Old 30th March 2014, 00:28   #151
Motoringlover's Avatar
Thanked: 179 Times
Angry Expensive Service Became even more expensive.
This Post is in continuation of the earlier post, after completing the Timing Belt and Water pump jobs, along with a small bearing correction in a fan belt tensioner, what suppose to be a 30K job along with an oil change, I get a call from the garage stating they are hearing metal abrasion noises from the Timing chain side at Mid revvs, well could not risk it, asked them to change that also, overall the total damages os 51K. I am attaching a bill for more details, all work carried in Bosch Service center Delhi.
Please let me know if you have questions, this bill hurt.
Thanks - ML
Motoringlover is offline   Reply With Quote
Old 30th March 2014, 12:32   #152
vnabhi's Avatar
Thanked: 1,315 Times
Default Re: My Precious - RS1 - Skoda Octavia vRS. Now Remapped!
Mama Mia, 51 K !
Pardon my ignorance, but is the timing belt different from the timing chain? You've mentioned that both got changed, hence my question.
Old 31st March 2014, 01:21   #153
Thanked: 179 Times
Originally Posted by vnabhi View Post
Mama Mia, 51 K !
Well this was a learning for me too, the VRS uses a chain and a belt, essentially the opposite side of the infamous timing belt, the noise as reported by the garage started from the chain side of things, the process was long as the chain uses an adjuster which was hard to procure and was the offending article in the procedure - pic attached.
Overall am told now I am good now. My other precautionary approach has been due to the car being remapped, and my love for revving in the mid and highs, that said the car is expensive to maintain from a parts cost perspective, and also is lots of fun too. Trouble with dichotomy, what can I say.
Best - ML
Old 31st March 2014, 09:32   #154
Thanked: 11,037 Times
Timing chain, total rubbish, it has a timing belt, I think the workshop merely used the wrong terminology but he has done the right things
Old 31st March 2014, 15:02   #155
Thanked: 179 Times
May be Ajmat it is called something else, its the opposite side of the Timing Belt, - it did look like a chain, so not sure if the claim is entirely not beleivable.
Please see the bill, it lists details for Timing Belt, Water Pump, Fan belt tensioner and specificly stated Timing chain (Set + Adjuster)
ML
Old 5th April 2014, 20:43   #156
Thanked: 179 Times
Please see the view of the chain and the belt - both have been replaced.
Further work in progress pictures
Best - ML
Motoringlover is offline   (1) Thanks Reply With Quote
Old 7th April 2014, 10:38   #157
Abhi_abarth's Avatar
Thanked: 129 Times
Oh my god ! these service costs are dampening my spirits of owning a octy rs
I am in search of a well maintained car but not sure where I will land up.
: That 50 K is equal to my two home loan EMIs !
Abhi_abarth is offline   Reply With Quote
Old 7th April 2014, 12:48   #158
Thanked: 179 Times
Sad but true Abhi_abharth, the costs to maintain an Octy in top shape will cost you top dollars, but having said that, i still love the car, do expect to maintain it in the same way, it just takes one drive to forget all that.
This may sound like i am trying to make sense with my own head, but here is why, i am listing my major spends.
1. Clutch + flywheel at 63K on the ODO - costed around ~35K - Typical Mileage for a changes, i have seen some go at even 40K on the ODO - i would say driving style and some luck.
2. Remap + BOV+Ignition coils - 65K (Discretionary spend - Could have been avoided) ODO reading 73K
3. Tires - I do not recall exact cost my guess ~30K - I am not sure have to check the ODO i guess around 70K.
4. Timing Kit + Water Pump + timing Chain - 51K ODO stands at ~79K.
So yes expensive, its not going to be equal to Japs for sure, but the pleasure when you get behind the wheel is priceless, even if you do find something which has been maintained well, with time you will need to make investments to keep it in top shape.
Good Luck with your hunt.
Best - ML
Old 16th May 2014, 18:33   #159
Thanked: 179 Times
Default 80K Update
All - Its been a while i updated the thread, RS now has crossed 80K on the ODO what an amazing experience it has been, i have now decided to treat myself with a suspension upgrade, with about 50K budget what upgrade options can i consider, appreciate your feedback.
My Goal is to not lower the car, i am fine with the Stock ride height, but want to consider performance dampers and may be stiffer springs.
If members could suggest options (with cost implications) that will help me make an informed choice.
ML
Old 11th July 2014, 10:19   #160
Cooleo's Avatar
My apologies in advance If I seem to be hijacking your thread but I just came across a 2009 VRS, photos of which are attached for everybody to see & comment upon & help me in making a decision of buying/not buying the car.
Thank you everybody, in advance.
Cooleo is offline   Reply With Quote
Old 11th July 2014, 10:26   #161
Cooleo's Avatar
And here are some more photos.
Old 11th July 2014, 10:28   #162
v&v
v&v's Avatar
Thanked: 1,099 Times
Cooleo, For VRS, check the internals, thats most important.
1. Check the service records
2. When was Timing belt & Water pump changed
3. Scan Electricals,
4. Check working of Headlights - They are expensive
5. Check underbody for Hits
6. VAC system & Glowplugs
7. Brake Pads & Disk
8. Ofcourse tyres - They are damn expensive about 9k per tyre.
9. Sun roof leakeage - Pour water into channel and check for leakage.
10 AC - Cooling coil leakage is common in Octavia
Immediate i can thing of these points. Rest experts can add...
If its a clean car, buy it, you will not regret...
v&v is offline   Reply With Quote
Old 11th July 2014, 15:13   #163
Cooleo's Avatar
Thanks a ton for the heads-up v&v, much appreciated.
That's quite a comprehensive check-list, but hey, nobody's complaining.
Assuming that the car is in decent shape & more or less meets the above check-list, how much do you reckon the car is worth ? Keeping in mind the fact that it's an August 2009 model, with a single/first owner.
Old 14th July 2014, 09:43   #164
Cooleo's Avatar
Hello people?
Any help regarding the approximate purchase price for the VRS would be greatly helpful.
Old 14th July 2014, 09:47   #165
Thanked: 655 Times
Apologies for posting here. I have a black VrS for sale too, KA registered. Indicative selling prices would be great!
jyobeb is offline   Reply With Quote
Skoda Octavia vRS - Dreams do Come true!! ashish22 Test-Drives & Initial Ownership Reports 68 16th August 2013 15:06
Remapped Skoda Octavia 1.9TDi Ricky_63 Modifications & Accessories 125 6th May 2012 10:43
Skoda Octavia II vRS skodaboy The International Automotive Scene 19 7th May 2006 20:17
Hot Skoda Octavia vRS nikibusa The International Automotive Scene 11 21st September 2005 12:58
