Go Back   Team-BHP > BHP Worldwide > The International Automotive Scene
Old 4th July 2017, 08:23   #16
Thanked: 15,262 Times
Default Re: Brazil-spec Renault Kwid to get ABS, 4 airbags
Renault KWID to go on sale in Brazil from 2nd August.
The model can now be ordered in pre-sale mode with prices ranging between R $30,000 and R $40,000 real, depending on the version. ( ~ 5.9 - 7.8 lakhs, INR)
The Kwid will be sold in three versions, all with the three-cylinder engine 1.0 Flex of 70 horses, and manual transmission.
link
volkman10 is offline   (1) Thanks Reply With Quote
Old 25th September 2017, 22:59   #17
KWID in Brazil decked up like a Mini Captur!
link
volkman10 is offline   Reply With Quote
Old 16th November 2017, 20:25   #18
MADE IN BRAZIL KWID secures 3 star rating in LATIN NCAP tests.
Frontal impact: The protection offered to the driver and passenger head and neck was good. Driver chest received marginal protection and passengerís chest adequate protection from the restraint systems. Driver and Passengers knees showed marginal protection as they could impact dangerous structures behind the dashboard. Driver tibia showed adequate and marginal protection, while Passengerís tibias showed adequate protection.
Footwell area is stable and showed insignificant deformation. Feet protection is good. The bodyshellwas rated as stable. Side impact: The side thorax airbag offered weak protection to the adult in the chest, while the car offered adequate protection to the abdomen and head and pelvis had good protection. The car does not offer ESC and side pole impact test could not be performed, as side head protection airbags are not available. The car offers two frontal SBR. All of the above explain the 3 stars for adult occupant protection.
Old 21st November 2017, 18:42   #19
Renault KWID recalled, all units since launch.
Cracked brakes and fuel pipe that can be lead to leakage are the reasons for the recall of 21,802 units.
the assembly of the fuel pipe, which is in a position that can cause a rupture, leaking fuel. The failure was detected in 16,798 subcompact units produced between March 1, 2016 and September 27, 2017.
The other recall campaign is no less serious. The brake system can crack, reducing its efficiency and, in some cases, locking the wheels, which causes loss of driveability. Renault will check the brakes of all Kwid produced between March 1, 2016 and November 2, 2017, a total of 21,802 units
LINK
Maruti Suzuki Swift and Dzire L and V variants get optional ABS and airbags Aditya The Indian Car Scene 53 7th December 2015 18:05
Datsun Go to get safer - will get stronger body, airbags, ABS Aditya The Indian Car Scene 49 17th June 2015 18:13
Renault XBA: Now unveiled as the Kwid rajeev k The Indian Car Scene 36 21st May 2015 16:34
Tata Indica Vista Aura ABS (EDIT: Now it is Aura Plus with ABS and Airbags) akhilesh51 The Indian Car Scene 141 28th September 2010 20:11
