Old 21st October 2014, 12:11   #46
DWind's Avatar
Thanked: 170 Times
Default Re: Hyundai Verna CRDI - 100,000 Kms and Beyond
Hope the slave cylinder was also changed with master cylinder.
Sorry for the delay. From what I recollect only the Master cylinder was changed and clutch fluid bled. In fact when I had this issue the gears refused to slot and I had to drive the car in second gear to the service center.
DWind is online now   Reply With Quote
Old 21st October 2014, 12:38   #47
Thanked: 41 Times
Glad to know the problem is resolved.
Suggest you to change the water + coolant solution.
From what you have explained, I assume, car is running on coolant only.
All the water would have evaporated due to the excess heat generated while running with a non functional radiator fan.
Yes sure. After detecting the issue of low coolant level, I had topped it up using water only. Not sure whether the workshop guys added coolant on top of that, once they were done with the fan replacement. Will check with them and add coolant, if required. Thanks for that heads-up kpzen !
vivekkr_99 is offline   Reply With Quote
My Predator - Ebony Black Hyundai Verna CRDI SX ABS - 100,000 kms update on pg 15 predatorwheelz Long-Term Ownership Reviews 248 12th September 2016 08:23
Tata Indica DLX - 150,000 kms & beyond AutoIndian Long-Term Ownership Reviews 355 23rd November 2015 15:33
My Beige Boy - Hyundai i20 Asta CRDi. Update: 60,000 kms and 4.5 years sagarpadaki Long-Term Ownership Reviews 108 17th January 2015 11:04
Hyundai Verna CRDI ABS -80,000 kms report (Is it worth the Hype) pjegadeesh Long-Term Ownership Reviews 36 10th August 2010 14:15
Verna CRDI (ABS) 30,000 Kms report on problems sag_kv Long-Term Ownership Reviews 24 11th March 2010 22:46
