Closed Thread
Old 12th June 2008, 19:57   #361
Go Steeroid go! I'm getting there - 33300 done so far.
dicorex4x4 is offline
Old 22nd June 2008, 18:55   #362
Thanked: 1,642 Times
Default Ssssshhhhhhhhhh !
This is what makes the noise (on the outside!):
The Green Storm filter is attached at the standard Airbox Mount Point. The Standard Airbox is HUUGE, so this really liberates quite a lot of space inside. The plumbing is straightforward and the air comes in from the grille through that huge tube. So perhaps it can be called a CAI.
I had some reservations on the pipe going straight thru to the grille, primarily worried about water intake, but then Matthew showed me where the original air intake ends up (inside the LHS Fender) and this is substantially higher.
The truck is obviously breathing a lot better. I havent been able to do a realistic assessment of performance gains, if any, primarily because we left immediately afterwards on the Monsoon D R I V E where I was carting 5 very healthy males + lots of luggage and 2 crates of beer. Not the most ideal situation to evaluate a change in performance, but the truck was breathing a lot better at lower speeds in higher gears - the intake boom that was present at certain rpms (very small band of about 100 rpm or so) in such situations has totally disappeared, so it was a breathing issue!
I must add here that I got a very good rate from Peter. I did not ask him for the price before we decided to put this on, I just drove into International Hotel and asked them to plonk in a Green Storm. After installation I asked for the bill, by when Matthew had noticed the Team BHP stickers on the car - he asked me for my TBHP handle before asking Peter and then told me that they've given me a dealer rate. No discounts were asked for - way to go, Pete.
Steeroid is offline
Old 22nd June 2008, 20:16   #363
Thanked: 245 Times
Look forward to the review, here's an exploded view:
dadu is offline
Old 23rd June 2008, 17:41   #364
simply_sunny001's Avatar
Thanked: 15 Times
Steer
The removal of airbox surely has relieved a lot of space there.
only outside but why ?
have you done anything regarding the sound proofing ?
Please post some details of that too.
would be much appreciated.
thanks
simply_sunny001 is offline
Old 23rd June 2008, 18:07   #365
Su-47's Avatar
Thanked: 94 Times
I have an awesome memory (takes a bow )
http://www.team-bhp.com/forum/long-t...tml#post633264
Su-47 is offline
Old 23rd June 2008, 18:13   #366
Thanked: 15 Times
indeed,thanks a lot.
But i would still need some more details on this Sound Proofing job and possibly the people who can do this in NCR.
will wait for Steer
Old 23rd June 2008, 18:25   #367
Sorry I havent done any soundproofing. The Green Storm filter comes with the casing (as detailed in Dadu's post with the very helpful illustration) and therefore it suppresses the noise unlike the K&N that I tried my luck with earlier. The casing suppresses noise and the tube that brings in air from the outside also ensures that there's no intake sound inside the engine bay.
You dont hear anything inside - those outside the vehicle only hear a very cool and slightly menacing "SSSSSSHHHHHHHH" as the vehicle approaches.
Steeroid is offline
Old 23rd June 2008, 18:29   #368
kb100's Avatar
Steer - I recollect the OE Safari filter is rather HUGE. And this one seems rather small.
Just wanted to know if this Green filter has the ability to better that given its combination of surface area and filtering /breathing ability? I mean have you been shown any test figures?
kb100 is offline
Old 23rd June 2008, 18:38   #369
The casing is huge - the paper element inside isnt. I suspect the casing is huge either (1) to keep intake noise levels down or (2) because that is the way they have been building air filters for ages now and cant be bothered to change.
My original plan was to have the K&N mounted inside the original casing after removing the OE paper element and modifying it suitably. However this never worked out because I was never in India for long enough. When I saw the Green Storm and compared it in size to the K&N it is nearly the same, plus it came with a casing by default.
Besides, take a look at the inlet to the huge metal case that houses the OE filter - the box itself is big, but the inlet tube (from the left fender) is rather tiny in comparison. Makes you wonder why you need such a large box on top of such a tiny inlet.
I havent seen any test figures. Even if test figures were made available by the vendor I'm sure those would be in favour of their filter - then I would need independent verification of those results. I dont want to go down that road.
As far as I'm concerned there are a few Safaris I know of that are running this filter, as there are Innovas and Scorpios (including my friend's taxi mHawk). None of them are unhappy with their purchase and they havent had issues. This is good enough for me.
Steeroid is offline
Old 23rd June 2008, 18:42   #370
jkdas's Avatar
Thanked: 1,436 Times
See that when you give for service etc as people will try to pull the 'capot' to see the filter without properly releasing it. This can cause the 'clip/lock' of Embase to break. It happened to mine.
Hope Zak drives it down to Tvm soon or I drive down to Cochin to check it.
Edit:
The bigger box for some reserve air? Remember Sankar describing about reserve air thingy when we were modifying bikes with new air filters.
jkdas is offline
Old 23rd June 2008, 18:52   #371
Thanked: 15 Times
How hard is to remove and again re fit the filter ?
i'm thinking of such an arrangement where we can take it off(again fitting that airbox) before giving for service.
Of course TASS guys will start complaining of Warranty going void after seeing this.
Old 23rd June 2008, 18:58   #372
Piece of cake - you can do it yourself. All you need is a screwdriver and 3 spanners.
If they are WAITING for an excuse to void Warranty then they will definitely crib about it. However, I doubt if that is the case with TML or at least with my dealer.
How can they void our warranty when we are paying members of their Product Development team?
Steeroid is offline
Old 23rd June 2008, 19:12   #373
Thanked: 15 Times
so Pete distributes GreenStorm in india,shall i contact him directly?
my dealer (Nawab Motors) has closed in march end,so already having trouble with servicing.
that was indeed hilarious
Old 23rd June 2008, 19:32   #374
Thanked: 83 Times
Steer, how much did the filter cost?
SumitB is offline
Old 23rd June 2008, 19:40   #375
Sankar's Avatar
Thanked: 4,657 Times
Not just bikes Jk airbox design is pretty important in all the modern engines. While choosing after market performance filters, like the conical filter, the filter you buy should have more surface area than the stock filter. Ideally with much larger surface area since the airbox is being tossed away.
Edit: Imo a car like Swift needs Storm instead of the Wind and Steer's Dicor needs an ever bigger filter.
Sankar is offline
Closed Thread
Tata Safari 2.2 VTT : 125000 kms Long Term Report rrsteer Long-Term Ownership Reviews 87 14th July 2012 20:02
Long Term Review : 1994 Tata Sierra Dippy Long-Term Ownership Reviews 53 25th April 2012 14:36
Long Term Review - Tata Indigo LX 2004 pankaj09 Long-Term Ownership Reviews 26 10th August 2009 20:33
Short Term vs Long Term Ownership, New Car vs Used Car Ownership architect The Indian Car Scene 10 9th May 2008 11:39
