Old 17th April 2013, 16:20   #16
Thanked: 13,343 Times
Default Re: Maruti Swift VDi Ownership Report - 50,000 kms clocked
Originally Posted by naveen.raju View Post
Guys, lately I have been experiencing a low mileage. I used to get a constant figure of about 15-16kmpl in city but now dropped to 12-13kmpl during the last few refills. What needs to be checked? Topped the engine oil recently. Car has now clocked around 53k kms.
It could be clogged injectors or bad fuel. How does the air filter look? If its too dark then it not doing its job fully.
Anurag.
a4anurag is online now   (1) Thanks Reply With Quote
Old 17th April 2013, 16:24   #17
naveen.raju's Avatar
Thanked: 3,129 Times
Anurag.
Didnt check the air filter. Have to do so. I think it's time for a change. Was waiting for the car to clock 60k kms so that I can give it for service.
naveen.raju is offline   Reply With Quote
Old 17th April 2013, 20:11   #18
When as was it you changed the air filter last? At 50k kms?
I change every 5000kms.
Anurag.
a4anurag is online now   Reply With Quote
Old 17th April 2013, 23:31   #19
deetjohn's Avatar
Thanked: 7,378 Times
If the air filter is clogged, the engine response will be affected to a very noticeable degree. How is the clutch?
deetjohn is offline   Reply With Quote
Old 18th April 2013, 10:50   #20
Anurag.
It was changed during the 40k km service. So it's been almost 12k kms with the same air filter.
Clutch isnt all that bad. Didnt notice any difference. BTW, how much kms you get for 500/- diesel topup? My average is around 150-160 sometimes 180kms.
Old 18th April 2013, 16:51   #21
Ah! 12K Kms on one air filter is not good buddy!
Change it ASAP! But when you give it for 60k Kms service get it clear to them as to not change the air filter.
Anurag.
Old 18th April 2013, 23:01   #22
deetjohn's Avatar
I always tank up. But that average sounds just about right. 16ish is what I get from a tank when I enjoy the car. i.e. constantly in the power band. And If I am careful and make it a point to always shift up at 2K RPM, I get 18+ on a tank.
I hope you clean the air filter from time to time. Our dusty conditions clog the filter very fast.
deetjohn is offline   (1) Thanks Reply With Quote
Old 19th April 2013, 09:40   #23
Anurag.
Planning to get this changed asap. Thanks for your thoughts
I sometimes manage to squeeze around 200kms for a 500/- fill but the average is around 150-160. But now dropped to around 120-140kms. Shall change the air filter soon. I guess this might improve it. Planning to check the filter this week to see it's condition.
Old 28th April 2013, 14:02   #24
Changed the air filter. After using the previous filter for almost 12k, it was black in color. Felt immediate improvement in the pickup. Have to check whether this improves the FE. Also checked the fluids and cleaned the battery terminals.
Expense - 410 including labor.
Old 28th April 2013, 15:58   #25
DieselLover's Avatar
Thanked: 86 Times
Excellent thread naveen. Missed it some how till this day. Being a fellow swift owner who bought the car around the same time as you (July 2009,64k kms on odo) I can relate to lot of points you have highlighted here.
1. Suspension is problematic even though I am using 185/70/R 14 tyres. replaced multiple times under warranty.
2. Rattles: as bad as it can get. Multiple sounds coming from dashboard like you mentioned. Driving without music is not adviced
3. FE seems to have reduced little bit after 55k though the air filter is less than 10k old. should I get injectors checked?
4. Cost of service: used to do it every 5k but stopped it off late. 10k services are expensive and 20k services costs a bomb. 60K cost me 8k. Quality of service seems to be declining also.
Engine and performance : this is what keeps me going. Still brings a smile every time I hit the highway.
DieselLover is offline   Reply With Quote
Old 28th April 2013, 17:18   #26
How do you find the throttle response to be while accelerating? Have you got the injector cleaned any time in your ownership time?
If not get them cleaned once when you go for the next service.
Services are costing a bomb now a days. Specially the 20K, 40K, 60K, 80K and so on the even number ones. In the even number service most of the fluids in the car are changed and added fresh and the filters too which in turn raises the bill. Sometimes the brake pads are changed even if there is still life in them. Maruti says its preventive measure for customer safety.
But the odd number services pertain to mostly oil change and air filter with any brake cleaning if necessary.
Cheers,
Anurag.
Old 28th April 2013, 21:35   #27
Thanked: 86 Times
Cheers,
Anurag.
Throttle response is good. but I have never done injector cleaning before. any idea how much it costs?
Old 29th April 2013, 09:50   #28
So guess all these problems are common among other Swift owners. I havent cleaned the injectors. Planning to do it when I give it for 60k kms service. Even I stopped servicing every 5k kms. Changed the engine oil few thousand kms back, and now got a new air filter. So it's 60k kms service next time.
Even though the labor is priced on the higher side, they seem to be doing a good job. Especially where I go. Might be because I had forwarded a complaint against a SA and he was properly dealt with by the MASS. He is really active now and does an excellent job. I make sure I contact him for any small issues. I just asked for a filter change yesterday but he made sure that all fluids are within limits. He even topped some fluids for free. And for any minor issues or fixes, it's always best to go on Sun. You get proper attention and the place will be free.
Rattles are still there even though they rectified during the last service.
naveen.raju is offline   (1) Thanks Reply With Quote
Old 11th May 2013, 14:52   #29
Thanked: 86 Times
naveen, you drive a vento diesel also right? Why don't you post a comparison between the two somewhere? It will be very useful for folks like me who is contemplating an upgrade from swift.
Old 12th May 2013, 08:13   #30
I had actually posted a small comparison in some thread long time back. Moreover, Vento is no longer here. Verna AT replaced it.
My Red Cherry - Maruti Swift VDI: 120,000+ kms up DieselFan Long-Term Ownership Reviews 177 20th June 2017 12:10
Long Term Ownership Report: Swift VdI- 2 lakh kms, Cost of ownership on Pg 3 epicenter.rulez Long-Term Ownership Reviews 150 30th May 2017 20:35
Swift Diesel.Vdi - Ownership report.Facing problems -Maruti refuses to honor warranty Mevtec Test-Drives & Initial Ownership Reports 97 7th October 2013 15:02
Baleno 50000 Km in 3 Years 2 Months - Review (Now clocked 50,000 kms) BlackPearl Long-Term Ownership Reviews 131 15th February 2009 12:01
Scorpio mHawk 5000 kms clocked.... lingadalli Test-Drives & Initial Ownership Reports 26 15th March 2008 11:17
