Old 15th October 2014, 13:46   #346
Gannu_1's Avatar
Thanked: 9,125 Times
Default re: Gannu's VW Polo GT TDI ownership log : 35,000 km up!
Originally Posted by rana_kirti View Post
1. where can i buy that white plastic part ? order online or any local store ?
2. you cut GTI black plastic part and stuck the GT on it right ?
3. which version of Araldite did you use ? i went to their website and got confused ? also where can i buy it ? order online or local store ?
1. Local hardware store that deals with plumbing and sanitary items.
2. Correct. The G, T and I from the black plastic part comes off quite easily. Trim the backplate to fit the stock GT logo.
3. Not sure of the version. Ask the hardware store for Araldite and they’ll give you a pack which has 2 tubes inside - resin and hardener in blue and white outer shades. Remember to clean the surface thoroughly (sand it if need be), squeeze equal amounts from both the tubes, mix them well and apply the mixture on the surface. Leave it to cure for a day. This is an epoxy adhesive and takes time to cure and set in. Unlike the instant cyanoacrylic adhesives like Fevi kwik.
Can it be moved a bit to the right? I can see a hole besides the 'T'. Or will it expose a a similar hole on the left?
That’s right Deepak. It will expose a hole on the left. Unless noticed carefully up close, the hole on the right is not visible.
The workman ship on the seat looks very good. A steal for that price. But I would have retained the stock covers. That Milan' Titanschwarz fabric upholstery is one of the best offered. A personal choice really.
The stock fabric upholstery was very comfortable - no doubts on that but this one looked much better. A notch less comfortable and the PU material makes some noise as you sit. Maintenance with beige shades are a big pain! I am realizing it now. I end up cleaning the seats every weekend!
Gannu_1 is offline   (1) Thanks Reply With Quote
Old 15th October 2014, 16:34   #347
Thanked: 80 Times
thanks forgot to ask, you stuck the GT to the plastic also with araldite or 3m double sided tape ?
I hope it's easy to remove if need be or rather I hope it doesn't fall of easily.
would you know the adhesive used on the oem GT emblem ? it was grey in color.
cheers.
rana_kirti is offline   Reply With Quote
Old 15th October 2014, 16:45   #348
Gannu_1's Avatar
No double sided tape used anywhere. Araldite was used for both - sticking GT to the backplate and backplate to the plastic screw. Don't use the double sided tape - peels off especially after the logo is exposed to a lot of heat.
I think it is some epoxy glue. It took a while to come off the stock grill.
Old 15th October 2014, 23:46   #349
deetjohn's Avatar
Thanked: 6,659 Times
I really like the way it looks as well. Also love that Interlagos trim VW use in GTI.
The downside of using artificial leather is less comfort and them getting soiled with ease. Pure leather is much more easier to live with. I have a can of Gulf MultiAuto Cleansing Foam and it works really well on light colored trim.
deetjohn is offline   (1) Thanks Reply With Quote
Old 16th October 2014, 14:05   #350
frankmehta's Avatar
Thanked: 2,216 Times
Awaiting your Projector install, Gannu. I hope you are accounting for the lack of light throw of Aftermarket projector headlights
frankmehta is offline   (1) Thanks Reply With Quote
Old 16th October 2014, 14:53   #351
Thanked: 80 Times
bro all equipment in place but got stuck again. how do i trim the black plastic part ? not able to do it with scissors.
any particular tool that'll help me trim it easily to the desired contour/shape...?
thanks.
VW Polo GT TDI ownership log. EDIT: 1.05L km up + DIY servicing!-1413451399359.jpg
Old 16th October 2014, 15:20   #352
Gannu_1's Avatar
Not sure about it Frank. I'd know after the installation. Will hopefully be done by the end of the month. We intend to take it up next weekend.
Excellent! You are set. Just that you would need a sharper tool and not just scissors.
I have this Stanley utility blade I had bought off eBay for my glovebox lamp mod link. Cuts through plastic with ease.
Place the letters G and T on that backplate and mark the rightmost tip of T using the blade. Now, use a steel rule, hold the backplate firmly and run this knife multiple times through a straight line (marked in yellow in the image below) where you just made the mark. The end would simply come off now.
Now use the Araldite as I had instructed but remember do not do excess of it. Or better still, use Fevi Kwik to fix the letters to the backplate and use Araldite to fix the screw to the backplate.
Old 17th October 2014, 12:29   #353
Thanked: 80 Times
hi gannu,
just an extension to your idea. I filed away the plastic bits on the right honey comb with a slim taper file and now it looks like stock.
I intend to now stick the GT which i prepared overnight over the remaining left and center honeycomb where the black plate clips went in and it should look stock without any holes exposed.
should I use araldite for this. what say ?
cheers. :-)
VW Polo GT TDI ownership log. EDIT: 1.05L km up + DIY servicing!-1413529059551.jpg
rana_kirti is offline   (1) Thanks Reply With Quote
Old 10th November 2014, 11:17   #354
Gannu_1's Avatar
Finally, after 3 long painful weeks (perks of not being a bachelor anymore!) of waiting and hard work, the Morimoto Mini D2S Stage III bi-xenons have been retrofitted onto the stock headlights:
VW Polo GT TDI ownership log. EDIT: 1.05L km up + DIY servicing!-img_1099.jpg
VW Polo GT TDI ownership log. EDIT: 1.05L km up + DIY servicing!-img_1107.jpg
VW Polo GT TDI ownership log. EDIT: 1.05L km up + DIY servicing!-img_1085.jpg
VW Polo GT TDI ownership log. EDIT: 1.05L km up + DIY servicing!-img_1100.jpg
VW Polo GT TDI ownership log. EDIT: 1.05L km up + DIY servicing!-img_1084.jpg
VW Polo GT TDI ownership log. EDIT: 1.05L km up + DIY servicing!-img_1073.jpg
VW Polo GT TDI ownership log. EDIT: 1.05L km up + DIY servicing!-img_1062.jpg
Unfortunately we couldn’t fine tune the cutoff for a perfectly horizontal/parallel line but we managed this after some trial and error:
VW Polo GT TDI ownership log. EDIT: 1.05L km up + DIY servicing!-img_1075.jpg
VW Polo GT TDI ownership log. EDIT: 1.05L km up + DIY servicing!-img_1050.jpg
VW Polo GT TDI ownership log. EDIT: 1.05L km up + DIY servicing!-img_1053.jpg
Night-time visibility has improved drastically - the throw is longer and the intensity of the beam is higher than the stock H4 halogen bulbs with a pleasant white light. Currently, the projectors are using Osram Xenarc 66240 D2S bulbs rated at 35 W, 4100 K and 3200 lm.
Before and after shots - same spot (open plot and no lights) and same camera settings (ISO 160, f/5, 0.6 s).
Before (Osram Nightbreaker Unlimited H4 60/55 W):
Low beam:
VW Polo GT TDI ownership log. EDIT: 1.05L km up + DIY servicing!-onbu_l.jpg
High beam:
VW Polo GT TDI ownership log. EDIT: 1.05L km up + DIY servicing!-onbu_h.jpg
.gif: Imgur
After (Morimoto Mini D2S 3.0 + Osram Xenarc 66240 4100K + 35W ballasts):
Low beam:
VW Polo GT TDI ownership log. EDIT: 1.05L km up + DIY servicing!-mori_l.jpg
High beam:
VW Polo GT TDI ownership log. EDIT: 1.05L km up + DIY servicing!-mori_h.jpg
.gif: Imgur
Have clicked a short clip while driving the car through an unlit road but doesn’t highlight the intensity of the projector much (will try clicking another one):
The entire DIY was done in-house with the assistance of my trusted ex-roomie, best friend and partner-in-crime - Moorthy, along with the support of my wife. Things would not have moved an inch further without the home ministry’s nod and approval. My heartfelt gratitude to Kedar Desai, a good friend from Bangalore whom I had interacted with on the HID Planet forums and over WhatsApp. You were of immense help during the course of this DIY. Thank you so much Kedar! I owe you one. And finally, Sreejith for lugging the Morimoto components from the US all the way to Palakkad.
As always, a detailed thread on the DIY - how to, all the tools and parts required, the roadblocks we met, the solutions and jugaad we eventually came up with, the purchase experience from TRS and AVS Tuning, the entire DIY experience - will be up in a week’s time. Stay tuned.
Gannu_1 is offline   (27) Thanks Reply With Quote
Old 10th November 2014, 11:38   #355
Thanked: 9,242 Times
Its now time you either re-badge your Polo or get a European registration number done and pay import duty for the whole car! Apart from Fuel & the driver, everything seems retrofitted & non India spec .
Waiting for the DIY pics and explanation as usual.
paragsachania is offline   (4) Thanks Reply With Quote
Old 10th November 2014, 19:06   #356
ajaypjayaraj's Avatar
Thanked: 1,008 Times
When I read "after 3 long painful weeks" related to retrofitting projector DIY, I felt nostalgic. It IS painful and the amount of patience required for the fine work involved in this DIY is something only a DIY specialist would understand in its true sense. Grinding the reflector unit to millimeter perfection and handling it without a scratch till project completion, finding ways to do a proper fitting of the projectors that will take the punishment of broken roads, achieving the precision alignment of the beam, managing the dust this work kicks up, all that noise and garbage generated from the work.. It DOES take lot of skill, time and patience. The dose of satisfaction this DIY gives you would last longer than your other projects. I know the hard work that goes into this job.
The cut off is great Gannu. I don't see a need to fine tune it further if at all you have run out of head light adjustment range (those manual adjusters). And since the very minute tilt (not big enough to be mentioned, but since you pointed it out..) is in advantage of RHD, it is very much safe and wont dazzle oncoming traffic at all. Don't worry about it. Looks good. Though I have 1 doubt. Why is the scattering of RH projector not as prominent as the LH ones? The scattering gives it the colorful sparkle which makes it look good. One car with that noticeable colorful sparkle (more than other cars few years back) on our roads was Laura. Now there are many.
That's the best HID bulbs you got. Is it 4,100K or 4,300K? Was in my wish list too when I was sourcing parts for upgrade. But currently running Philips D1S HIDs and actually quite impressed with it. But Xenarc NBU is the leader, no doubt!
That would be a great help for those who venture out into DIYs like us. The amount of data collection that goes into the preparation of each DIY is huge, you would know that. While most DIYs are from US or EU, problem for us Indians is finding cost/availability/sourcing details. So details from a DIY-er in India would be of great help to the guys here wanting to try these stuff. I couldn't be a member to share the info. when I did the DIY years back. Back then there were not even after market projector retrofitted head lamps (forget DIYs like you see on our forum today) available like today. Good you have the chance to share all the info. and you religiously do it too. Keep it up!
Last edited by Technocrat : 10th November 2014 at 21:51. Reason: Typo corrected as requested, thanks
ajaypjayaraj is offline   (1) Thanks Reply With Quote
Old 11th November 2014, 07:18   #357
naveen.raju's Avatar
Thanked: 2,815 Times
Great work Ganesh. So finally it's up after a long time. Had any trouble fixing the ballast?
naveen.raju is offline   (1) Thanks Reply With Quote
Old 11th November 2014, 08:46   #358
Gannu_1's Avatar
Thread in the works Parag bhai. This will be THE thread for anyone who’s looking for the Mini D2S retrofit on the Polo or any other car. I can assure you that.
We did not observe the slight tilt of the driver side projector while fixing the epoxy glue. Not sure how it crept in. I am just glad it isn't too much!
I think the bulb has to be reseated after taking it out. My friend was also suggesting he had faced the same thing during his retrofit.
These Osrams are supposedly the OEM bulbs on many cars. It is 4100K as indicated in the spec sheet from Osram.
Keep it up!
Thank you so much Ajay. Means a lot coming from established DIY’ers like you and Parag bhai. Appreciate it.
No issues with fixing the ballasts Naveen. For the co-driver side, there is a small opening behind the headlight which had a hole. Mounted both, the ballast and the harness box on the same hole using the same hex. head bolt. For the driver side, there weren’t any open holes so we fixed the ballasts to the diesel filter’s column using a couple of zip-ties. It is a secure mount and wouldn’t wobble. Everything will be on the DIY thread.
Gannu_1 is offline   (2) Thanks Reply With Quote
Old 13th November 2014, 10:54   #359
abbey4u's Avatar
Thanked: 101 Times
Great work. Was there any bulb failure error in polo after the install? If yes what was done to fix that?
abbey4u is online now   Reply With Quote
Old 13th November 2014, 11:06   #360
Gannu_1's Avatar
The MID didn't throw any error or messages.
Gannu_1 is offline   Reply With Quote
My 2014 VW Polo 1.5 TDI : First Ownership Report. EDIT, 10000 kms up Zigor Test-Drives & Initial Ownership Reports 116 25th April 2016 16:35
VW Polo 1.2L TSI DSG Ownership Log - From a non-enthusiast diffsoft Test-Drives & Initial Ownership Reports 38 14th December 2014 12:17
New Polo - Highline TDI - Test-Drive and Initial Ownership Report EDIT: Now sold! Chethan B G Long-Term Ownership Reviews 1220 24th November 2013 21:04
Ownership Log: VW Vento TDI HL (Updated with ICE Review) bala80 Test-Drives & Initial Ownership Reports 168 12th February 2012 19:51
