Old 16th April 2007, 11:35   #196 (permalink)
Steeroid's Avatar
Update & Notice to Dicor owners
- vehicle has gone in for 30k Service. Fuel Filter (Diesel Filter) assembly will be REPLACED and it Costs Rs.7,400/-. My friend says it is some kind of two-piece assembly consisting of a filter and an electronic sensor.
MODS PLEASE UPDATE TITLE TO 30,000 KMS.
__________________
Steer
The Land is in the past, now where do I find the 6-cylinder Ponton?
Steeroid is offline   Reply With Quote
Old 16th April 2007, 11:43   #197 (permalink)
suman's Avatar
Originally Posted by Steeroid View Post
Fuel Filter (Diesel Filter) assembly will be REPLACED and it Costs Dhs.7,400/-. My friend says it some kind of two-piece assembly consisting of a filter and an electronic sensor.
I'm sure you meant INR 7,400
__________________
Land's end, journey's beginning - Safari Dicor VX 3.0L 4x4
Old 16th April 2007, 11:46   #198 (permalink)
Steeroid's Avatar
Thanks Suman. Corrected now.
__________________
Steer
Old 16th April 2007, 11:46   #199 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Dhs, or Rs.?
Assembly replaced.
I change indica's diesel filters every 10-15K kms, but never had to change the assembly even once.
If possible take a second opinion. Most Tata workshops try to make money by replacing things which need not be replaced.
Case in point, the car missing due to air in the lines.
From this forum, and on the web I found out that the cause is some air. The reason could be Leaking hand primer.
The workshop service advisor kept on insisting that it requires a fuel pump overhaul(7K party for them).
I inspected the engine bay and showed them the leaking hand primer.
__________________
Reclaiming.....!
Old 16th April 2007, 11:53   #200 (permalink)
Godfather's Avatar
what is that??? hand primer...
Godfather
__________________
I accidentally installed the deer whistles on my car backwards. Now everywhere I go, I'm chased by a herd of deer.
Godfather is offline   Reply With Quote
Old 16th April 2007, 11:56   #201 (permalink)
Team-BHP Moderator
Rtech's Avatar
The lil handle there which you pump to prime the fuel pump incase you run dry.
P.s. A diesel fuel filter costs Rs.7,400? Maybe you mean the fuel pump instead?
Old 16th April 2007, 12:07   #202 (permalink)
Steeroid's Avatar
Nope - I had been forewarned about this by some friends and some TBHPians as well. Apparently its the biggest expense for the 30k service.
This filter must be special in some way - its the only one I've seen that collects kerosene from adultrated diesel, and cuts the engine once its full and cannot filter anymore.
v1p3r and veyron1 were with me in Cochin when this happened once - we drove to the Dealership where the guy stuck his hand into the right wheelwell, moved a flap and unscrewed the sensor first before removing the filter itself. When he took it out it was filled with kerosene and water.
__________________
Steer
Old 16th April 2007, 15:28   #203 (permalink)
Ahh..this bliss of owning a Safari...Please take the whole parts price catalogue so that you can make early budget planning on 60,000 kms servicing and after warranty maintanance.
There is a old ode by Safari owners down here from long(1998-present) i will PM that to you.
Desert fox is offline   Reply With Quote
Old 16th April 2007, 17:03   #204 (permalink)
Team-BHP Moderator
tsk1979's Avatar
I am doing flip flop between safari and no safari right now.
Every time we see one, we want one, every time my indica alternator fails, we don't want one.
Guess the state of indica's alternator during the time when we actually make the purchase(May-june) will decide whether its a safari or a Hyundai.
Anyways steer, if you could make a list of all the services/repairs and charges till now, it will be great for budget planning.
__________________
Reclaiming.....!
Old 16th April 2007, 17:28   #205 (permalink)
Steeroid's Avatar
Its all on this thread. Check each service update for costs. Only other recent cost has been for painting one whole side after some moron in Bangalore ran a key or nail through the entire RHS. I mean the entire side - front to rear.
__________________
Steer
Old 16th April 2007, 17:42   #206 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Ok, will do, but it means going through hundreds of posts!!
And as for the Nail.. Welcome to the club!
Waiting for your detailed service report.
__________________
Reclaiming.....!
Old 18th April 2007, 09:43   #207 (permalink)
Originally Posted by testdrive View Post
I recently (Feb 4th,2007) bought a Tata Safari from Dhingra Motors, Gurgaon. I have done 1300Kms so far.
Problems so far:
(a) Engine oil is leaking (i can see oil drops under the engine where the vehicle is parked). Took the vehicle for repairs. The oil drain nut was tightened, but the problem still persists.
(b) On quick acceleration the vehicle leaves lot of black smoke. As per the service advisor, this is because the engine is not able to burn the increased amount of diesel pumped into the engine on acceleration. I'm not sure whether I should accept his explanation, as I used to own a Bolero before and did not face this problem.
Any thoughts/comments are most welcomed... Thanks!
I just happened to read this. I did not see any follow up threads talking about whether you managed to have this sorted out.
Did you pick up a used Safari or a new one? Is it a DiCor or the IDi-turbo? The problems seems like 'Back Compression', something that happens to ageing IDI diesel engines, and not one that we'd expect from a brand new vehicle. I had this problem with my MM540. check if the oil is leaking from the sump or from the space between the cylinder block and everything else - clutch bell housing/ transmission, etc.
__________________
2005 Baleno LXi
2006 Marina TDi
wizardofid is offline   Reply With Quote
Old 18th April 2007, 09:52   #208 (permalink)
pogusingh's Avatar
One more request in for the detailed service report
-POGU
pogusingh is offline   Reply With Quote
Old 18th April 2007, 11:11   #209 (permalink)
Steeroid's Avatar
Check this post for costs till date:
http://www.team-bhp.com/forum/295912-post134.html (Tata Safari Dicor updated to 50000km)
__________________
Steer
Old 18th April 2007, 11:25   #210 (permalink)
condor's Avatar
Every time we see one, we want one, every time my indica alternator fails, we don't want one..
TSK, go for it .. The Safari has such a road presence - such a sight to see it go past you gracefully.
Is it the same alternator on the Safari that's there on the Indica ?
__________________
Life is Analog. Digital is an approximation.
Thread Tools
New Tata Safari Dicor 2.2L released! Samurai The Indian Car Scene!! 155 7th October 2007 00:56
On buying Tata Safari Dicor now adc SUVs, MUVs & 4x4s 45 1st October 2007 16:46
TATA safari TCIC or the DICOR maheepgupta SUVs, MUVs & 4x4s 24 12th September 2007 11:29
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
