Old 19th January 2016, 21:59   #181
thoma's Avatar
Thanked: 1,089 Times
Default re: Nissan Micra Diesel. EDIT: 95k kms of happy ownership, a 2nd Micra joins the family!
Originally Posted by amalji View Post
The sad thing is that he has completed only 20,000 odd kms. He is forced to do the 40,000 kms service because of the 6 months service interval of the Micra. Can anyone confirm on this as well ?[/list]
This is one frustrating part of ownership of the Micra and Sunny for those with less running. You need to go for service every 6 months and the total cost comes above a VW Vento D whose service interval is once a year and amounts to ~11k only.
thoma is offline   Reply With Quote
Old 20th January 2016, 12:57   #182
Thanked: 1,645 Times
Post re: Nissan Micra Diesel. EDIT: 95k kms of happy ownership, a 2nd Micra joins the family!
Also, can you tell me the regular 40,000 kms service labour cost. My uncle told it was 2750 which looked quite unrealistic.
amalji is offline   (1) Thanks Reply With Quote
Old 24th February 2016, 15:21   #183
PetrolRider's Avatar
Thanked: 237 Times
Hi, a few queries.
Does your a/c compressor switch on and off too intermittently? Do you experience any slightest drag on the acceleration with this intermittent on/off? Does the a/c come on with a loud hiss in the mornings?
I think the A/C compressor on and off are more to the out side temperature. While I was in Bangalore, I never faced this issue as A/C was always on minimal position, but in Pune during summer noon I sometime have to put the A/C on higher side and then I have faced this issue. I feel because of the larger glass area on front, the compressor have to work more frequently to keep the cabin cool. I am no expert on this, but this is my assumption.
Regarding the drag,my micra is a petrol one (3 cylinder), and I always feel some loss of power whenever I switch on the A/C, but I have not feel on difference of power during compressor switch on or off.
PetrolRider is offline   (1) Thanks Reply With Quote
Old 25th March 2016, 10:22   #184
bravo82in's Avatar
Thanked: 246 Times
My Car has done 90,000 kms. Running good, no issues. Service bill was close to Rs 6500/-. Was adviced clutch and timing chain replacement at 85,000 km service but i didnt comply. Clutch failed completely yesterday. Will get the clutch replacement done on Monday. Any suggestion when and why timing chain be replaced?
bravo82in is offline   Reply With Quote
Old 25th March 2016, 12:51   #185
Thad E Ginathom's Avatar
Thanked: 8,337 Times
It is a very hard-worked component of your engine, and, if it fails, the entire engine will suffer catastrophic damage. They were right about the clutch, it seems, so perhaps you should accept the recommendation for a new timing chain.
What is the quoted cost?
Thad E Ginathom is online now   (1) Thanks Reply With Quote
Old 25th March 2016, 16:48   #186
thoma's Avatar
Timing chain for the Micra D needs to be changed at 3 yrs or 60000 kms whichever is earlier. Since it is a rubber component, not a chain, even if the running is low, one has to change it as per the time period. I had just 25000 kms on my odo when my timing belt was changed. They said that some people had suffered engine valve damage due to not changing timing belt on time. Earlier they were slotted in to change the belt at 4 yrs but now it has been reduced seeing more failures. Please change it immediately.
Do change the tension pulley for the timing belt and the alternator belt along with it. All the three alone might cost you around 10k. I was spared replacing the tension pulley since it is not a rubber part and my running is too low.
The same when I inquired for my VW Vento, they said they need not change the belt with respect to time and their belt last for around a lac kms. I am really pissed off with the maintenance cost for the Micra D, especially when my running is too low.
thoma is offline   (3) Thanks Reply With Quote
Old 22nd May 2016, 00:01   #187
bravo82in's Avatar
Thanked: 246 Times
First major maintenance bill for my micra. The clutch failed due to hydraulic failure. Replacement cost 18000/- Got the timing belt and tensioner replaced. Cost Rs 9000. With 95,000 km service due total bill will be Rs 35,000/-
At 95,000 kms, I am one happy owner of Micra. Absolutely no issues, no part failure, no rattles, nothing. The car zips through Delhi's traffic, AC works fabulous. Even in peek summer with single or double occupancy, fan runs at speed II. The interiors look as fresh as a one year old car.
bravo82in is offline   (5) Thanks Reply With Quote
Old 22nd May 2016, 00:46   #188
thoma's Avatar
I was looking for this; the clutch replacement cost for the Micra. I was contemplating on keeping or selling the Micra vs Vento. Why I'm looking at the clutch costs is because my wifey has a tendency to ride the clutch and I'm sure it will wear of prematurely. The Vento clutch and flywheel costs ~40k. Did you have to change the flywheel too?
I'm having a horrible time with my a/c. On rare occasions, the actuator gets stuck a bit and cold air flows to the legs even if the mode is directed to the face. Cycle through the modes and it is gone. And on some other rare occasions, I feel a a lot of time to cool the cabin from super hot conditions. Up the temperature and bring it down, it cools faster; something with the auto climate control I believe. And recently I get slight outside odor in the cabin even if I am on recirculating mode. On top of this, I hate the compressor getting turned on with jerk every 10 seconds if the fan is on low speed (the pressure temperature combination at the evaporator decide the timings). I'm wondering no one else is complaining about it. I even tried it on a brand new showroom car.
thoma is offline   (2) Thanks Reply With Quote
Old 22nd May 2016, 05:48   #189
bravo82in's Avatar
Thanked: 246 Times
Yes the fly wheel was changed too. My driving is typically bumper to bumper in Delhi with a weekly outstation trip. Clutch lasted 85,000km which I believe is very good.
If the actuator is giving problems, it can be taken care off with AC Service. Probably needs cleaning and oiling for smooth running. Ac turning off frequently can be due to faulty sensors. Many Nissan Sunny are being used as cabs. Have a word with those cab drivers. There are efficient AC mechanics in every metro. Give it a try.
bravo82in is offline   (1) Thanks Reply With Quote
Old 23rd July 2016, 21:14   #190
bravo82in's Avatar
Thanked: 246 Times
Default Re: Nissan Micra Diesel. EDIT: Added some bling to interiors
I was getting bored of 'greige' interiors of my Micra decided to add some chrome to it. Couldn't find much options online and at accessories shops. The original chrome door handles cost Rs 2500 apiece and 15-2000 INR in grey Then Aliexpress comes to rescue. Here is the result.
Nissan Micra Diesel. EDIT: 95k kms of happy ownership, a 2nd Micra joins the family!-img_20160722_170405.jpg
Nissan Micra Diesel. EDIT: 95k kms of happy ownership, a 2nd Micra joins the family!-img_20160722_170419.jpg
Nissan Micra Diesel. EDIT: 95k kms of happy ownership, a 2nd Micra joins the family!-img_20160722_170354.jpg
Nissan Micra Diesel. EDIT: 95k kms of happy ownership, a 2nd Micra joins the family!-img_20160722_170313.jpg
Old 23rd July 2016, 23:35   #191
thoma's Avatar
How much did it cost you? Can I get the a/c vent inserts alone? Is so, how much would it cost? Is the a/c vent chrome a DIY fix?
Is that a gear lock in the last picture?
Old 24th July 2016, 00:19   #192
bravo82in's Avatar
Thanked: 246 Times
Default Re: Nissan Micra Diesel. EDIT: 95k kms of happy ownership, a 2nd Micra joins the family!
All parts can be ordered individually
AC inserts Approx Rs 500 for a set of 4
http://www.aliexpress.com/item/Brigh...08.0.96.miK2bq
Gear shift trim Rs 760 approx
http://www.aliexpress.com/item/For-N...08.0.80.miK2bq
Door Handle Rs 2000 approx
http://www.aliexpress.com/item/Free-...6-680920b676e9
That's a gear shift lock in last pic.
bravo82in is offline   (3) Thanks Reply With Quote
Old 31st July 2016, 14:04   #193
Thank You! Unfortnately the AC inserts are sold out now. Need to wait :(
Anubhav89 is offline   Reply With Quote
Old 1st August 2016, 10:28   #194
bravo82in's Avatar
Thanked: 246 Times
Originally Posted by Anubhav89 View Post
Need to wait :(
There are many other sellers.
http://www.aliexpress.com/wholesale?...ent+trim+versa
Old 26th September 2016, 21:49   #195
Thanked: 44 Times
Hello Bravo, congrats on your micra completing 95k. I have a diesel micra too and is inching towards 84k. Could you please tell me the engine oil grade your service centre use? One of the service centres in my city said they use 10w30 which I primarily think is a motorbike engine oil. Have you ever tried doing routine service outside Nissan A.S.S ? I'm contemplating to do an oil change from an outside garage with a Purolator air filter and Bosch oil filter, still undecided on the oil. Please advise me on the same.
rupdeb is offline   Reply With Quote
Nissan Micra Review. EDIT: 8 years of trouble-free ownership! W.A.G.7 Long-Term Ownership Reviews 165 3rd June 2018 11:07
Sita, Red Mahindra XUV5OO W8 joins our Family. EDIT: 1 Year & 35,000 kms up Mudhalaipatti Test-Drives & Initial Ownership Reports 133 11th April 2014 06:58
Made in India Nissan Micra global recall: 9,600 Micra compact cars with faulty sensor rkg The Indian Car Scene 1 25th February 2012 09:22
Heart vs. Head - Nissan Micra or Maruti Ritz? UPDATE: Booked the Micra W.A.G.7 Hatchbacks 38 29th December 2010 20:28
