Go Back   Team-BHP > BHP Worldwide > The International Automotive Scene
Old 18th August 2016, 22:43   #16
Thanked: 11,328 Times
Default Re: Details of the next-generation Volkswagen Polo emerge!
Next Gen Polo on test - Video, Likely to be the GTI
volkman10 is offline   (1) Thanks Reply With Quote
Old 4th September 2016, 19:19   #17
Next Gen Polo GTI is too seen under test, could launch earlier than expected, in late 2017.
it's got LED headlights, twin exhaust, big wheels and upgraded brakes. The design of the wheels seems to be a 17- or 18-inch version of what the Golf GTI. It's also using drive mode selectors, because you can barely hear the sound of the engine.
Details of the next-generation Volkswagen Polo emerge!-spyshotswhythe2018volkswagenpologtimighthavea20lturbo_1.jpg
Details of the next-generation Volkswagen Polo emerge!-spyshotswhythe2018volkswagenpologtimighthavea20lturbo_7.jpg
Link
volkman10 is offline   Reply With Quote
Old 18th September 2016, 20:44   #18
Next Gen Polo to grow in size, speculated to increase about 20 centimeters to reach a length of about 4,17 m. ( Main reason for not getting the Global Polo to India)
Rendered
Details of the next-generation Volkswagen Polo emerge!-imagegallery4766157dbb0629c23e.jpg
will be based on the MQB platform , it is estimated that the weight of the Volkswagen Polo 2017 will fall on average about 70 kilos , in order to stay below that critical threshold in the category representing the 1,000 kilos
Mechanical supply the future Volkswagen Polo 2017 will start with an engine 1.0 TSI 70 hp, which will also have a decline of 100 hp, shared with other models of the Volkswagen Group . But, no doubt, an important novelty is the emergence of a plug -in hybrid version with a pull chain formed by a three - cylinder gasoline and an electric motor.
But that will not be the thing, because a new family based on a block expected 1.5 TSI Evo , which will be split into engines three and four cylinders , with advanced VNT, system of selective cylinder deactivation and Miller cycle, to promote the reuse of exhaust gases and increase efficiency, significantly reducing fuel consumption. It seems that in this new family will emerge mechanical versions of 130 and 150 hp , while the future Polo GTI will use a 2.0 Turbo 200 hp.
Volkswagen Polo 2017 will also feature turbodiesel versions, in particular be based on a 1.5 TDI future to replace the current 1.6 TDI.
Volkswagen Polo 2017 will also take a big leap. For example, one option will be offered adaptive suspension with electronic control , which is more typical of higher segment cars and therefore unusual in the category of utilities. You can also set up a digital instrumentation and a new system of information and entertainment, featuring a large touch screen in the center of the dashboard, with the latest services connectivity .
http://www.autopista.es/novedades-co...n-vw-polo-2017
Old 27th September 2016, 12:28   #19
KiloAlpha's Avatar
Thanked: 1,181 Times
Which means that the MQB 2017 Polo is as big as the Mark 4 Golf, which was just over 4m long.
As far as the Indian market is concerned, I am not sure if there is scope for shaving 170mm to bring the car under 4m. However, with the GST regime likely to result in the end of the sub-4m "small car" incentive, not sure if this is going to matter too much.
KiloAlpha is offline   Reply With Quote
Old 27th September 2016, 12:50   #20
Either ways it was reported that India is not likely to get the Polo in the MQB platform but the existing platform PQ25 which will be tweaked and internally code named VX x26 IN NF (PQ26). Look wise it will look simialr to the Gen next Polo. The reason cited is the cost involved in this new platform seem currently exorbitant for justifying the business case.
Link
Old 7th October 2016, 09:21   #21
Next Gen Gol for Brazil will be based on the MQB platform A0, lower variation of the modular platform that is already in use in Golf.
The result will be a larger and more spacious: sources speak at length until 10.5 cm larger, reaching 4 m long and about 2.55 m wheelbase.
Details of the next-generation Volkswagen Polo emerge!-qr688capa01rgbparainternet.jpg
the Gol will have limitations in relation to the Polo, especially with cost. In Europe the most powerful Polo will be one of the first VW with the modern motor 1.5 TSI of 150 HP, for here the big news will be the 1.6 16V turbo MSI with the same 150 hp. Levels of consumption and emissions are lower, but it will be cheaper. Still, it would be a great argument for a possible Gol GTI.
The same platform will give rise to new MQB A0 , the new Sloop and expected compact SUV from Volkswagen
India Plans -
We will need alignment with the Brazilian, South African and Russian markets that have demand for similar products.
With top officials revealing the alignment of strategy with Brazilian market - This is most likely to come to India- Polo and the Compact SUV!
Both will look like the Global product with control on cost!
Link
Old 7th October 2016, 09:28   #22
reignofchaos's Avatar
Thanked: 741 Times
150HP in a Polo for a sane price would definitely put it on the enthusiast's radar. However India is the last priority for VW looking at their strategies.
Old 30th October 2016, 17:41   #23
VW begins testing the New Gen Gol for Brazil - Visually speculated to look like the Next GEN Polo for Europe. Will this be India bound as the 2018 Polo?
Expect also a Polo GTI version for emerging markets.
Details of the next-generation Volkswagen Polo emerge!-flagra_volkswagen_gol_2018.jpg
Details of the next-generation Volkswagen Polo emerge!-flagra_volkswagen_gol_2018_2.jpg
the project is called Gol MQB, the model will be built from the MQB platform A0, shorter version of the MQB modular. For their production
In visual, the Gol 2018 will be very similar to the new Polo, but, of course, more simplified, even by the different positioning of the models in the markets where they will be sold.
The three-cylinder 1.0 engines, TSI and 1.6 16V 1.0 MSI are already confirmed in the new generation of the Compact. It is speculated that the 1.4 TSI Flex is also part of the catalog
Source
Old 31st October 2016, 14:14   #24
With VW plans of aligning India plans along with the LA market , it is most likely the Polo and the Polo GTI's ( MBQ A0) are India bound in 2018.
Yes the Polo GTi's are likely to be with the 1.4TSI @ 150hp, while the standard will come with the 1.0L TSI @115hp.
There are already two engines confirmed for this new model 1.0 turbo 115 hp and 1.4 turbo of 150 hp.
Will the 2018 Polo GTI (Brazil) be shown at the S„o Paulo auto show?
Link
Link2
Old 22nd November 2016, 20:22   #25
Thanked: 55 Times
Extract from Autocar's article:
The new Polo is likely to be based on the MQB A0 platform which will also underpin the all-new compact SUV due in 2018. Like the current model, the new Polo is likely to get the localised 1.2 TSI four-cylinder motor with a similar amount of power (112hp) and a retuned and more powerful version of the 1.5 TDI (117hp) thatís currently made here.
Source Link:
http://www.autocarindia.com/auto-new...kly_newsletter
vijayvelprakash is offline   (1) Thanks Reply With Quote
Old 22nd November 2016, 20:54   #26
Thanked: 66 Times
As per the reports, they are still hung up on using the 1.6 TDI derived motor. Internationally, 1.6 TDI has been replaced with a 1.4 TDI engine putting out the same power and torque.
The MQB-based Polo facelift (Mk6; 6C) launched in 2014, comes with the 1.4 TDI. By the looks of the GTI launched in India, it seems to be the Mk6 model, that is newer than other Polo variants sold here at present.
halfbytecode is offline   Reply With Quote
Old 3rd December 2016, 19:08   #27
Why the Next Generation (Global) Polo will not come to India?
the VW MQB platform, which has already formed the basis of 58 models across the group and eight million vehicles sold. MQB A0 will underpin 2017’s new VW Polo and then be used across the group’s small cars with next generation SEAT Ibiza, Skoda Fabia and a range of smaller SUVs set to use the new platform.
As well as weight and cost benefits, MQB A0 also brings a range of advanced driver assistance technologies that haven’t yet been seen on small cars. It’ll also mean that vehicles as diverse as the Polo and the five meter-long VW Atlas SUV will be built on MQB platforms, with length differences of over one meter.
VW bosses have also hinted at the need to fill the gap between next year’s even larger Polo and the up! city car, although it might not wear a VW badge. VW has confirmed two further group brands – one to be used in emerging markets and one for its smart mobility solutions – but Skoda and SEAT offerings are also expected to fill that gap.
Source
Old 13th December 2016, 19:56   #28
Details of Gen next Polo emerge. To be unrelieved at the Frankfurt Motor show in 2017 and will go on sale in Q4 2017.
Details of the next-generation Volkswagen Polo emerge!-volkswagenpolo6projecao1.jpg
Will be built on the MQB A0 platform and will be bigger than the existing one which is on the PQ25 Platform.
Speculations are a length of 4,17m, the reason for the increase in size in the wheelbase, which will rise of 2.47 m to 2.56 m, a standard measure in MQB A0.
Details of the next-generation Volkswagen Polo emerge!-volkswagenpolo6projecao2.jpg
This space is only 1 cm bigger than seen in Polo/Vento Sedan currently sold in Europe, Russia and India. So, probably the new Polo Sedan should not grow as much as the hatch.
The new Polo engine is expected to be a new 1.5L TSI, will deliver 75, 100 / 115 HP and will be accompanied by an equivalent 1.5 diesel TDI. ( will not be the 1.0L as to meet the emission norms a biiger engine will be needed.)
Will be with the virtual cockpit which is now seen in the New Golf,
Link
Old 14th December 2016, 09:37   #29
sgiitk's Avatar
Thanked: 3,139 Times
I am not sure that the scenario will be post GST. So it will be prudent for VW to wait. The habit of a car putting on heft between updates is very common. Remember if they have a lot of imports in the body, then stocks may not last long.
Old 14th December 2016, 09:43   #30
Volkswagen will most likely NOT bring this Polo (MQB A0) due to cost reasons and will get the one simialr in design but in the modified PQ25 Platform.
GST has no role in its decision and purely cost of manufacturing which is prohibitive in these cost sensitive markets.
Ferrari 458 Italia Spyder - Details Emerge. EDIT : Now officially unveiled! Scorcher The International Automotive Scene 23 31st January 2013 10:04
2012 Merc SL Class - Spy Pics and Initial Details Emerge Scorcher The International Automotive Scene 0 16th November 2011 23:16
Volkswagen Polo specs. EDIT : 11,111,111th Polo rolls off in Pune (Pg. 18) sidindica The Indian Car Scene 375 23rd February 2010 18:10
The next generation of Indian cars: What do you expect? sajo The Indian Car Scene 4 27th March 2006 16:06
