Old 1st September 2013, 15:14   #91
puchoo's Avatar
Thanked: 748 Times
Default re: BBLost's Chevrolet Sail UVA: First 1,000 kms weekend trip done.
Having spectacles unfortunately limit the option of the Polaroids for me , but what i have done is stopped using any shining agent on the Fabia / T-Jet dashboard at all now , just wipe it with a dry cloth and let it be. After a day or so anyway there is a thin layer of dust which settles , despite the windows being rolled up all the time , and that absorbs a lot of glare as well.
Originally Posted by bblost View Post
[ Maybe a nice pair of Polaroids would help me out.
puchoo is offline   (1) Thanks Reply With Quote
Old 2nd September 2013, 11:36   #92
bblost's Avatar
Thanked: 6,051 Times
Yesterday had a bit of city driving as I needed to do a bunch of errands.
The dashboard reflection only happens when the sun is directly overhead. While the noon sun was irritating, by 3:30 pm the problem had subsided.
I was shopping at Karachi Bakery yesterday. I very rarely use a valet. In the case of a new car, there is just no way I would hand it over.
So I parked it myself in the cellar. This is two floors down the exit ramp is very steep.
Its almost feels like a 45 degree angle. I might be exaggerating just a little.
The car climbed up halfway when I had to brake. It then refused to climb up. No wheel spin because I did not give it more than 3k rpm. The tacho is very helpful in its digital format. The car however refused to climb. In this confusion the car switched off. I had anyways engaged the hand brake. It held the car in place. The valets asked me to back up and try. I let go of the handbrake without switching on the car. The rear brakes absolutely refused to gather any traction. The car continued sliding down. I pulled up the handbrake, switched on the car. Regained my brakes almost immediately.
Once at the base, I simply accelerated my way out of that cellar without any issues.
Did I mention the floor was wet due to water dripping.
Many years back I had had a similar experience in my wagon r. It was the Amrutha Mall parking in Somajiguda. That slope was not as steep as this one. But it was a lot wetter.
My wagon's front wheels had literally danced left and right when I had accelerated.
This car handled it a little better but the 3k limit I have set for the 1,000 kms is so frustrating.
RPM and Engine Speed.
In the fifth gear the car does 90 at a little less than 2700.
3000 rpm takes you to 105.
bblost is offline   (1) Thanks Reply With Quote
Old 2nd September 2013, 11:43   #93
himanshugoswami's Avatar
Thanked: 865 Times
Missed this thread and just saw it. Congrats Imran! The sail is a very well sorted car and highly underrated. i drove it a month back and was taken aback by its amazing ride quality and the tractablitiy of the diesel engine.
Welcome to the chevy family
himanshugoswami is offline   (1) Thanks Reply With Quote
Old 2nd September 2013, 12:40   #94
CARDEEP's Avatar
Thanked: 1,463 Times
Hi Imran (@bblost)
For the dash reflection under afternoon sun, you may also use the dashboard covers, but not sure how appealing these are to any non-commercial user.
Regarding climbing steep slopes/ inclines, I feel the older cars with more torque rating were definitely better. We have a similar ramp in Crown Interior mall in Faridabad, & yesterday I could easily climb out of second basement in second gear (engaged midway) in my '03 Santro Xing. On an earlier occasion, there was water on the surface due to rains, & yet it pulled 4 of us from second basement again.
Moreover, your car is heavier & the new emission norms have resulted in lowering the torque rating, which has affected the cars with smaller engines the most. Also, having tyres in good shape also helps in such tricky (steep incline + slippery surface) helps a lot.
PS: Apology for quoting your whole post... please edit whatever you feel appropriate.
Last edited by bblost : 2nd September 2013 at 14:43. Reason: Reduced the size of quoted post. Thanks./
CARDEEP is offline   (1) Thanks Reply With Quote
Old 2nd September 2013, 13:25   #95
CARDEEP's Avatar
Hi Imran
I forget to mention that my car runs on CNG these days, & as compared to petrol, there is some power loss, yet it manages these situations with aplomb.
I could not edit the earlier post, hence, had to post the same separately. Please feel free to merge this with the earlier one.
Old 2nd September 2013, 14:12   #96
rajshenoy's Avatar
Thanked: 580 Times
Not sure if its a MJD engine issue. Similar thing happened to me with Ertiga and Car did not move even in first gear after i applied sudden break. I had to switch off both AC and then it moved.
its a puny 1.25 ltr diesel engine and without the turbo kicking in, the power delivery is on par with any small displacement engine.
rajshenoy is offline   Reply With Quote
Old 2nd September 2013, 14:42   #97
bblost's Avatar
I have a Petrol. Its engine specs are:
Max. Power (PS@rpm) 86 PS @ 6000 rpm
Max. Torque (NM@rpm) 113 NM @ 5000 rpm
Because I am still in the initial break in period I have a self imposed limit of 3000 rpm.
There was no way I could go towards its peak power and torque values.
Old 2nd September 2013, 14:49   #98
Vid6639's Avatar
Thanked: 17,875 Times
The self imposed rev limiter is really not needed. The idea is not to have sudden bursts of acceleration and braking. So red lining like mad is not ok but going till 4000rpm is absolutely fine. Don't slip clutch for crazy start off the lights or rev suddenly till 5k and then just release your foot completely. Those are what you need to avoid. Also many times manual says don't keep it in constant rpm for long. Keep changing gears if on highway.
Vid6639 is offline   (3) Thanks Reply With Quote
Old 2nd September 2013, 15:01   #99
bblost's Avatar
This trapped on the parking ramp would have broken all those rules. High revving at standstill and dropping the clutch to take off.
Something I avoid on a used car and something I most certainly would not like to try on a new car.
Old 2nd September 2013, 19:24   #100
Geo_Ipe's Avatar
Thanked: 250 Times
Default Re: The Selection Process
Tata Vista:
-- Am not sure if I can trust the airbags to deploy.
Anything solid behind that line, or just an opinion??
Chevrolet can be happy that someone is actually making one of their cars popular! Kudos for thinking out of the box, and sticking to that thought!
Geo_Ipe is offline   (1) Thanks Reply With Quote
Old 2nd September 2013, 19:34   #101
Parth46's Avatar
Thanked: 331 Times
Congrats on a very sensible family car, sure to serve you for many years to come.
Parth46 is offline   (1) Thanks Reply With Quote
Old 2nd September 2013, 20:54   #102
bblost's Avatar
No, its just an opinion.
Old 3rd September 2013, 12:39   #103
bblost's Avatar
I guess I need to give a little more explanation that just a curt reply.
Thing is I have constantly read on the cost cutting by Tata. Over a period of time a sort of a negative perception gets created. That Tata makes vehicles at a price and hence it skimps on basic things.
A case of putting in a lot of features but not choosing the best available.
Things like power window switches etc failing make me very wary of the higher end electronics in the car.
Since my prime requirement was safety, I decided to avoid Tata. IN fact for the price I paid for my Petrol hatch, I could have easily bought the Diesel Tata Vista.
But every time I drove it, I would be unsure and that mental feeling would have dampened most of my drives.
Old 5th September 2013, 10:22   #104
alokgunhal's Avatar
Thanked: 83 Times
Congratulations on such a crisp and detailed ownership thread. The initial post of the requirements of a person who has is needs clear when looking for a car upgrade is very good. It will help a lot of us making a decision when it comes to deciding the car. Hope you have many more good times with the car.
alokgunhal is offline   (1) Thanks Reply With Quote
Old 5th September 2013, 19:12   #105
Baddychat's Avatar
Thanked: 120 Times
Congratulations bblost on your new ride. Wishing you thousands of happy and safe miles on this car. May she serve you well :-)
This shade of grey really looks cool on this car. I have never checked this car out in person but from what I see the rear legroom and space in general would be class-leading(not considering the Indica Vista in my comparo).
Happy mile munching. Cheers !!
Baddychat is offline   Reply With Quote
Stopped driving, started sailing - Chevy Sail UVA - now @ 65,000 kms indianvirus Test-Drives & Initial Ownership Reports 53 18th July 2016 20:02
Sailing on tarmac : The Chevrolet Sail ownership report @ 20,000 kms parrys Test-Drives & Initial Ownership Reports 57 8th February 2014 15:32
Chevrolet Sail UVA comes home - Initial ownership report shreehari Test-Drives & Initial Ownership Reports 41 18th May 2013 21:21
Chevrolet Sail (Hatchback) & Chevrolet MPV (Enjoy) : Auto Expo 2012 GTO The Indian Car Scene 343 9th May 2013 12:44
