ignition switch and made it more robust, authorizing its production without fully documenting the decision, according to a letter sent to Barra last week by Democrats on the House Energy and Commerce Committee.
On April 14, 2014, GM announced that two of its executives - Selim Bingol, SVP for global communications and public policy, and Melissa Howell, SVP for global HR were departing the company. GM did not comment on whether they had resigned or were fired. (Press Release)
Lawsuits Filed: After the recall was announced by GM, a large number of lawsuits were filed by those claiming to have been injured due to the recalled vehicles' faulty switches, including two class action ones. Two other lawsuits have also named Delphi Automotive, the car parts manufacturer who produced the defective switches, as one of the parties partly responsible for the deaths caused by the now-recalled vehicles.
What this means for GM: This recall is going to cost GM dearly; old GM or the new GM post-bankruptcy doesn't matter here. Recall that Toyota had to pay $1.3 billion for a class action settlement during March 2014, wherein Toyota was charged with intentionally hiding information about safety defects from the public (concerning unintended acceleration) and deceiving the customers to protect its brand image. That was the largest sum of money penalised against a car company for a settlement! Of course, for the world's largest carmaker this is literally peanuts. GM's incompetency and the cover-up for over a decade has resulted in the loss of 13 lives and several injuries (some of them have went unreported). Their only way out is to come clean, admit the wrongdoings, fix the faulty part in all the cars that were sold and pay a (handful) sum to close the settlement. In the history of recalls, this one would be a significant one by all counts.
Workaround from GM: Jeff Boyer, Vice President, Global Vehicle Safety suggests using a single key instead of a heavy bunch of keys on the key chain and after the vehicle has been repaired by the dealer, use the GM issued keys with a hole instead of replacement keys that come with a slot.
Alas, this solution has come delayed by just over a decade! Whatever it is, good luck GM! You are going to need it.
Sources: Jalopnik, IB Times, Bloomberg, WSJ, The Family Deal Blog, Car and Driver. Images copyright respective owners.
Gannu_1 is offline   (7) Thanks Reply With Quote
Old 12th May 2014, 16:40   #2
Thanked: 103,668 Times
Default Re: General Motors - Ignition switch recall thread
Thread moved from the Assembly Line (The "Assembly Line" Forum section) to the International Section. Thanks for sharing!
Old 19th June 2014, 12:14   #3
E63
Thanked: 69 Times
Default GM Just Got Sued For $10 Billion
It's a tough day to be working for General Motors, and it just got a little tougher. The troubled automaker just got sued for $10 billion, or possibly more, for lost resale values of their recalled vehicles.
Reuters says this new lawsuit, filed today in a California federal court, claims the slew of recalls over the past few months — as well as the delayed response to the ignition switch defect — have damaged the brand, and thus hurt owners' ability to sell their cars one day, anywhere from $500 to $2,600.
What's interesting is the lawsuit doesn't just affect the recalled cars (even though they're up to 20 million now) but all GM cars because it claims the entire brand has taken a black eye over the safety crisis.
The suit seeks class-action status from anyone who bought or leased a GM car between July 1, 2009 — around the time the company emerged from bankruptcy — to April of 2014.
Source: http://jalopnik.com/gm-just-got-sued...ion-1592655778
E63 is offline   Reply With Quote
Old 1st July 2014, 06:23   #4
wilful's Avatar
Thanked: 893 Times
A million dollars would be the starting point for GM's payout formula for accidental deaths caused by the defective ignition switch.
There is no cap on the amount of money GM has agreed to spend on victims' payments, Feinberg said, and the company will not invoke its protection from liabilities involving incidents before its July 10, 2009, bankruptcy restructuring agreement.
Under Feinberg's formula, families of those who died are entitled to at least $1 million, and added to that will be a calculation of lifetime earnings lost as well as $300,000 for a spouse and for each dependent.
http://www.ndtv.com/article/world/gm...ome-topstories
wilful is offline   Reply With Quote
Old 1st July 2014, 12:43   #5
arnabchak's Avatar
Thanked: 1,101 Times
Just read this news piece. Source-Yahoo.
Sad to see that 16 innocent have lost their lives due to the indifferent attitude of the automobile giant.
https://in.finance.yahoo.com/news/gm...201753390.html
arnabchak is offline   Reply With Quote
Old 24th November 2014, 06:19   #6
hserus's Avatar
Thanked: 2,695 Times
Default Lovely article on an accident / safety investigation and lawsuit
just saw this. How a lawsuit amd plaintiff retaining a specialist engg company showed a judge that GM was shipping cars with faulty ignition switches.
The article also has a little detail I found interesting for indian roads - ford bronco 2, a cut down version of the ford bronco, had major rollover problems, would flip over changing lanes at high speed etc. after cosmetic changes it was renamed ford explorer (which I think is just the model we have here ..)
http://pando.com/2014/10/18/gms-hit-...al-in-history/
hserus is offline   (2) Thanks Reply With Quote
Old 24th November 2014, 12:12   #7
alpha1's Avatar
Thanked: 1,035 Times
Default Re: Lovely article on an accident / safety investigation and lawsuit
Great! (in a sarcastic manner)
Well to be honest, I am not surprised at GM's (or any other business organization) way of dealing things. No matter how much they hark upon their corporate social responsibility male bovine ordure credentials.
Actually I was appalled + amused (is there a word for such emotion?) reading one of the comments below the article:
I called Cadillac about the problem again the girl told me they would get involve only if there was an injury, I asked her if I should just crash the car the next time I had this problem, she said no but if it does that, they will open up a case
Quite a natural programmed reaction from an organization only concerned about making profits!
Old 1st December 2014, 09:28   #8
Cowardly Lion's Avatar
Thanked: 42 Times
Default GM Recalls: How General Motors Silenced a Whistle-Blower
http://www.businessweek.com/articles...faces-congress
If the car co executives can get away with such behaviour in the US, where there is still some semblance of justice being meted out , then imagine what could be happening in India!
Cowardly Lion is online now   (6) Thanks Reply With Quote
Old 1st December 2014, 11:44   #9
alpha1's Avatar
Default Re: GM Recalls: How General Motors Silenced a Whistle-Blower
Why are you surprised?
For a company/firm the number one objective is profits.
For a listed company the only objective is profit (since other objectives take various precedence for different shared owners - and therefore lose their importance).
Old 1st December 2014, 11:57   #10
fine69's Avatar
Thanked: 886 Times
Why would anyone buy a GM vehicle after reading this article?
I think its awareness, or the lack of it, is why GM is still able to sell cars. Today's customer should be aware, fully aware, and do thorough research because companies like GM are out there to make a killing, literally.
I wouldn't let any of my family members drive a GM vehicle even if it was offered free!
fine69 is offline   Reply With Quote
Old 1st December 2014, 12:33   #11
AshBabu's Avatar
Thanked: 106 Times
Whether in US or India all Business Corporates operate for profit only. The article is another proof how people neglect their conscience and work only for money. There will be many such stories in India also. One or two might raise their voice but will be sidelined.
If this is possible in US, where the enforcement of law and consumer rights are respected, imagine the plight in India. Here we do not value life and are fine in neglecting safety features in name of value for money. Even recently an interview of leading car manufacturer Executive represented this thought process.
AshBabu is offline   Reply With Quote
Old 1st December 2014, 12:46   #12
Zodak's Avatar
Thanks for sharing this. This was an informative read and is a perfect example of how a corporation shouldn't behave. This link actually makes me think about the issue reported elsewhere on our forum about a Captiva catching a fire, and GM's lacklustre response to that. It's in their DNA to not care about anything except profit.
I would make sure that no near and dear ones every buy a GM.
Zodak is offline   Reply With Quote
Old 1st December 2014, 14:32   #13
.anshuman's Avatar
Thanked: 9,159 Times
Have you read about GM's emissions scandal in India?
http://www.leftlanenews.com/gm-found...s-scandal.html
http://gmauthority.com/blog/2013/11/...tavera-recall/
.anshuman is offline   (1) Thanks Reply With Quote
Old 9th June 2015, 23:21   #14
jetti's Avatar
Thanked: 369 Times
Default U.S. Weighs Wire-Fraud Charge Against General Motors
Manhattan U.S. Attorney Preet Bharara continues his unorthodox approach to bring the GM to book after following a similar approach to reach an unprecedented $1.2 Billion settlement with Toyota.
Article: U.S. Weighs Wire-Fraud Charge Against General Motors
Quotes from this article:
Charge stems from auto maker’s failure to recall vehicles equipped with defective ignition switch
Federal prosecutors in New York are focusing on the charge after determining GM likely made misleading statements and concealed information about the faulty switch, now linked to more than 100 deaths, the people said.
In the GM probe, Manhattan U.S. Attorney Preet Bharara is building on an unprecedented settlement with Toyota Motor Corp. in March of last year.
Prosecutors charged Toyota with wire fraud under a unique legal theory that effectively punished the Japanese company not for producing defective products, but for defrauding their customers by making misleading statements about their products’ safety.
jetti is offline   (1) Thanks Reply With Quote
Old 22nd September 2015, 06:25   #15
batterylow's Avatar
Thanked: 711 Times
For hiding a fatal ignition-switch defect tied to at least 174 deaths, General Motors employees will face no criminal charges and the automaker will pay a $900 million fine — less than a third of its $2.8 billion in profit last year.
The settlement with the Department of Justice, announced Thursday, signals a close to the criminal investigation that has long tarnished the car giant. But critics say the automaker got off easy for mishandling one of the worst auto safety crises in history, and years of lying to safety regulators and leaving Americans at risk.
Source
batterylow is offline   Reply With Quote
Key stuck in the Ignition Switch somitra1981 Technical Stuff 2 31st August 2014 08:30
Power Window Switch Recall on the Toyota Camry & Corolla Styler Technical Stuff 3 7th September 2013 18:22
Toyota to recall 8,700 cars in India over faulty window switch LobsterB The Indian Car Scene 19 12th October 2012 10:12
AC Switch OFF or Blower Switch OFF Peter Technical Stuff 24 29th June 2011 12:02
