Old 19th March 2014, 21:13   #151
Thanked: 14,604 Times
Default Re: My Gen3 Maruti Suzuki Swift VDi Sep2011 40,000kms Update !!!
Originally Posted by moralfibre View Post
Therefore I took it upon myself to change oil + oil filter and clean / replace the air filter.
Good DIY!
And I see that you are using 15W40 oil, i.e. Mineral oil, how long do you find the smoothness in the engine? Does it last for 5K kms or the NVH increases earlier?
Anurag.
a4anurag is online now   Reply With Quote
Old 19th March 2014, 21:15   #152
moralfibre's Avatar
Thanked: 6,532 Times
Good DIY!
Anurag.
It goes well till 4500 kms after which I begin to notice an increase in NVH. Now, I am not quite sure if it is psychological.
moralfibre is offline   (1) Thanks Reply With Quote
Old 19th March 2014, 21:19   #153
It goes well till 4500 kms after which I begin to notice an increase in NVH. Now I am not quite sure if it is psychological.
It is not psychological!
Reason for me telling this is, when I had the Ritz VDI, I used synthetic oil (5W40) which has a change interval of 10K kms that was silent and good enough till 9K kms but the last 1K kms were like a AL lorry.
Yet to have an oil change by MASS in my Swift ZDi which is at 10K kms though I changed the oil + oil filter proactively at 5K kms, now thw car is at 7.5K kms.
Anurag.
a4anurag is online now   (1) Thanks Reply With Quote
Old 19th March 2014, 21:36   #154
moralfibre's Avatar
We encountered continuous rains on our trip to Goa. Add to that, there was road construction work going on at various sections of Amboli Ghat as well. The car was covered in muck and there were tar spots all around. The only sane option was to take it to 3M car care near my work place.
The person at 3M recommended some treatment to wash and wax the car which would take care of the tar spots as well. The end result was satisfactory though I feel that 3M has lost touch with quality off late. He used some adhesive cleaner to get rid of the tar spots. I think a dedicated bug and tar remover should have been available with 3M. The cost was somewhere around 900-1000 bucks.
moralfibre is offline   (2) Thanks Reply With Quote
Old 19th March 2014, 21:59   #155
The person at 3M recommended some treatment to wash and wax the car which would take care of the tar spots as well. The cost was somewhere around 900-1000 bucks.
You are right, 3M guys do a Foam Wash + Waxing that takes care of everything and it comes down to Rs 1050 including taxes.
Anurag.
Old 24th November 2014, 12:08   #156
vishnu-man's Avatar
Thanked: 60 Times
I've been following your thread for sometime!
I too have a Gen 3 Swift VDi with VIN number less than that mentioned in the Maruti's circular for synthetic oil.
Here's my experience on the Synthetic/Mineral engine oil.
During its 30K service, the SA insisted to try out Maruti provided Synthetic oil (is this Mobil's flavour?). I gave it a try, but was not really happy during this run.
After about 35K kms, I started get a lot of jetting during mornings when I used to get the car onto the ramp before hitting the road (having waited in idle for about 30 seconds on the day's first crank).
There used to be something missing with the 2nd and 3rd gear pull. I was too laggy.
It was time for 40K and I was mentally prepared, went to J.K. Automobiles from J.C. Road in Bangalore and picked up 4 litres of Delvac MX 15W40 Mineral Oil got it filled at Service center and things changed for good.
The car is now 42K on the odo and runs like a gun.
No more early morning jetting and also the engine noise levels have come down with the absence of lags during 2nd and 3rd gears.
I didn't post my experience till I crossed 2K with Delvac MX 15W40 as I wanted to give it sometime to understand if it is really working for me.
Now, ergo this post!
vishnu-man is offline   (2) Thanks Reply With Quote
Old 11th November 2015, 12:12   #157
vishnu-man's Avatar
Thanked: 60 Times
Hello moralfibre!
Hope you're doing well!
Jogging this thread after a year
So, I guess you would've clocked over 65K on the odo by now.
I'm with the Delvac MX 15W40 ever since 40K and now I'm reaching 60K.
Just wanted to know if you're still with same oil.
Appreciate if you could share the latest!
vishnu-man is offline   (1) Thanks Reply With Quote
Old 24th November 2015, 10:13   #158
moralfibre's Avatar
Originally Posted by vishnu-man View Post
Hello moralfibre!
Yes I am with the same oil. Car has trudged past 80k kms now. Major servicing is due. I'll get the following done shortly:
- Suspension overhaul. The car is bouncing away to glory.
- Brake pad replacement.
- Clutch overhaul.
- EGR cleaning.
- Intercooler cleaning.
- Throttle body cleaning.
- Regular service (without diesel filter and coolant replacement. These wee replaced just about 5000 kms ago).
Hope that helps.
Old 24th March 2016, 10:35   #159
vishnu-man's Avatar
Thanked: 60 Times
- Clutch overhaul.
- EGR cleaning.
Hope that helps.
Thanks for the reply.
I was away for sometime.
Good to know that you're still with Delvac MX.
I've done 65k as of now and will be following the same path you've planned with the suspensions, brake pads, clutch assembly and throttle body.
Please leave your comments on how much they cost you when you get them done.
Your inputs are of good value to me.
I'm a little concerned with the clutch assembly if they last really good.
Thanks a ton!
vishnu-man is offline   Reply With Quote
The Abominable (Skoda) Yeti *UPDATE* 20,000Kms Update on Pg.14 SushilBajpai Test-Drives & Initial Ownership Reports 281 8th December 2016 16:08
My Red Pimento - Maruti Swift Vdi Euro IV review - 40000 Kms update ontheroad Test-Drives & Initial Ownership Reports 19 9th June 2013 20:01
My ka Laal: Swift - Oye VDi, VDi Oye! - 12 months, 29.3k km UPDATE phamilyman Long-Term Ownership Reviews 89 7th May 2010 17:13
Booked my Azure Grey Maruti Suzuki Swift VDi with ABS BBT Test-Drives & Initial Ownership Reports 54 3rd December 2008 06:11
