Old 11th July 2016, 20:41   #811
avinash_clt's Avatar
Thanked: 797 Times
Default re: VW Polo GT TDI ownership log. EDIT: 1,00,000 km up!
Originally Posted by McLaren Rulez View Post
17k seems a bit high for a service no, even if you take the extra 3M stuff into account? Also, looks like there are two oil purchase entries in your bill. Did you buy some extra oil for emergency use later?
Excluding 3M detailing, overpriced wheel alignment + balancing at a VW ASC and brake pad replacement(an additional job), the bills comes Rs. 10,156 - (including extra Rs.970 for 1L bottle of spare oil). So otherwise a Rs.9200 for periodic scheduled service job seems fair pricing.
-Avinash
avinash_clt is offline   (1) Thanks Reply With Quote
Old 11th July 2016, 23:31   #812
BigBrad's Avatar
Thanked: 179 Times
75k km/5th service update:
Does the new 1.5TDI have a different fuel filter? I just noticed that the part number is different in my car's 15k service bill. The one in mine has the part number 6RF127401A and costs approx Rs. 1700 whereas your invoice lists this one: 6RF127400A. The cost is lesser too. A little googling tells me that the CWXA, CWXB engines get the costlier one. Is it possible to use the cheaper one in the 1.5TDI? Do you have more information on this?
BigBrad is offline   Reply With Quote
Old 14th July 2016, 18:36   #813
Thanked: 797 Times
Default Fuel filter: 1.5 TDI vs 1.6 TDI
As per Etka, the 1.5 TDI seems to have a different fuel filter. 6RF127401A as you have quoted is correct for 1.5TDIs (CWXA / CWXB). The fuel lines part number are also different from 1.6TDI. There seems to be an extra seal and water in fuel sensor for the 1.5TDI engines.
1.6TDI/105PS or CLNA engines have 6RF127400A for fuel filter part number.
Source
Old 19th July 2016, 19:25   #814
sunilsoft's Avatar
Thanked: 49 Times
That is the coolant temperature not the engine/oil temperature. And 90 'C is the normal temperature reported.
I am sharing the problem in this video Gannu bhai. Its like Mfd alerts and shows temp automatically without even switching the mfd to temperature mode.
sunilsoft is offline   Reply With Quote
Old 19th July 2016, 20:42   #815
Gannu_1's Avatar
Thanked: 9,008 Times
I am not sure but I think the airbag slip-ring inside the steering wheel is the culprit. The MFD is cycling between the various options by itself and the only connection between the steering wheel and the BCM is the slip-ring.
Go to your service centre and get it replaced.
Gannu_1 is offline   Reply With Quote
Old 19th July 2016, 21:29   #816
sunilsoft's Avatar
Thanked: 49 Times
No it displays the temp and then revert back to whatever was previously set such as average fuel economy or even outside temperature. IMO I THINK IT COULD BE THE COOLANT SENSOR
Old 22nd July 2016, 12:24   #817
Gannu_1's Avatar
Another Chennai-Palakkad trip yesterday night and that brought up the 75k mark:
VW Polo GT TDI ownership log. EDIT: 1,00,000 km up!-wp_20160722_11_28_49_pro.jpg
Left at 9 PM and reached home at 4:30 AM. Replacing the brake pads during the last service helped immensely - realised it a couple of times during the drive.
Gannu_1 is offline   (5) Thanks Reply With Quote
Old 23rd July 2016, 00:30   #818
Thad E Ginathom's Avatar
Thanked: 6,586 Times
Mine had it's first decent out-of-city run, this last weekend, since I bought it. The effect on the car is better than a service!
Thad E Ginathom is offline   (1) Thanks Reply With Quote
Old 24th July 2016, 06:11   #819
Thanked: 1,647 Times
In what way did it help? Braking effect / pedal travel does not reduce when pads are worn unless there is some other problem with the brake systems.
VeyronSuperSprt is offline   Reply With Quote
Old 24th July 2016, 12:37   #820
MavericK46's Avatar
Thanked: 108 Times
I beg to differ.. Braking effect (brake bite and even stopping distance if the pad is worn down to the backing-plate) would reduce for sure, but pedal travel won't show a difference unless the brake fluid is contaminated with air/water.
Cheers !
Sundar
MavericK46 is offline   Reply With Quote
Old 24th July 2016, 14:04   #821
Many years ago I heard that brake pads had particles in them at a level where they should be replaced. They make noise on braking. I don't know if this is general?
Letting the brakes wear down to the backing plate would not only be very dangerous, but also very expensive, as the disks are going to get damaged by steel-on-steel contact.
I don't think any of us would let that happen, but sometimes we get into a mode like I can get another three weeks... It's just penny pinching, and the last time I did it with a dying battery it cost me, in delays rather than cash, but it is still a cost. Sure: I used that battery until it's very last drop of life, but the on-the-road replacement cost me several hours of that day.
Old 24th July 2016, 17:31   #822
MavericK46's Avatar
Thanked: 108 Times
Amen, Sir !
Just wanted to point out that improvement in braking can certainly be felt when the brake pads are down to their last legs and one gets them replaced. Its down to the wear on the pads causing them to glaze more easily and hence reducing the friction that they generate against the discs.
Cheers !
Sundar
Old 24th July 2016, 21:09   #823
Gannu_1's Avatar
The braking distance has reduced massively. While replacing the stock pads, it had about 3-4 mm of the frictional material left. On the downside, the alloys have darkened as a result of the brake dust.
We left Palakkad around 9:30 AM and reached Chennai at 5:30 PM, after 2 tea breaks and a lunch break at A2B Thoppur. Surprisingly, the A2B outlet was nearly empty today. Completed 76k on the return trip.
Old 24th July 2016, 21:56   #824
This happens because of glazing that develops on pads / discs when forceful braking is minimised (good / slow / anticipatory driving).
And although this is a good practice, the downside is the reduction in braking distances.
You will feel this happen with your current pads too after some use and it's best at that time to do some forceful braking a few times (on empty roads and after checking in your mirrors) which will remove the glazed surface on the pads / discs and get the forceful braking back again.
The car will not have reduced braking distances in any other situation unless there is a problem with your brake systems which apparently is not the case.
VeyronSuperSprt is offline   (2) Thanks Reply With Quote
Old 24th July 2016, 22:32   #825
reduced braking distance = good
increased braking distance = bad
I'm confused!
My 2014 VW Polo 1.5 TDI : First Ownership Report. EDIT, 10000 kms up Zigor Test-Drives & Initial Ownership Reports 116 25th April 2016 16:35
VW Polo 1.2L TSI DSG Ownership Log - From a non-enthusiast diffsoft Test-Drives & Initial Ownership Reports 38 14th December 2014 12:17
New Polo - Highline TDI - Test-Drive and Initial Ownership Report EDIT: Now sold! Chethan B G Long-Term Ownership Reviews 1220 24th November 2013 21:04
Ownership Log: VW Vento TDI HL (Updated with ICE Review) bala80 Test-Drives & Initial Ownership Reports 168 12th February 2012 19:51
