Old 20th January 2014, 09:10   #391
nkg77's Avatar
Thanked: 141 Times
Default re: Petrol Hatch to Diesel Sedan - Fiat Linea - Now Wolfed
Originally Posted by nkrishnap View Post
The issue is back again. I will be raising a complaint with Fiat for this, lets see what they have to say. I guess the seat vendors will be called to look into the issue.
I think this is quite common with Punto/Linea front seat. My Punto's front left seat has the rattle from the day I got the car. For each service they will take the seat out and lubricate it, but the noise returns after a month's use. Now I have decided to live with it as the rattle is very muted and is not heard at all with music on.
nkg77 is offline   Reply With Quote
Old 20th January 2014, 09:19   #392
.anshuman's Avatar
Thanked: 9,045 Times
Note from Moderator: Thread moved to Long Term Reviews on request. Thanks
.anshuman is offline   (1) Thanks Reply With Quote
Old 20th January 2014, 09:19   #393
nkrishnap's Avatar
Thanked: 4,161 Times
Seems like a common issue. I will chase the service center to give me a permanent fix and will not allow them to lubricate it (if this is a stop gap arrangement). Lets see what they come up with. I will update the thread once they provide me any fix other than the lubricating the seat.
nkrishnap is offline   (1) Thanks Reply With Quote
Old 26th January 2014, 13:42   #394
TheTeacher's Avatar
Thanked: 322 Times
Looks like the lube is drying out.
1) Try pure silicone grease
2) Try Super Lube (from the USA)
Google and Amazon are your friends!
TheTeacher is offline   (1) Thanks Reply With Quote
Old 28th January 2014, 19:17   #395
nkrishnap's Avatar
Mileage update:
94th Refill: 521.6 kms - 32.62 liters - 15.99 KMPL (MID 16.4 kmpl) - Average Speed 87 kmph - Rs. 58.76/- per litre from BPCL COCO - Maddur.
95th Refill: 522.9 kms - 29.40 liters - 17.79 KMPL (MID 18.1 kmpl) - Average Speed 42 kmph - Rs. 58.77/- per litre from HPCL - Bellary Main Road.
nkrishnap is offline   Reply With Quote
Old 31st January 2014, 23:16   #396
nkrishnap's Avatar
Visited Madhus on the way back from office for wheel balancing and alignment as the car had done close to 4000 kms and was having a wobble around the speeds of 90 kmph. Took about 30 mins and a 1000 bucks to get the work done. Had to change directions of two tyres and nitrogen refill increased the bill by around 250 bucks.
First a puncture scare
Before Road Force Balancing
After Road Force Balancing
Alignment Report
Old 2nd February 2014, 20:58   #397
nkrishnap's Avatar
A small milestone of 35000 kms on the odo at the start of the day to attend the Teambhp meet.
Customary Pic
Mileage update:
96th Refill: 418.1 kms - 22.63 liters - 18.48 KMPL (MID 18.8 kmpl) - Average Speed 38 kmph - Rs. 59.33/- per litre from BPCL Rajarajeshwarinagar
Old 16th February 2014, 22:04   #398
nkrishnap's Avatar
A two part update mileage and a new issue.
Mileage update:
97th Refill: 402.1 kms - 27.01 liters - 14.89 KMPL (MID 15.2 kmpl) - Average Speed 17 kmph - Rs. 59.38/- per litre from HPCL near CBI Road.
Issue
There is a minor coolant leak which is causing the coolant level to drop very slowly. Its losing around 100 ml or so in a week. Seems like the latch/clamp has gone lose or kaput. Will need to get this fixed.
Old 20th February 2014, 12:24   #399
nkrishnap's Avatar
The car was quite dirty over the past week. I washed the car on Tuesday evening but had no time and energy left for waxing the car. Today morning got up early and did just that.
Products used. Meguairs Tech wax 2.0, Meguairs Alloys Shine, Meguairs Glass Cleaner and Meguairs Tyre Foam.
Petrol Hatch to Diesel Sedan - Fiat Linea - Now Wolfed-img_20140220_100626.jpg
Petrol Hatch to Diesel Sedan - Fiat Linea - Now Wolfed-img_20140220_100711.jpg
Petrol Hatch to Diesel Sedan - Fiat Linea - Now Wolfed-img_20140220_101032.jpg
Petrol Hatch to Diesel Sedan - Fiat Linea - Now Wolfed-img_20140220_101109.jpg
Petrol Hatch to Diesel Sedan - Fiat Linea - Now Wolfed-img_20140220_101233.jpg
Petrol Hatch to Diesel Sedan - Fiat Linea - Now Wolfed-img_20140220_101309.jpg
nkrishnap is offline   (5) Thanks Reply With Quote
Old 23rd February 2014, 14:28   #400
nkrishnap's Avatar
Got the coolant leakage fixed yesterday. The culprits were the lose clamps of the hoses connected to the thermostat valve which needed replacement, the hoses were fine with not sign of cracking or giving away. The cost for fixing this was 670 bucks for two clamps, 2 liters of premix coolant, silicon glue and labour.
The picture for illustration of the location of the clamps.
Old 28th February 2014, 09:45   #401
nkrishnap's Avatar
Breached the 36000 kms mark on the odo a couple of days back.
A customary pic.
Old 5th March 2014, 00:10   #402
nkrishnap's Avatar
Mileage update:
98th Refill: 404.9 kms - 25.13 liters - 16.11 KMPL (MID 16.6 kmpl) - Average Speed 24 kmph - Rs. 60/- per litre from HPCL near CBI Road.
Old 7th March 2014, 21:11   #403
ampere's Avatar
Thanked: 8,758 Times
Mileage update:
May be once in a quarter you should put cumulative mileage stats and over on too of odometer chart. That's a nice way to illustrate how its varying over time.
I tried something similar. Illustrates the stats very nicely.
ampere is offline   (1) Thanks Reply With Quote
Old 5th April 2014, 00:21   #404
arun_josie's Avatar
Thanked: 4,322 Times
Default Re: 34,000 kms in 500 days - A Look Back How Things Have Turned Out With The Ownershi
Issue Driver Seat squeaking issue
Resolution Lubricate the seat rail and tighten the bolts. But appears again after a month or so. Permanent fix not found yet.
Service Center response Co-operative, but no permanent fix found yet.
Are you still facing this issue? I am getting a similar sound from the front passenger seat. Even when I tap the seat from behind, I get this sound. But it doesn't come when this seat is occupied.
arun_josie is offline   Reply With Quote
Old 6th April 2014, 18:03   #405
nkrishnap's Avatar
A few updates after some gap, the odo milestone, mileage, AC Filter Change and a few pics after the car was washed and waxed.
37000 mark
Mileage update:
99th Refill: 350.7 kms - 22.31 liters - 15.72 KMPL (MID 15.6 kmpl) - Average Speed 17 kmph - Rs. 60/- per litre from HPCL near CBI Road.
100th Refill: 290.3 kms - 18.02 liters - 16.11 KMPL (MID 16.3 kmpl) - Average Speed 18 kmph - Rs. 60/- per litre from HPCL near CBI Road.
AC Filter Change
Off late was feeling that the AC cooling was a bit lower and the blower speeds too. Decided to remove the AC filter and check how bad it is. The filter had turned blackish and decided to replace the one which I had stocked from some time.
Petrol Hatch to Diesel Sedan - Fiat Linea - Now Wolfed-ac-filter-old-vs-new.jpg
A few pics after the wash and wax.
Yes, the issue is still present, haven't had time to visit the service center. A couple of appointments made and cancelled. I guess the sound which you are mentioning would be taken care with the anti-rust/lube spray. In my car, the seat rails has an issue.
FIAT Linea T-Jet: 1.4L Turbo Petrol. EDIT: Now launched sidindica The Indian Car Scene 669 18th October 2010 21:09
Which car to buy? Heart says Baleno, but mind says Diesel hatch/sedan fieroid Sedans 55 20th May 2009 14:01
