Old 19th January 2006, 09:41   #46 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Gypsy had the same thing, 4H was on the fly because there was no locking but for 4L you had to stop and then do it. But it was like a manual gearshift and no reverse business was required.
__________________
Old 19th January 2006, 09:50   #47 (permalink)
Steeroid's Avatar
Hmmm there's no manual shift here and you can shift IN to 4L on the fly. The reverse business to get OUT of 4L is their 'recommended practice' so I follow it all the time.
__________________
Steer
Where all think alike, no one really thinks very much.
Steeroid is offline   Reply With Quote
Old 19th January 2006, 09:55   #48 (permalink)
RedOne's Avatar
Electronic transfer case, as available in the Safari, usually does not require the stop & reverse routine, but yes, on older 4WD systems reversing would be to unlock the diff. Reversing after shifting out of 4L would release the wind-up stress on the diff and gearbox.
You could check with TATA (if you find someone knowledgeble) on locking diffs and driving in 4H on tarmac, just to be safe.
Gears,
Red-One.
RedOne is offline   Reply With Quote
Old 19th January 2006, 10:07   #49 (permalink)
Team-BHP Moderator
tsk1979's Avatar
I guess 4L locks the diffs. In gypsy once I got stuck in 4H. The front right and rear left wheel started spinning as they had no traction. So I shifted into 4L, and bingo, she crawled out with not difficulty. In older gypsy's you had to get out and do some manual thing with the hubs. Newer gypsy's do away with this nonsense.
Safari has limited slip diffrential, so even if your one wheen completely loses traction, still the other wheel will be given rotations.
__________________
Old 19th January 2006, 12:56   #50 (permalink)
Super-Admin
Actually, the system of older gypsies is better as they give you a choice.
The manual thing you are referring to is "locking" the free wheeling hubs and thereby "engaging" the front axle only when required for 4x4 mode.
Due to the lack of free-wheeling hubs in the newer gypsies, the front axle is working full time, whether they are being used for 4x4 or not. My Jeep has free-wheeling hubs too.
__________________
Self-imposed limits are the only type that exist. Break them....then, make it a habit. Exceed.
  • Please don't PM for support. Use the Contact Form instead.
  • Please read the *NEW* Team-BHP FAQ section for all your queries.
Old 19th January 2006, 16:23   #51 (permalink)
adityapd's Avatar
Originally Posted by pioneer
According to me the old Safari looks much better than the Dicor. I have also heard from my friend that Scorpio's CRDe engine is much more responsive and drivable than the Dicor's.
how about getting a old safari at dirt cheap rates ( 1.5 to 2.0 L) and plonking in a scorpio CRDe engine and gearbox in it to have the best of both the worlds ? Any views on the feasibility of this option ?
~A
adityapd is offline   Reply With Quote
Old 19th January 2006, 18:21   #52 (permalink)
v1p3r's Avatar
Try finding a Scorpio CRDe engine... you will also need the complete wiring harness and ECM. If you can find this, and someone to mate it, then you are set for the ultimate Indian SUV!
__________________
Peace is a lie, there is only passion.
Old 19th January 2006, 20:33   #53 (permalink)
kpzen's Avatar
Both Mahindra and Tata are there with diesel engine technology from long time but Wonder how mahindra is able to produce great diesel engines whereas tata struggle in this department..
__________________
Prajesh - << will be offline till August >>
A true friend is someone who says nice things behind your back...
kpzen is online now   Reply With Quote
Old 20th January 2006, 08:35   #54 (permalink)
adityapd's Avatar
exactly my thought...and wonder how mahindras struggle endlessly in the handling and high speed stability department where the Tatas seem to have an upper hand !!!
~A
Old 20th January 2006, 14:35   #55 (permalink)
Steeroid's Avatar
Mahindra has produced ONE diesel engine and modified a couple of others, all with help from AVL and others.
Please remember that the Tata range of Diesels is not restricted to the Safari or the Indica. They have developed - either by themselves as in the legendary 407 or even the original 207 or with help from Cummins or other diesel specialists - a whole range of engines from small capacity HSDs for passenger cars to large load-carriers and even the Tata-Hitachi range of earthmovers.
While I agree that the Scorpio engine is a gem, it would be wrong to draw the conclusion as you have that Mahindra produces great diesel engines.
For the record, let us look at two turbocharged engines from Tata w.r.t their nearest competition:
Old Tata Safari Diesel 1948cc 90ps @ 4300 rpm 190nm @ 2000~3000rpm
(483 DL Turbo engine)
GVWeight 2690 kg
Old Mahindra Scorpio 2609cc 109bhp @3800rpm 255 nm @ 1800 rpm
GV weight 1910 kg
Another comparable engine (in terms of size)
Skoda Octavia 1.9 tdi 1896cc 90bhp @ 4000 rpm 210nm @ 1900 rpm
When compared to the Scorpio, an engine that was 33% bigger produced about 21% more power and 33% more torque.
When compared to the Skoda, the engine is pretty much par of the course
What really made the difference was also that the vehicle with the smaller engine was ALSO 40% heavier (4x4).....I'd say the old engine was pretty competent for its size....
Now when we come to Common Rails, it is another story altogether....the Dicor engine does NO justice to its size when it comes to BHP figures, though Torque is massive (no biggie since it is directly proportionate to cc).
Compare smaller diesels...the Tata 1.4 litre NA engine compared to the best known small capacity foreign diesel, the Peuguot TUD5:
Indica V2 DL 1405cc 53bhp @ 5000 rpm 85 nm @ 2500 rpm
Peuguot TUD5 1517cc 57bhp @ 5000 rpm 96nm @ 2600 rpm
Esteem/Zen D
Palio 1.9 D 1910cc 63bhp @ 4500 rpm 120nm @ 2500 rpm
The homegrown Indica engine was right up there with the slightly bigger Peuguot engine and though the Fiat engine was 25% bigger it only pumped out about 16% more peak power though torque was 29% more. This, despite the TATA engine being extremely FRUGAL - which is quite an achievement.
The addition of a turbocharger to the Indica meant that it now matches (actually both power and torque are about 8-9% more) the output of an engine thats 25% larger. Compare these with figures for the older 1.7 litre Turbo engine of the Siena and things fall into perspective.
You can do similar comparisons for other engines...Sumo(N.A) v/s Bolero v/s MM550 v/s Qualis, for instance:
1948cc/67bhp@4500/12kgm@2500 v/s 2498cc/72bhp@4000/15.5kgm@2000 v/s 2112cc/62bhp@4500/12.3kgm@2000 v/s
2446cc/75bhp@4200/15.4kgm@2400
Let us therefore not jump to conclusions, then.
__________________
Steer
Old 20th January 2006, 14:50   #56 (permalink)
Team-BHP Moderator
Rtech's Avatar
All that looks great on paper Steer, but that Indica engine is nasty, plain and simple. It is by far the worst engine I have ever experienced in an automobile!
I haven't driven the turbo'd one, but I'm not exactly holding my breath either.
__________________
He who makes the loudest noise usually has the least to say. Unfortunately they don't realise that and keep at it!
____
Old 20th January 2006, 15:05   #57 (permalink)
Steeroid's Avatar
Meant for a purpose, serves that purpose. About 10,000 people think so every month.
Please do - you wont catch the plague...
__________________
Steer
Old 20th January 2006, 15:06   #58 (permalink)
adityapd's Avatar
u've pretty much hit the nail on the head steeroid...the weight is the biggest culprit of the safari...both old as well as the Dicor ..( didn't know that the 4X4 was so heavy as to tip the scales at a massive 2.7 Tons)
This excessive bulk surely did contribute in a way as a damper to improve the ride quality over those bone jarring pot holes.
Wonder how other SUVs like the scorpio and the endeavour ,etc have managed to tip the scales on a lighter side in comparison to the safari...
A 80 / 20 ( paretto) analysis of the main factors contributing to the safaris weight would give some good pointers to the Tata engineers to trim that extra flab and make a the safari a more nimble beast...
~A
Old 20th January 2006, 15:17   #59 (permalink)
Steeroid's Avatar
Originally Posted by adityapd
A 80 / 20 ( paretto) analysis of the main factors contributing to the safaris weight would give some good pointers to the Tata engineers to trim that extra flab and make a the safari a more nimble beast...~A
If someone can give me a carbon fibre/other composite bonnet, doors, fenders and a tailgate I figure we could get the weight down to Scorpio levels.
__________________
Steer
Old 20th January 2006, 15:20   #60 (permalink)
amitoj's Avatar
OR, you can go on a diet, Steer!
amitoj is offline   Reply With Quote
Thread Tools
New Tata Safari Dicor 2.2L released! Samurai The Indian Car Scene!! 155 7th October 2007 00:56
On buying Tata Safari Dicor now adc SUVs, MUVs & 4x4s 45 1st October 2007 16:46
TATA safari TCIC or the DICOR maheepgupta SUVs, MUVs & 4x4s 24 12th September 2007 11:29
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
