Old 6th October 2013, 10:30   #166
ecosport rules's Avatar
Thanked: 1,350 Times
Default Re: My Silver Ford EcoSport Titanium (O) TDCi. First delivered in India!
Originally Posted by urajkumar View Post
Ecosport rules: So the white DRL comes only when you switch on the parking lights! Then even during the day the rear parking lights are ON so that you can use the DRL?
I am planning to add only the DRL (no projectors) and keep the STOCK headlamps but that would mean the yellow parking light and white DRL might not look good togeather
Please help educate illiterate folks like me out here
1.white light is connected to parking light supply, socket to socket(u have to switch on whenever u need it)
2.yellow light is connected to indicator /hazard, socket to socket
3.if you want white light as DRL then it has to be connected to ignition which is not socket to socket, hence will void warranty. (Always on whenever the engine is on)
4.Suppose the vehicles parking lights are on and then you switch on the right indicator, the left light remains white ,the right one blinks in yellow colour.same applies for the other side
Will post some pictures for your reference
Hope this helps
Originally Posted by throttlehead View Post
Brilliant and very tastefully done mods. I also have the DRLs on my list but will get them added in due course. Immediate must adds are fog lamps, cross bar and tyre upgrade from 195 to 205 Michelins.
I just had one question, I feel like my clutch sends out a pulse when it is fully depressed. I can distinctively feel it. Not sure if it's the engine vibrating or something else. This is my first time with diesel engines so not sure if it's common. Do you or any other ecosport owners here experience it too?
Thank you throttle head
Very slight vibration which is not distinctly perceivable is ok, but beyond that you should ask your service manager to check it.
Also observe once more whether you are fully depressing the clutch for the gear change .
Is this vibration during idle or on the move?
ecosport rules is offline   (5) Thanks Reply With Quote
Old 6th October 2013, 10:48   #167
DeKay's Avatar
Thanked: 154 Times
What about the stock parking lights? Did you get them removed?
DeKay is offline   Reply With Quote
Old 6th October 2013, 10:53   #168
The white light is fixed to the original parking socket and more over when this is the new parking the stock one will look pretty bad.
The parking bulb hole is almost covered by the projector and is not visible unless you keenly observe it.
ecosport rules is offline   (1) Thanks Reply With Quote
Old 6th October 2013, 22:37   #169
Thanked: 92 Times
Hi EcoSport Rules,
Can you please let me know the Rearview Camera with IVRM is of which brand? Also, did they fit additional IVRM on top of the stock one or remove the entire assembly and fit the new one?
I'm getting quotes ranging from Rs 14000 (Torq brand) to Rs 19000 from different dealers but I'm not sure whether they are importing the Brazil version like you.
TSIched'Out is offline   Reply With Quote
Old 7th October 2013, 02:17   #170
Originally Posted by TSIched'Out View Post
Hi EcoSport Rules,
It is from ford company, all dealers will have the same model and all of them are made in brazil.
The entire assembly will be changed, if some body is offering a clip on model then it is not genuine.
I found the individual pack is value for money
ecosport rules is offline   (2) Thanks Reply With Quote
Old 7th October 2013, 03:51   #171
Thanked: 23 Times
Hi EcoSport Rules,
I had seen the torq branded irvm for 7k, i think with with 6 months warranty. Its not a reputed brand at all. These are chinese products stamped with names. Give you a better peace of mind than their counterparts without warranty for a premium. There were others, with screen sizes ranging from 4 to 7 inches. All clip on types mostly with no warranty prices ranging from 4-6k.
Also all the accessories at showrooms are Chinese/after market products except for a few things. The irvms they are selling at Gurgaon here are branded 3T plus. And guess what, it is owned by the sachdev group - owners of harpreet ford. They are priced 15k.
If you do want to spend something close to this, I would recommend you to invest in a 5 inch gps from mapmyindia/Garmin which supports rear cam as well. Two problems solved with one screen.
eco-doc is offline   Reply With Quote
Old 7th October 2013, 10:15   #172
Thanked: 92 Times
It is from ford company, all dealers will have the same model and all of them are made in brazil. The entire assembly will be changed, if some body is offering a clip on model then it is not genuine. I found the individual pack is value for money
Thanks for the info. One more query, there are no front parking sensors available with dealers in Mumbai. They are saying there's no such accessory from Ford. Did you get the rear parking sensors fitted on the front side as well? If so, are these working fine? Do you get the feedback on the MID for front sensors as well?
Old 7th October 2013, 11:56   #173
Thanked: 70 Times
No its all inclusive of ballasts, hid bulbs , projectors,wiring harness for socket to socket fittment,switchback yellow white drls.
So did you purchase a new set of headlights from Ford and sent it across to Gopal to carry out the Mod or did you remove the ones from your car and kept the car in garage till the modified headlight were received back at your end?
Just wondering how much is the cost of the new set of headlights from Ford if the first approach is followed?
pious_devil is offline   Reply With Quote
Old 7th October 2013, 15:40   #174
You are right , they are the rear genuine sensors fitted to the front.You get only audio feed back as it cannot be integrated to the mid.mid can only take feedback from one set
He gave us both options.as we had spare car we opted to send him current set of headlamps.headlamp set from ford is around 9300 but gopal has a good option of buyback so we donot loose anything in the bargain
Old 7th October 2013, 18:47   #175
Thanked: 70 Times
Anybody from bangalore planning to carry out the headlight upgrade. Mr Gopal says a better price can be worked out for a group purchase.
pious_devil is offline   (1) Thanks Reply With Quote
Old 10th October 2013, 11:48   #176
Thanked: 776 Times
Am sorry if this has already been posted somewhere but where is Mr. Gopal based out of? Hyderabad? Also, how long does he take to fix the headlights?
Maybe for someone like me based out of Pune, it makes sense to just drive down the car for a day.
Nilesh5417 is offline   Reply With Quote
Old 10th October 2013, 12:03   #177
niks_devil666's Avatar
Thanked: 236 Times
I also thot the same but he's based out of vizag. Plus he takes some time as well to do the job. Driving down to vizag from pune doesn't sound that good.
niks_devil666 is offline   Reply With Quote
Old 10th October 2013, 12:29   #178
Thanked: 776 Times
Niks - What part of town are you in? I'm going to check with Carax and Poona Motors to see if they have anything on it yet. Do you know any place in bombay where we can get these installed? I don't want to really remove the headlamps, courier them, get them back and install again. Too much trouble and don't trust couriers. Prefer standing next to the car when mods (at least electrical) are done.
Old 10th October 2013, 13:31   #179
johannskaria's Avatar
Thanked: 1,570 Times
Had sweeped Bombay a couple of times for this.
Came back disappointed!
It takes 5 days for the job to perfect!
So driving to Vizag wouldn't be a good idea!
Unless you are booking your first service in a Ford showroom in Vizag which is bang opposite to Srinivas shop
Then you can be sure you are in the official hands!
johannskaria is offline   Reply With Quote
Old 12th October 2013, 00:56   #180
avm
avm's Avatar
Thanked: 17 Times
Hi Pious Devil. I would love to get the headlight mod done along with the awesome DRLs.
PM me the details please.
Cheers!
avm is offline   Reply With Quote
My First Car - Ford EcoSport 1.5 TDCi Titanium (O) Naman_Ferrari Test-Drives & Initial Ownership Reports 26 22nd October 2014 10:47
My Urban SUV: Ford EcoSport Titanium TDCi - Moondust Silver xuv2390 Test-Drives & Initial Ownership Reports 71 5th September 2013 00:05
Ford Figo TDCI Titanium Silver joins the family Ricci Test-Drives & Initial Ownership Reports 27 14th June 2013 23:52
