Old 12th October 2012, 21:21   #61
Eminenttismo's Avatar
Thanked: 315 Times
Default Re: A Solemn Promise - Chevrolet Spark M200 - 41K kms Report
Car's fine and has done 42*** KM. Still didn't change the Engine Oil, may do it a week later.
Bought Motomax Carnauba Wax @ INR200
Motomax Dash Polish @ INR75 in Punnam's Shop.
Will post on their effectiveness later.
Eminenttismo is offline   Reply With Quote
Old 15th October 2012, 19:18   #62
Thanked: 315 Times
Exclamation Electrical Problem
First, I walk towards the car pressing the unlock button, nothing happens. So, I think "Time to change the Remote Battery and Did it promptly"
Next, this night I walk to wards the car and unlock, works perfectly but the RH Rear Indicator does not glow on unlocking. I supposed the bulb must have gone kaput and proceed in the car.
Later on, while I was taking a right turn, I switch the RH turn signal and it glows with a greater frequency. I cross checked it with the LH turn signal which is normal.
While I was driving, the headlamps go off and on suddenly. (Just before this happened, I switched the A/C on)
The Latest changes to the car,
LH Rear Light Assembly Replace, Remote Battery Change.
I checked all the fuses and they are fine, correctly placed.
Has anyone encountered such a situation? If yes, please reply.
Thanks!
Old 19th October 2012, 16:02   #63
ecenandu's Avatar
Thanked: 1,783 Times
Hey, What about the accidental repair? Did you avail insurance. And what about the electrical issue?
ecenandu is offline   Reply With Quote
Old 21st October 2012, 18:15   #64
Thanked: 315 Times
I didn't get the accidental repair done as there was an unfortunate death incident in our family, so we had to have the car with us.
The electrical issue was sorted out. It seems the frequency of the front RH indicator increased due to the non working of rear RH indicator. Once the rear RH indicator was set right(loose wiring), the frequency got normal.
Old 15th February 2013, 12:58   #65
Thanked: 315 Times
Default 46K REPORT: A Solemn Promise - Chevrolet Spark M200
46K KMS REPORT GOES AS FOLLOWS:
I over threw the service by, well, a lot of miles. But I've got it done anyway.
Mobil Super - 5W30 - 3.5L
Castrol Coolant - Water Based - 3L
TVS - Girling - DOT4 - 0.5L
Castrol - ATF Dex II - 0.5L
Purolator Filter - Same as Maruti 800
This was the first time I got my service outside GM Service as my 3Y Promise was completed.Regarding the Engine Oil, I bought all of the above in Vicky.in and got completely confused with Mobil Super and Mobil 1 . Acutally ordered a Bosch Engine Oil Filter, but it wasn't available said vicky, so got a Purolator one. Also, I ordered a Castrol DOT 4 Brake Fluid, but that wasn't available even, so Vicky sent me TVS Girling.
Refer to Post#80 here for experience with Vicky.in (Vicky.in's online automotive store. EDIT : Poor reviews & customer service on Pg.3)
Pictures on the day of Service,
TYRE UPGRADE: 175/60 R13 BS POTENZA GIII
Yes, they are still on 4.5Js. Planning to get alloys ASAP. Anyway, the ride on plain roads is not only nicer, but quieter. Yet when it comes to potholes and all it bangs a little harder. Braking, grip have improved as expected the tires kinda lock the car down to the ground. . I'm still understanding the Steering sensitiveness, which got changed due to wider track I suppose.
Got this little gift for her,
Happy Motoring, Drive Safe, Always wear your Seat Belt
Eminenttismo is offline   (2) Thanks Reply With Quote
Old 21st July 2013, 16:07   #66
Simple_car's Avatar
Thanked: 581 Times
Hi emeinenttismo,
Greetings from a fellow spark owner! This was the car I learnt to drive on.
My long term ownership is up on team bhp. Have a look at it and see if you find it helpful. The car has just crossed 90k kms and is up for service on monday.
Let me know if I can be of any assistance.
Simple_car
Simple_car is offline   (1) Thanks Reply With Quote
Old 1st May 2018, 07:55   #67
virgopal's Avatar
Thanked: 80 Times
Default Re: Tata Motors Spare Parts Pricelist
After A/c gas recharge at A.S.S,my Chevy Spark(2009) A/c Temperature control knob freely rotates and has come off the spindle.
Also is stuck in coldest level and can't select different temps.Needs replacement(along with its control cable).Where can I buy the knob off line/online?..Can I DIY the same? Thanks in advance
virgopal is offline   Reply With Quote
Chevrolet SPARK or Hyundai EON. EDIT- Spark booked ajay_satpute Hatchbacks 69 23rd July 2014 09:34
a Solemn Prayer no_sweat Shifting gears 8 27th January 2011 12:08
GM refreshes Aveo! 5.9- 6.8L. Launches Chevrolet Promise! CrAzY dRiVeR The Indian Car Scene 57 7th April 2010 18:35
Little Spark of Happiness has arrived - Chevrolet Spark LT JRD Test-Drives & Initial Ownership Reports 27 15th November 2008 13:44
