Old 28th May 2016, 12:47   #781
Gannu_1's Avatar
Thanked: 8,302 Times
Default re: VW Polo GT TDI ownership log. EDIT: 87,000 km up!
Originally Posted by sunilsoft View Post
Gannu Bhai can we use araldite fast and clear. As Bondtite is not available?
I can't say since I have seldom used Araldite. Please ask around if Bondtite is available in your neighbourhood hardware outlets.
Gannu_1 is offline   Reply With Quote
Old 30th May 2016, 11:45   #782
sunilsoft's Avatar
Thanked: 47 Times
Gannu Bhai, I did Manage to get the mirror installed with Fevitite Rapid. But after driving for 200 Kms. When I switched my audio system to full volume, With vibrations or heat. The mount fell down.
Please let me know did you prepare the windscreen area with sand paper or primer?
Is there any specific method to fix the mount.
I am trying to get the BONDTITE FAST AND CLEAR.
sunilsoft is offline   Reply With Quote
Old 30th May 2016, 12:03   #783
Thanked: 131 Times
I am wondering, would it not be possible to use hot glue to fix this?
Something like this:
http://www.amazon.in/gp/aw/d/B004MKM...s=hot+glue+gun
pillainp is offline   Reply With Quote
Old 30th May 2016, 17:07   #784
Thad E Ginathom's Avatar
Thanked: 5,258 Times
This is a specialist application. I feel that proper glass glues should be used.
Not only is glass smoooth but it has to cope with constant vibration and regular hard shocks.
Perhaps there are lots of other things that might work, but perhaps finding out that they don't is going to leave a very-difficult-to-remove mess on your screen. Not worth the risk of experimenting.
Old 31st May 2016, 12:24   #785
Gannu_1's Avatar
Why would you even do that? You should never attempt to play an audio device at its full volume. It will damage the drivers.
The mount was lightly sanded using a 1200 grit wet sandpaper and cleaned before the epoxy glue was applied. No primer was applied.
No. You just have to follow the basic procedure for gluing 2 things together. Surface preparation goes a long way to ensure that the mount is secure and firm on the long run and it doesn’t come off easily. FWIW, it has been close to X months ever since I’ve installed the mirror and it hasn’t come off the mount despite the car going over bad patches of road, being parked under the sun and the cabin getting heated and adjusting the mirror.
Enquire at shops which sells glass and mirror articles. They usually keep Bondtite in stock. Before applying the glue, ensure you scrap off the old one from the windshield properly and sand the surface if needed. Take time and do it.
I suggest you take the car to Windshield Experts (or an FNG that deals with windshield replacements) and request them to glue the mount for you using the polyurethane glue which is used to stick the windshield to the frame. This is essentially the same glue. The tube usually doesn’t cost more than 800-1000 Rs.
Hot glue won’t cut it for this application. The mount is heavy (being made of metal) and the mirror assembly is heavy as well.
Absolutely. I had originally thought of getting the OEM primer and glue imported but it wasn’t worth it. After further research on how metal can be glued to glass, I chose to go with this one.
Old 31st May 2016, 12:29   #786
Thanked: 131 Times
Bondtite seems to be available on Amazon:
Search for Bondtite on Amazon.in
Is this the same product you are talking about, Gannu?
Old 31st May 2016, 12:39   #787
Gannu_1's Avatar
The Fast & Clear variant it is but they don't seem to stock the smaller tube pack. It was available for less than 100 Rs for a pack of 2 tubes. The hardware stores have them, specifically the ones that retail glass and mirror articles.
Old 31st May 2016, 12:43   #788
Thanked: 131 Times
They do seem to have 24-packs of the 3g tubes though:
Resinova Bondtite Fast & Clear Epoxy Adhesive (3g) Pack of 24
Old 31st May 2016, 13:34   #789
sunilsoft's Avatar
Thanked: 47 Times
Gannu Bhai, After searching a lot, Finally got the Bondtite Fast and Clear from a hardware store in Sector 45 Chandigarh. Even the owner told me that fevitite rapid comes off due to heat.
Should I use the mallet to fix the mirror to mount. I think it is difficult to slide it using hand.
Actually what I meant was high volume of the audio system not Full Volume ( Mistake).
Gannu Bhai When would you be upgrading the shock absorbers to Bilsteins.
Old 31st May 2016, 19:34   #790
Gannu_1's Avatar
Not really. After the mount is glued and you've given it at least a day for curing, you can simply slid the mirror on the mount with the bare hands. It should slide in and lock with a reassuring click.
August perhaps. A friend is planning to visit Germany and he might carry it along.
Old 4th June 2016, 13:35   #791
Thanked: 66 Times
Gannu_1, I have a question about the Mk7 headlight switch and the associated module you installed. Apart from the coming home and leaving home features, do headlights turn on automatically on auto mode, while driving the car, when it's dark?
I am wondering if auto-toggling between dipped beam and high beam, for halogen headlamps, is somehow possible. We may need a different clock spring, with the headlight stalk that gets flicked "in-place", to make its behavior sane for user overrides.
halfbytecode is offline   (1) Thanks Reply With Quote
Old 4th June 2016, 20:26   #792
Gannu_1's Avatar
Yes they do. When it turns dark, the parking lights turn on first and the headlamps later when the intensity of the darkness increases. I don't recall the last time I turned on the headlamps manually.
As in you flick the stalk to the high beam position and the high beam reverts to low when it senses the beam from the oncoming vehicle? Doable with the HBA (high beam assist) retrofit.
A friend from Spain has done it on his Polo after a lot of hard work:
Notice how the stalk comes back to the central position after the high beam is flicked but the indicator on the cluster is on. Requires extensive rewiring, refits (IRVM, stalk module etc) and VCDS changes. Not to mention being expensive.
Old 7th June 2016, 14:16   #793
Thanked: 66 Times
That's good to know about auto on-off working with the retrofit.
About the stalk coming back to central position, that is exactly what I was thinking and trying to ddescribe It's good to know that someone has done it. Thanks for sharing.
Last edited by Gannu_1 : 7th June 2016 at 21:48. Reason: Removed Youtube URL from quoted post.
halfbytecode is offline   Reply With Quote
Old 16th June 2016, 14:55   #794
Hi Gannu_1,
Do you gave a post on step by step procedure to replace anti-glare ORVM, will be very useful.
prabhul is offline   Reply With Quote
Old 29th June 2016, 22:34   #795
Gannu_1's Avatar
We did a 1280 km, Chennai – Palakkad – Malappuram – Palakkad - Chennai drive last weekend which also happened to be my first night drive. My friend and I, started from our Chennai apartment at 9 PM on Friday, took a 20 minute break after a toll booth around 3 AM for a power nap and a coffee (which helped immensely!) and reached my Palakkad residence at 5 AM. Other than the trucks and Volvo/Scania buses, the roads were relatively free from Krishnagiri all the way till Coimbatore. The biggest bottleneck in this route is the L&T Coimbatore bypass road! The single-laned road is a pain with trucks crawling!
We started back at 3:20 PM on Sunday, paused at the A2B Thoppur for dinner around 7 PM (man, this place's minting some serious money with the sheer crowd we've seen so far!) and reached our Chennai residence at 11:30 PM. Two things that helped massively during the drive - cruise control and the bi-xenon headlights! I have to do the same trip this weekend (not opting for public transport since I'm transporting some goods).
Meanwhile, I had casually checked the engine oil level last week and found the level lower than the required mark on the dipstick. Bought a 1L bottle of Castrol Edge 5W-40 from Amazon but the dealer shipped it through Professional Courier which did not reach me before the trip. So ended up buying a can of Shell Helix Ultra from the local vendor and the engine gulped *wait for it* 950 ml! Initiated a return for the other bottle in the meantime.
VW Polo GT TDI ownership log. EDIT: 87,000 km up!-wp_20160626_13_44_15_pro.jpg
VW Polo GT TDI ownership log. EDIT: 87,000 km up!-wp_20160626_13_44_26_pro.jpg
The 75k service is also coming up; the odo currently stands at 73350 km. I am in two minds as to where to give her for servicing. Palakkad doesn't have a service center; there's only a satellite delivery outlet of VW Thrissur. The three service centers here in Chennai have poor feedback going by this thread. I just need to do the basic 75k service + front brake pads' replacement without any unwanted bits added. I was also thinking of Ramani VW, Coimbatore when I drive home sometime during August. Still have some time; will take a call.
Also got the parking aid button from my Russian dealer-friend sometime back:
VW Polo GT TDI ownership log. EDIT: 87,000 km up!-p_20160511_202634.jpg
VW Polo GT TDI ownership log. EDIT: 87,000 km up!-p_20160511_202622.jpg
VW Polo GT TDI ownership log. EDIT: 87,000 km up!-p_20160511_202648.jpg
So the whole PDC upgrade kit is with me now. I just need to find some time to hook ‘em up and running.
The driver side noodle mat is showing its age. Will replace it sometime. Had purchased it during Oct. '13.
VW Polo GT TDI ownership log. EDIT: 87,000 km up!-wp_20160626_13_17_33_pro.jpg
Originally Posted by prabhul View Post
Hi Gannu_1,
VW Polo DIY: Installing the OEM anti-glare mirror
Gannu_1 is offline   (5) Thanks Reply With Quote
My 2014 VW Polo 1.5 TDI : First Ownership Report. EDIT, 10000 kms up Zigor Test-Drives & Initial Ownership Reports 116 25th April 2016 16:35
VW Polo 1.2L TSI DSG Ownership Log - From a non-enthusiast diffsoft Test-Drives & Initial Ownership Reports 38 14th December 2014 12:17
New Polo - Highline TDI - Test-Drive and Initial Ownership Report EDIT: Now sold! Chethan B G Long-Term Ownership Reviews 1220 24th November 2013 21:04
Ownership Log: VW Vento TDI HL (Updated with ICE Review) bala80 Test-Drives & Initial Ownership Reports 168 12th February 2012 19:51
