Go Back   Team-BHP > Around the Corner > Introduce yourself
Closed Thread
Old 3rd June 2009, 14:03   #1
KRIEG150's Avatar
Default Thanks for letting me in!
This is bhushan from Mumbai…a B.E. (Mechanical) from RGIT (Versova), and currently working with L&T Oil & Gas. I’ve grown-up admiring cars and under-the-hood stuff…not so interested with all the cosmetics on the outside. I’m naturally inclined towards suspension and transmission systems. As my final year project for B.E, my team & i built “KRIEG150”…the gokart with suspension and mild offroading capacities…here are the tech-specs in brief:
"KRIEG150"
Engine:
Bajaj PULSAR 150 1st Generation (free flow exhaust - no silencer!!!)
Transmission:
The power split-up from the P150 engine to the two rear wheels was done by a shaft which was conceptualized, designed (structurally sound) in Ansys by my team; fabrication outsourced (not my cup of tea!) The shaft could allow for vertical wheel deflections of upto 150mm. It was without a differential though due to cost concerns
Chassis:
Conceptualized, designed (structurally sound) in Ansys and FABRICATED in-house (college machine-shop), by my team.
Wheels:
Bajaj Super 8” wheels
Suspension:
1) Front:
Unequal Double wish-bone with horizontal spring mounting. Wishbones from Premier Padmini were cut to suit our requirement and rod-end bearings used to mount them onto chassis
Springs were from Bajaj M80 (sourced from Kurla chorbazar)
2) Rear:
Independent single-sided swing arms sourced from Bajaj Autorikshaw. Springs were from Bajaj Pulsar (sourced from Kurla chorbazar)
Brakes:
Bajaj AutoRikshaw (hydraulic drum-brakes)
Steering:
1) Mechanism: Modified Ackermann mechanism with the “go-kart touch” to it
2) Steering Wheel and Steering Column: Maruti Omni (sourced from Kurla chorbazar)
3) Steering Spindle: taken from Rack of Tata Indica (from Kurla chorbazar)
4) Front Wheel knuckles: Fabricated In-House
In all, the parts of this project come from 3 different TWO-Wheelers, 1 THREE Wheeler and 2 Four Wheelers! - All integrated using imagination of 5 Auto Freaks (myself included!)
Currently i'm working on a 6WD ATV on the lines of the Argo480 6X6...will neeed tremendous tech-support from Team-BHP on that front..
please chk out the pics of the KRIEG150...
Note from the Team-BHP Support Team : Please take the time to use proper punctuation as per Team-BHP rules. Avoid...typing...like...this. Thanks.
Last edited by Technocrat : 3rd June 2009 at 16:54. Reason: please see the note in post
KRIEG150 is offline
Old 3rd June 2009, 16:44   #2
TheOne®'s Avatar
Welcome aboard!
I am sure you will have a great time here and I am convinced that a lot of people will be happy to provide you with technical support.
TheOne® is offline
Old 3rd June 2009, 16:51   #3
sonirohit's Avatar
Great effort - What are the performance figures for this machine???
sonirohit is offline
Old 3rd June 2009, 17:17   #4
Welcome aboard! have a pleasant stay. great mod work!! keep it up
Last edited by Rehaan : 3rd June 2009 at 19:45. Reason: gr8 = great. Please type in full words and avoid SMS language. Thanks.
hariharanea is offline
Old 3rd June 2009, 17:35   #5
KRIEG150's Avatar
well we did manage an approximate 55kmph on it in 4th gear (the speed was chked by a Passion Plus driven close beside it and matching the speed - the reason being that the gokart had no speedo!) anyway, driving that not-so-timid machine even at 40kmph was a bit scary inspite of the rudimentary and uncomfortable but safe seatbelts we had put on it.
one interesting point is that since we had put a 11Nm@7000rpm engine on a kart with 8" rims and not the usual 15" of the P150, the gokart would ALWAYS start-off with a burnout on any given surface!!!
KRIEG150 is offline
Old 4th June 2009, 04:35   #6
harishnayak's Avatar
Thanked: 116 Times
Originally Posted by KRIEG150 View Post
"KRIEG150"
Engine:
Welcome aboard . Whats the weight of this vehicle?
harishnayak is offline
Old 4th June 2009, 21:28   #7
KRIEG150's Avatar
Default video of the kart
ppl please check out the video of the KRIEG150:
@harshnayak
the weight is about 250kgs (with a 70 kg rider and filled-to-the-brim petrol tank of 500ml )
KRIEG150 is offline
Old 4th June 2009, 23:44   #8
rider60's Avatar
Thanked: 47 Times
congrats, i think this is the season of the home built/indigenous designer students and designers.
there is a thread of indigenous 1000cc motor cycle running already in the motorbikes section and a awesome project to live through building the machine.
so is your build.
awesome effort mate.
a hearty welcome to t-bhp.
rider60 is offline
Old 5th June 2009, 18:34   #9
Rehaan's Avatar
Thanked: 23,059 Times
Hi KRIEG150,
Welcome aboard!
Check this similar project out :http://www.team-bhp.com/forum/introd...kart-kvx1.html (Off Road KArt .. KVX1)
Also, i suggest you start a new thread for your project and leave this as an intro-only thread, since it will lock automatically after a few weeks (preventing further posts).
cya around,
R
PS - Also do a search for FSAE on the forum to see some more cool projects.
Rehaan is offline
Old 8th June 2009, 11:20   #10
Cool Project Bhushan,
Welcome onboard, have a nice stay.
Just one question why did you choose pulsar 150cc & not some bigger engine like Bullet 350cc to have more power & torque
SamtheLeo is offline
Old 8th June 2009, 12:08   #11
Welcome to Team-BHP. I am sure you are going to have a blast.
T_Girl is offline
Old 8th June 2009, 22:52   #12
KRIEG150's Avatar
One of the reasons that i used the P150 was that i got the engine from a reliable source and that too pretty quickly (but now i know that i was duped commercially ). The second reason was that the 350cc biggies (enfields and RD's )have a comparatively larger footprint on the chassis -> and i already had too much to pack into that tiny framework. hence the selection.
KRIEG150 is offline
Old 9th June 2009, 00:32   #13
johnda's Avatar
Thanked: 11 Times
Welcome here! have a blast... that is some neat stuff that you've built.
All the best. Have a nice time!
johnda is offline
Old 9th June 2009, 01:46   #14
McLaren Rulez's Avatar
Thanked: 474 Times
Neat thing man! Do be careful on it though
McLaren Rulez is offline
Closed Thread
Thanks for letting me and my Storme in redracham Introduce yourself 1 24th July 2015 18:02
Thanks for letting me in! RJ411 Introduce yourself 5 20th July 2015 18:49
Duratorq-in' with Josh: Ford Ikon TDCi * 4 years 7 months/43,941 km & Letting Go :( condor Long-Term Ownership Reviews 441 16th September 2013 13:14
getting a Corolla H2 1.8E and letting go of OHC 1.3 EXi weejai Sedans 30 18th June 2009 16:04
P Chidambaram is letting me buy the car now. Samurai The Indian Car Scene 14 11th March 2005 17:44
