Old 2nd November 2013, 12:54   #121
Motoringlover's Avatar
Thanked: 179 Times
Default Re: My Precious - RS1 - Skoda Octavia vRS. Now Remapped!
Originally Posted by v&v View Post
ML Congrats, Was there any specific reason to change the BOV ?
Whats the difference from stock one ?
cheers
Well Vinod - To be honest, I have not been able to make out the difference, in theory it is suppose to be more effective in holding the boost.
I found this in Wikipedia about BOV
http://en.wikipedia.org/wiki/Blowoff_valve
Originally Posted by sameerpb View Post
at what speed you are driving Precious these days to get 13.6 kmpl? Let me know results of BOV upgrade.
Sameer - in the last drive I managed an Average fuel consumption in the range of 6.2L/100 - translates to about 16.1Kmpl, not that I was driving slow, I set the cruise control at 80kmph and it was 6:30 in the morning, the ambient temperature was a big help.
BOV not much difference to be honest, can't make out if it adds value to performance at all.
Best - ML
Motoringlover is online now   Reply With Quote
Old 8th November 2013, 09:48   #122
Thanked: 179 Times
Default Running Repair - Brake Pads, Discs and others
Team - RS went for a change of the essentials.
1. Packing cover - aka valve cover gasket.
2. Oil Dipstick - I broke the older one while checking oil once.
3. Sparg Plug - I wanted to change this while changing the ignition coils, this was not in stock, this was not required to be changed, i do not recall changing this and hence went ahead with the change.
4. Brake Pads - Front
5. Ventilated Brake Discs - Front.
While doing the work was recommended to change Vacuum pipe , part of the preventive maintenance the part is on order.
Attaching the bill for reference. Please let me know if you have specific questions.
My Precious - RS1 - Skoda Octavia vRS. Now Remapped!-skoda-running-repair-nov-2013.jpg
Thanks - ML
Old 9th November 2013, 07:12   #123
Ardy's Avatar
Thanked: 86 Times
Great going, ML.
A quick question on the latest service. What spark plugs have been used as replacements? Aren't they Iridium plugs?
Also, can you post the picture of ventilated discs?
Cheers,
Ardy
Ardy is offline   Reply With Quote
Old 9th November 2013, 07:36   #124
Thanked: 179 Times
Originally Posted by Ardy View Post
Great going, ML. A quick question on the latest service. What spark plugs have been used as replacements? Aren't they Iridium plugs? Also, can you post the picture of ventilated discs? Cheers, Ardy
Hi Ardy - Spoke to Vinu from Petes on this - he recommends all stock ignition coils and stock spark plugs up until stage 2, I will share the picture shortly.
Thanks - ML
Old 9th November 2013, 07:55   #125
Ardy's Avatar
Thanked: 86 Times
Thanks - ML
ML, AFAIK stock spark plugs on RS are iridium. And IIRC, the iridium plugs should be a little more costly and hence the question. Do you have the old spark plugs with you?
Cheers,
Ardy
Old 9th November 2013, 09:04   #126
Thanked: 179 Times
ML, AFAIK stock spark plugs on RS are iridium. And IIRC, the iridium plugs should be a little more costly and hence the question. Do you have the old spark plugs with you? Cheers, Ardy
Mate have the older plugs and the 3 working coil packs. Will upload picture of them too.
Thanks - ML
Old 14th November 2013, 16:55   #127
Thanked: 179 Times
Cheers,
Ardy
Ardy - Here you go with the pics - sorry this update comes late.
Spark Plugs - Old.
Name:  Older Spark Plugs.jpeg
New Spark plug box - don't have the pictures.
Name:  new Spark plug box.jpeg
Older Discs
Name:  Older Discs.jpeg
New Front Discs
Name:  Left Disc New.jpeg
Size:  90.6 KB Name:  Right Disc New.jpeg
Please let me know if you have any further questions.
Thanks - ML
Motoringlover is online now   (2) Thanks Reply With Quote
Old 14th November 2013, 20:30   #128
Ardy's Avatar
Thanked: 86 Times
Thanks - ML
Thanks, ML.
These are conventional spark plugs. I will have to go back and check if I have Iridium spark plugs installed on mine. IIRC, I have iridium, but these pictures have cast doubt in my mind. I remember paying around 500 odd for each, which is what an iridium plug would cost.
Cheers,
Ardy
Old 14th November 2013, 21:15   #129
vnabhi's Avatar
Thanked: 1,317 Times
Can Iridium spark plugs be installed on other cars also? I need to change my Fiesta's spark plugs in its next service,which is next year, hence my question. Will they yield any improvement? If so, where?
OT: @ML--you standard 'please let me know if you have any questions' is missing in your post #126.
Old 15th November 2013, 08:55   #130
Thanked: 179 Times
Originally Posted by vnabhi View Post
Can Iridium spark plugs be installed on other cars also? I need to change my Fiesta's spark plugs in its next service,which is next year, hence my question. Will they yield any improvement? If so, where? OT: @ML--you standard 'please let me know if you have any questions' is missing in your post #126.
Venu Saab - Iridium plugs are high performance spark plugs for setups needing the same, my advice would be to stick to regular once, unless you are going for changes in the cars setup.
I never knew any one would pay attention to "please let me know if you have any questions"
Best - ML
Motoringlover is online now   (1) Thanks Reply With Quote
Old 24th November 2013, 01:17   #131
aravind.anand's Avatar
Thanked: 2,041 Times
Best - ML
Can you elaborate a little more on the part that only high performance setups would need them? I ask this because, I need to understand the gains in case of a stock Fiesta setup, a Fiesta with FFE, and a Fiesta with FFE and K&N Air intakes. How would the iridium plugs help in the above three cases?
aravind.anand is offline   Reply With Quote
Old 24th November 2013, 04:26   #132
Thanked: 179 Times
My advice in the earlier post was based on the idea if you get incremental ( measurable )gain for the incremental investment which you would need to measure over the life of your plugs, I know Vnabhii's car - bone stock and is in great shape. That said I also had a conversation with Petes especially after I remapped my car, the feedback I got was simple - your car does not have that extensive a modifications in the current state - I am running a stage 1 tune and have a after market BOV installed and a green cotton air filter.
I also did preliminary research on the same attached for your reference -
Attached http://spark-plugs.co.uk/index.php/c...ntents.iridium
Again it does not sound that you are making that extensive changes to your fiesta sounds like bolt on, I don't know fiestas to be making a recommendation, your tuner should be able to make a recommendation on the changes your are targeting for. Good luck
ML
Old 26th November 2013, 23:02   #133
Thanked: 179 Times
Love and care -
Spent the day detailing the car, some shots for your ready reference. Cleaning at bright wheels - DLF Phase - 2.
Getting the alloys cleaned.
Interiors cleaned - carpets and seats
Just before the final step.
Almost done.
Back home.
Best - ML.
Old 27th November 2013, 18:57   #134
Love and care -
That's a nicely done Job! May i check how much did this set you back by? Also, any specific reason why you didn't consider the newly opened 3M Car Care outlet in Gurgaon?
Thanks!
tifoso is offline   Reply With Quote
Old 27th November 2013, 21:57   #135
Thanked: 179 Times
Originally Posted by tifoso View Post
That's a nicely done Job! May i check how much did this set you back by? Also, any specific reason why you didn't consider the newly opened 3M Car Care outlet in Gurgaon? Thanks!
I paid 1800 + 100 as tips, I was looking for a low cost solution which I could try include in a monthly routine if possible.
My earlier experience was around 4k which is a bit expensive if you fancy chances for a monthly treat.
Quite frankly I could not find the difference service between the current and he earlier 4k version.
The service included interior dry clean + exterior cleaning. How much is 3M by the way ?
Thanks - ML
Skoda Octavia vRS - Dreams do Come true!! ashish22 Test-Drives & Initial Ownership Reports 68 16th August 2013 15:06
Remapped Skoda Octavia 1.9TDi Ricky_63 Modifications & Accessories 125 6th May 2012 10:43
Skoda Octavia II vRS skodaboy The International Automotive Scene 19 7th May 2006 20:17
Hot Skoda Octavia vRS nikibusa The International Automotive Scene 11 21st September 2005 12:58
