Old 22nd June 2006, 16:18   #106 (permalink)
Originally Posted by v1p3r
So in a straight line, there's no problem? .
Yes, as long as all 4 wheels are turning atthe same rate (which is straight line) there is no problem..
That would mean better traction off the blocks for a 4wd Safari.
You thinking of taking a 4WD Safari to a drag??
nitinbhag is offline   Reply With Quote
Old 29th June 2006, 14:49   #107 (permalink)
headers's Avatar
Hey steeroid,,
Does the Safari has enough power to do a powerslide as shown in the TV Ads..
__________________
RWD Rocks!
Old 29th June 2006, 18:31   #108 (permalink)
headers's Avatar
Originally Posted by Rtech
All that looks great on paper Steer, but that Indica engine is nasty, plain and simple. It is by far the worst engine I have ever experienced in an automobile!
I haven't driven the turbo'd one, but I'm not exactly holding my breath either.
guess you have never driven old Amby with Trekker diesel engines .. OR ARE RATHER NEW TO DIESEL DRIVING..
[IMG]images/smilies/Rolling%20laughter.gif[/IMG]
__________________
RWD Rocks!
Old 29th June 2006, 18:39   #109 (permalink)
headers's Avatar
Steeroid, the Octavia is actually a common rail diesel. TDI is just their acronym for it.
If you are serious about the carbon-fibre, pm me. I'm experimenting with it for my youknowwhat!
Hey V1p3r,
PD is the acronym for their Common rail DIs..Which is used only in the Superb diesel engines..The others have Direct Injection Turbos.. and not Common rail..
__________________
RWD Rocks!
Old 29th June 2006, 20:12   #110 (permalink)
@ v1p3r and @headers
You both are some how wrong bros.
Neither octavia nor Superb is Common rain. Neither TDI nor PD is common rail. (BTW Laura has PD engine)
Volkswagen is walking a different path in diesel engine technology.
They are not doing common rail. The are following their own path (pump deuse) and instead of using a common rain to increase pressure and minimise losses of IDI or DI they are using single pump per cylinder.
So PD and CRDi are two completely diffrent technology.
And both works. Now which one is better is a question yet to be answered.
I hope I have explained things (I am pretty bad in explaining though ask my wife ).
sinhsha is offline   Reply With Quote
Old 29th June 2006, 21:39   #111 (permalink)
Team-BHP Moderator
Mpower's Avatar
Sinhsha, You are right on all counts except that the Superb 2.5 V6 uses a common rail (I'm almost sure).
VW has all three FI systems in use, but will be migrating to piezo common rail for the future.
__________________
The difference between the men and the boys....................is the speed of their toys.
Old 30th June 2006, 15:06   #112 (permalink)
Default Dicor at 15K Km.
My Dicor has just crossed 15000 km and i thought I'd add my 2 bits worth. Engine is a godsend after the old anaemic TCIC 2 litre. I did 2 lakh km on my old Safari and moved onto the Dicor as nothing else really got me interested. Any person who drives a Safari will tell you that the Scorpio, old or new, just doesn't stack up. However the narrow power band is quite irritating, till you get used to it.
I've had my share of trouble with the EGR valve (Steer, all you need to do is disconnect the vacuum tube to close off the EGR totally, for a temporary fix. Engine check light stays off too) and got the modulator changed. I had a problem with my car snapping sideways under heavy braking and that was diagnosed as due to a blocked front brake line. Thats been fixed and brakings great again. The AC, as Steer said is just about adequate, and is pretty noisy at full blast, which is when it is also most effective.
My biggest complaint against this car is the rumbling at idle with the AC on. Reminds you of a jet plane on full brakes, waiting to take off .
The dealers however are being asked to take great care of Safari owners and not to be rigid on warranty claims. Good for us, I guess.
Overall, my kind of car and I'm very happy. The new price will make more people happier i guess. Oh and by the way the 6.4 lakh safari has the Dicor look and the TCIC engine. Don't go anywhere near it!!!
__________________
Live Life King Size!
jyobeb is offline   Reply With Quote
Old 30th June 2006, 15:32   #113 (permalink)
himanshugoswami's Avatar
Sorry Mate, but the Superd uses a TDI engine and not a common rail one.
Check this out
http://www.skoda-auto.com/global/sho...rb/technology/
BTW, sorry for going off topic!
__________________
I asked Mom if I was a gifted child...she said they certainly wouldn't have paid for me.- Calvin
himanshugoswami is offline   Reply With Quote
Old 1st July 2006, 10:43   #114 (permalink)
headers's Avatar
Yup mate,
I agree that VW uses single pump per cyclinder. They are called unit injectors and i read somewhere [I guess Overdrive] that this is called PD which is VW's answer to common rail technology.
The funda is that CRDI uses a common rail which handles the boosted pressure. This rail feeds all the injectors,,whereas in unit injectors, each of the injectors has its own pump and plumbling is different.
Each is supposed to have its share of advantages and disadvantages..
__________________
RWD Rocks!
Old 19th July 2006, 11:40   #115 (permalink)
The safari dicor site says that the engine is second generation.
Why? Has the engine been changed? Any idea?
Proxima is offline   Reply With Quote
Old 2nd August 2006, 18:26   #116 (permalink)
Latest... A friend bought a Safari Dicor VX in Chennai 2 weeks ago.. Within 2 days of delivery, the vehicle developed a long list of problems and is back at the garage where most things are being sorted out and some are taking a lot of time.. Will post details once I have an update..
Old 4th August 2006, 14:46   #117 (permalink)
Apparently the best way to get your new TATA vehicle delivered is to be physically present in the workshop when the PDC is being done. test drive get the corrections done. Any one buying a new tata Vehicle please be aware. Might not be applicable to all dealers.. Please use dicsretion
kiranpashtakar is offline   Reply With Quote
Old 18th August 2006, 10:32   #118 (permalink)
Hi Guys!!
I am a newbie to BHP and have booked a Dicor at Prerana Bangalore.
Let me know good places to change tyres (want to change to 255 size on alloys) and fix a good comp system.
ravin is offline   Reply With Quote
Old 18th August 2006, 11:58   #119 (permalink)
rkkoul's Avatar
After you changed all those spares in your Safari, I am wondering if you are still driving the same car that you originally bought!!
Rakesh
rkkoul is offline   Reply With Quote
Old 18th August 2006, 12:13   #120 (permalink)
Steeroid's Avatar
Rakesh
Why do you think they keep saying 'More car per car'?
__________________
Steer
In the land of the blind, the one-eyed man is stoned to death.
Steeroid is offline   Reply With Quote
Thread Tools
New Tata Safari Dicor 2.2L released! Samurai The Indian Car Scene!! 155 7th October 2007 00:56
On buying Tata Safari Dicor now adc SUVs, MUVs & 4x4s 45 1st October 2007 16:46
TATA safari TCIC or the DICOR maheepgupta SUVs, MUVs & 4x4s 24 12th September 2007 11:29
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445
