Old 26th March 2017, 14:44   #361
Thanked: 126 Times
Default Re: The White Knight - My Toyota Etios Liva Diesel. EDIT: 50,000 kms update
Originally Posted by rajivr1612 View Post
Hi Saadat, sorry to hijack your thread, but felt this will be useful:-
A common problem faced by us Liva owners is $$ For the interest of Liva owners is the lack of weather seal on Liva doors causes lot of dust to settle on the door frame. In my case on two occasions a lizard was hiding in the gap and when I opened the door, it jumped inside the car. It took a hell lot of effort to get it out.
A month ago was browsing through Ali Express and came across this:-
The item is available at below link:-
https://www.aliexpress.com/item/4M-Z...608.0.0.Zd4vbJ
Ordered it and was delivered within one month. No additional duties paid.
Installed it yesterday and the results are very good.
Thanks a lot for sharing. Can you please share more detailed snaps?
coolmel is offline   Reply With Quote
Old 10th May 2017, 13:23   #362
saadat1992's Avatar
Thanked: 293 Times
Major update:
An update after what seems to be an eternity. The car went through the 50k service recently and all 4 tyres were changed due to excessive wear & tear.
The tyres have been upgraded to 185 sections and the car feels as good as new after these upgrades and service.
Changed the stock 175/65 R14 to 185/65 R14 Goodyear Assurance triplemax ones.
The 50k service though had certain issues. They had given me free 3M interior and exterior cleaning for renewing the smiles package. They rectified the exhaust pipe noise issue that I had pointed out, however they hadn't rectified the security system issue. So when I was checking the car prior to the delivery, I was shocked to see they hadn't filled the coolant up. It was well below low level & when I asked the SA about it, he said it was 'normal'. Normal my foot! I told he should stop with all this BS and asked if this was what the service was all about, he apologized and immediately brought a bottle of coolant and filled it up to the rim. They then got the people from accessories and 'fixed' the security system issue by removing the switch from the bonnet and gave another bad reason saying it won't be a problem. And despite all this, the SA had the audacity to ask me for a 5 star rating.
Totally dissatisfied, I drove back home to find that they had not changed the brake pads either -_-
What has Harsha Toyota's service come to? They're definitely damaging the reputation of Toyota by doing a shoddy job. I'm planning to write to TKM regarding this, if nothing goes my way with Harsha, I'll have to switch to Lanson.
Coolant below Low
The White Knight - My Toyota Etios Liva Diesel. EDIT: 50,000 kms update-1494402605537.jpg
Interiors done by 3M
The White Knight - My Toyota Etios Liva Diesel. EDIT: 50,000 kms update-1494402633277.jpg
Before the delivery
The White Knight - My Toyota Etios Liva Diesel. EDIT: 50,000 kms update-1494402665711.jpg
One of the new tyres
The White Knight - My Toyota Etios Liva Diesel. EDIT: 50,000 kms update-1494402699027.jpg
Alignment being done at BM Lal
The White Knight - My Toyota Etios Liva Diesel. EDIT: 50,000 kms update-1494402732319.jpg
The White Knight - My Toyota Etios Liva Diesel. EDIT: 50,000 kms update-1494402768378.jpg
Good wet grip is what it says
The White Knight - My Toyota Etios Liva Diesel. EDIT: 50,000 kms update-1494402799950.jpg
saadat1992 is offline   (3) Thanks Reply With Quote
Old 1st June 2017, 07:30   #363
saadat1992's Avatar
Thanked: 293 Times
Quick update:
The car had crossed the 56k & 57k mark last week when I had taken it for a short vacation to Kodaikanal
The White Knight - My Toyota Etios Liva Diesel. EDIT: 50,000 kms update-1496282431844.jpg
saadat1992 is offline   Reply With Quote
Old 1st July 2017, 20:11   #364
Thanked: 126 Times
Your post made me check my coolant level and shocking enough, found them at the low level marking. Wrote to TKM and they promptly called. Will get it done.
Also bro, you should've opted for the Michelins and upgraded to R15s. Missed opportunity!
Old 8th September 2017, 06:44   #365
saadat1992's Avatar
Thanked: 293 Times
An Update after what seems to be an eternity:
The car clocked the 60k mark somewhere this week. I've been away from the forum & the car for quite sometime as my work has me occupied and my driving has come down by 90%.
The White Knight - My Toyota Etios Liva Diesel. EDIT: 50,000 kms update-1504832885854.jpg
Also, the car seemed to have developed a bearing issue in the front left wheel. The bearing is shattered & we're waiting for parts to arrive from Toyota. Apparently, this is a part that doesn't wear off easily & Harsha Toyota doesn't stock up these.
Couple of months ago, a moron in a Fabia rear ended me in a signal at slow speeds. The result: Bumper went in & got impaled in the screws that hold the rear frame. I managed to fix it myself using the good old method of hot water + plunger. Bumper is back in its place but, the screw damage stays.
The White Knight - My Toyota Etios Liva Diesel. EDIT: 50,000 kms update-1504833177544.jpg
The White Knight - My Toyota Etios Liva Diesel. EDIT: 50,000 kms update-1504833201898.jpg
The White Knight - My Toyota Etios Liva Diesel. EDIT: 50,000 kms update-1504833232698.jpg
saadat1992 is offline   (2) Thanks Reply With Quote
Old 22nd May 2018, 17:00   #366
I am Owning a Liva VXD 2017, 25k kms on meter, but i am not happy with the fuel effeciency. I am getting around 17-18 kmpl without A/c on highways and 15-16 kmpl with A/c. Checked with toyota at 10k service they also quoted 15.5kmpl in first turn and around 16.3 kmpl in second. During the 20k service they clocked 25+ kmpl. Thought it might be possible after service FE may get better but still after 5k kms I am not experincing any improvements.
Any leads what can be done for getting a better FE?
ombir.rathee is offline   Reply With Quote
White meets Black, it's Toyota Liva GD Xclusive for me. EDIT: 30,000 km update driving_smartly Long-Term Ownership Reviews 27 10th August 2016 23:30
The Black Knight: Toyota Etios Liva G Inquisitive Test-Drives & Initial Ownership Reports 33 29th August 2015 16:18
Living Tmrrw 2Day - Toyota Etios Liva G - SP Vermilion Red - 10,000 kms nkrishnap Test-Drives & Initial Ownership Reports 184 25th June 2015 18:41
White Knight: Toyota Etios VD 1.4L Diesel. Long Term Review @ 33,000 kms AshBabu Test-Drives & Initial Ownership Reports 6 8th December 2014 21:33
