Old 18th July 2016, 09:18   #526
nkrishnap's Avatar
Thanked: 4,434 Times
Default Re: Petrol Hatch to Diesel Sedan - Fiat Linea - Now Wolfed
Got the puddle lights installed and the LED lights in the boot. With increased travel at night and to the forests meant I need this additional lights when getting out of the car.
PS: Kindly excuse the picture quality, they were shot with mobile in low light conditions
Puddle lights
LED Lights in the boot
Got the dash-cam hardwired too with a dedicated cigarette lighter Port and Charger. Puddle lamps, LED boot light and dash cam hard wiring with charger point and charger cost me 3,300 bucks in total.
Mileage Update
Another 780 kms to go to complete 10,000 kms post remap.
nkrishnap is offline   (4) Thanks Reply With Quote
Old 19th July 2016, 02:46   #527
GrammarNazi's Avatar
Thanked: 1,667 Times
Well kept car that! Also thanks for an insightful thread !
Those are some good lights. Did the ECU throw up any errors ?
If possible I need to know where I can get them done because my Linea's boot light went kaput & the Fiat ASC wants me to change the setup for ~3500.
P.S. : Also wanted to upgrade the headlights, any suggestions on that would be great because I guess many suggest a relay kit. (Alternatively I'm also considering an LED bar, but that could look tacky & guess it'd be overkill).
I've even recently up'd the Battery to a 60 DIN unit as a precaution.
GrammarNazi is offline   Reply With Quote
Old 27th July 2016, 09:24   #528
nkrishnap's Avatar
Originally Posted by GrammarNazi View Post
Thank you and glad that the documentation is of help.
No, this is independent of the BCM. So no error lights throw up for the door lights. These lights are wired up to the Door sensor/interior lights.
The switch/sensor is located in the boot lock. Its the same with both Punto and Linea. Even Crazy Driver's Punto is having the same issue. Alternate solution is to bypass the boot switch and install a LED light. I will PM you the details along my phone number.
I am running my car with the relay kit for about 2+ years now. One fused bulb apart from that no other issues. Works as expected. You can as well install the relay kit and save some money. LED bar would surely look tacky. Even the stock battery would be OK, but 60 DIN does no harm.
Old 28th August 2016, 23:30   #529
nkrishnap's Avatar
Over the past month or so it was pretty hectic with the work at office. Had no time to clean the car and it had become pretty dirty. Cleaned the car exteriors using a rinse-less wash and diluted APC to clean the interiors.
Few exterior pics (kindly excuse me for mobile quality pics). Interiors need a bit of dressing and will post those pics in a day or two.
nkrishnap is offline   (5) Thanks Reply With Quote
Old 19th September 2016, 09:51   #530
nkrishnap's Avatar
Linea has now crossed 4 years on the 5th September 2016.
1. Insurance renewed - Premium INR 10,662/- for an IDV of 4.8 Lakhs
2. Completed 10K kms post the remap
3. Crossed the 69,000 mark on the Odo.
Milestone
Got the wheel alignment done at Madhus as the vehicle was pulling slightly to the left. The rear toe is still off though the total values are within range. Will get that fixed back to the factory specifications on the next trip to True Sai.
Any center which fixes the rear toe in Bangalore?
Before and After Readings
nkrishnap is offline   (1) Thanks Reply With Quote
Old 30th October 2016, 09:50   #531
nkrishnap's Avatar
Had a minor accident when I rear ended another car around 20 kmph, thanks to lack of concentration and sudden braking from the car ahead. Luckily very little damage on the car ahead and the gentleman said "Don't worry these things happen and drove off"
Damage
Petrol Hatch to Diesel Sedan - Fiat Linea - Now Wolfed-broken-lower-grill.jpg
Petrol Hatch to Diesel Sedan - Fiat Linea - Now Wolfed-broken-upper-grill.jpg
Picked up the Lower Grill from Aadya Motors and gave the car to Trend Automobiles to have these fixed.
New Lower Grill
Upper grill clamps fixed by welding. It now feels stronger than the OEM ones.
Bonnet tinkered and repainted - Note, I asked the Trend guys not to polish the bonnet post the sanding and Rubbing. I will be detailing it in the next few days.
High beam bulb on the Left headlamps had conked. I had the upgraded the bulbs to night breaker plus a little over 3 years back. Link (Petrol Hatch to Diesel Sedan - Fiat Linea - Now Wolfed). Replaced these with the Osram night breaker unlimited for the high beams which cost me 1650 bucks.
Petrol Hatch to Diesel Sedan - Fiat Linea - Now Wolfed-osram-night-breaker-unlimited.jpg
Petrol Hatch to Diesel Sedan - Fiat Linea - Now Wolfed-new-high-beam-bulbs-parking-lights.jpg
Swapped the parking light bulbs with the Palio ones as I had put the LED ones in the Palio. This one now looks whitish
Petrol Hatch to Diesel Sedan - Fiat Linea - Now Wolfed-new-parking-light.jpg
Old one looks yellowish
Petrol Hatch to Diesel Sedan - Fiat Linea - Now Wolfed-old-parking-light.jpg
Mileage Update
PS: Kindly excuse about the Picture quality. Mobile camera couple with shaky hands
Old 6th November 2016, 20:49   #532
nkrishnap's Avatar
Finally went ahead and got the ICE set up converted to active and rewired the full setup. Got the tweeters on the A pillar as it was placed in the door pads earlier.
Got the front doors re-dampened as the old one was almost end of its life.
Doors Dampened
Wiring getting packed neatly
Tweeter Location
Now, the fiddling with the settings begin to get it to my liking
Old 9th November 2016, 09:08   #533
nkrishnap's Avatar
Post the ICE wiring update, the car interiors were a bit dirty. Thoroughly vacuum cleaned the car and the boot.
Battery terminals required a bit of attention as there were signs of mineral deposits. Cleaned it and mounted the terminals back.
Petrol Hatch to Diesel Sedan - Fiat Linea - Now Wolfed-battery-terminals.jpg
Wanted to clean the AC ducts with minimal effort. Removed the AC filter and sprayed the 3M AC Cleaner Spray into the ducts and let it evaporate for about 15 mins and put a new AC Filter.
AC Filter - Old Vs New: 28xx kms
Changed the air filter as it would have been dirty by now. Thanks to the clean city Bangalore has become
Air Filter- Old Vs New
Old 11th November 2016, 13:03   #534
Thanked: 134 Times
Wow. Your Linea is sure under a lot of TLC. I must say it looks smashing.
Though I have sold my Linea she will be dear to my heart as one of the best rides ever in all the cars that I have owned. 6.5 years of ownership and never has it left me stranded or given any trouble (except the AC evaporator coil replacement under warranty). Had to sell it off as electricals and some parts were failing and getting very difficult to source in Mumbai plus lack of time available.
Enjoy your time with your Linea
Palio_2005 is offline   Reply With Quote
Old 15th November 2016, 19:13   #535
TheTeacher's Avatar
Thanked: 324 Times
Krishna, where is the promised write-up on the remap :(
TheTeacher is offline   Reply With Quote
Old 15th November 2016, 21:08   #536
nkrishnap's Avatar
Thanks. Just did a 934 kms drive over the past weekend. Will post details shortly.
Yet to compile it. Should be possible during the Christmas holidays as I am pretty tied up till then.
Old 24th November 2016, 22:37   #537
nkrishnap's Avatar
Crossed the 70,000 kms mark during the trip to Kudremukh.
On the way to Kalasa, somewhere near Hirebylu
Linea basking in Early morning sunshine
A couple of drives through the Kudremukh roads on two consecutive days.
Day 1
Day 2
How misty it was
Near Hotel Ganesh - Agumbe
Will post a travelogue over the weekend.
nkrishnap is offline   (2) Thanks Reply With Quote
Old 25th December 2016, 19:58   #538
nkrishnap's Avatar
Yesterday while driving back home, one of the roots horn conked after serving for a good 4 years. It was time to replace it. Bought the Hella Twin Tone horn and fit this today morning.
Petrol Hatch to Diesel Sedan - Fiat Linea - Now Wolfed-img_20161224_195815_01.jpg
Open up the top bolts of the bumper (5 in number) to losen the up part of the bumper and the 4 screws to remove the upper grill.
Petrol Hatch to Diesel Sedan - Fiat Linea - Now Wolfed-img_20161225_072904.jpg
Upper Grill removed
Petrol Hatch to Diesel Sedan - Fiat Linea - Now Wolfed-img_20161225_073301.jpg
Horn put in place
Petrol Hatch to Diesel Sedan - Fiat Linea - Now Wolfed-img_20161225_080415.jpg
Gave the car a thorough wash and it took a good 3 hours to finish the job.
Petrol Hatch to Diesel Sedan - Fiat Linea - Now Wolfed-img_20161225_101621.jpg
Petrol Hatch to Diesel Sedan - Fiat Linea - Now Wolfed-img_20161225_101631.jpg
Petrol Hatch to Diesel Sedan - Fiat Linea - Now Wolfed-img_20161225_101728.jpg
Petrol Hatch to Diesel Sedan - Fiat Linea - Now Wolfed-img_20161225_101750.jpg
Petrol Hatch to Diesel Sedan - Fiat Linea - Now Wolfed-img_20161225_101819.jpg
Petrol Hatch to Diesel Sedan - Fiat Linea - Now Wolfed-img_20161225_101843.jpg
Planning to add the Xado engine oil additive in the next oil change. Hearing a lot of good things about this one. Any inputs on the this is most welcome. Only grouse is it costs 3000 bucks for 225 ml.
Petrol Hatch to Diesel Sedan - Fiat Linea - Now Wolfed-img_20161224_112039.jpg
nkrishnap is offline   Reply With Quote
Old 30th January 2017, 23:01   #539
nkrishnap's Avatar
An update after a month.
72000 and 73000 kms mark completed thanks to a couple trips to Nagarahole Forests.
Got the wheel balancing and alignment done at Madhus, was done in 30 mins flat.
Turbo hose had a slit which I could manage to spot. Got it changed.
Feb will a busy month with multiple travels, should cover a good 1500 to 2000 kms. The car is munching miles as good as it when new. One small rattle has cropped in near the glove-box which I will try and fix it over the weekend. Tyres look good for another 18-20K kms.
Old 5th February 2017, 22:34   #540
nkrishnap's Avatar
Finally tool the Plunge and got the projectors bulbs installed. Got the Morimotto Mini D2S set up for the low beams.
Petrol Hatch to Diesel Sedan - Fiat Linea - Now Wolfed-reflectors-opened.jpg
Petrol Hatch to Diesel Sedan - Fiat Linea - Now Wolfed-initial-look-before-alignment.jpg
Petrol Hatch to Diesel Sedan - Fiat Linea - Now Wolfed-projectors-aligned.jpg
Puddle Lights on the mirror. It works in tandem with the interior lights.
Got the LED arrow lights for the ORVM
Petrol Hatch to Diesel Sedan - Fiat Linea - Now Wolfed-side-mirror-indicator.jpg
Got the clutch Plates (New Type released sometime mid 2016), Master Cylinder and Slave Cylinder replaced. The bite from the clutch is way way better now.
New Type
Petrol Hatch to Diesel Sedan - Fiat Linea - Now Wolfed-new-type-clutch-plate.jpg
Old Type
nkrishnap is offline   (6) Thanks Reply With Quote
FIAT Linea T-Jet: 1.4L Turbo Petrol. EDIT: Now launched sidindica The Indian Car Scene 669 18th October 2010 21:09
Which car to buy? Heart says Baleno, but mind says Diesel hatch/sedan fieroid Sedans 55 20th May 2009 14:01
