Old 26th May 2014, 16:58   #121
dass's Avatar
Thanked: 434 Times
Default re: Tallboy welcomes longer companion: Maruti Ertiga VDi, 20000 kms report
Looks awesome. I went to the website in the hope that I can order the same for my Dzire, but looks like this is not compatible with Dzire. Anyways, do keep us posted on your experience and I will continue to check for the one which fits the Dzire.
dass is offline   (1) Thanks Reply With Quote
Old 26th May 2014, 17:40   #122
Thanked: 9,822 Times
I believe that the center console for the Dzire is also same as the Ertiga. If so, you can order the same. As you can see from the pictures, the width of the base if exactly the same as the width of the center console and fits precisely.
On experience, This will last long as It is currently doing duty in my WagonR and have faced no issues or breakages.
In terms of driving the Ertiga with the armrest, Its only 40 kms which I have driven of which 9 kms was on BETL where I could notice that its fitted exactly to my height and requirements.
paragsachania is online now   Reply With Quote
Old 26th May 2014, 20:47   #123
alokgunhal's Avatar
Thanked: 90 Times
The Ertiga Experience just gets better and better. The addition of the arm rest looks perfect and matches the Ertiga to a T. It is a welcome addition to the driving pleasure one has had driving this car. @paragsachania I do look forward to seeing this and experiencing the Drive again!
alokgunhal is offline   (1) Thanks Reply With Quote
Old 27th May 2014, 09:25   #124
extreme_torque's Avatar
Thanked: 1,241 Times
Parag, one of my known is interested in buying the Ertiga and sceptical about the A/C performance given the small engine and large greenhouse. Would you be able to comment on the effectiveness of the A/C in a place like Delhi (Ambient temperatures over 45 Degrees)
extreme_torque is online now   Reply With Quote
Old 27th May 2014, 10:17   #125
Let me be honest: The A/C takes a while to cool the entire cabin in case you have made a mistake of parking under direct sun. Easily 10-15 minutes to satisfactorily cool every area for that matter. Large space over your heads, long cabin till the boot door, huge glass areas all over.
In my case, I have experienced this couple of times in Bangalore with temperatures soaring at 37-38 Degrees but what I have for the seat covers is something which is a major heat generator too!
All thanks to the huge glass area, I would rate the AC 7/10 in Peak summers.
However, whenever we have had a drive during the same summer at nights, the rear AC is usually turned off after few minutes as the font AC takes care of the cooling effectively.
I am contemplating 100% transparent heat resistant film for the front as that is the major area where heat from the windshield bakes up the dashboard as well when parked under hot sun.
But another month and summer is almost over for me!
paragsachania is online now   (2) Thanks Reply With Quote
Old 27th May 2014, 10:31   #126
Thanked: 13,237 Times
I agree on the larger greenhouse and cabin size whic means longer AC usage durations to cool the cabin but the trick is:
1) Close the windows with slight gap left so that hot air escapes and heat doesn't build up in the cabin.
Caution: not open enough for theft.
2) Once started driving roll down all windows for 2-3 minutes to send all hot air passout, later on, switch ON the A/C at a higher blower setting (3-4 position) and after a while keep it at setpoint 2.
Following these, the cabin cools faster and the temperature attaining time is lesser hence lower load on all components and better FE. In Hyderabad the temperatures hover around 41-43 degree C.
Anurag.
a4anurag is offline   (3) Thanks Reply With Quote
Old 27th May 2014, 10:36   #127
1) Close the windows with slight gap left so that hot air escapes and doesn't build up on the cabin. Caution: not open enough for theft.
2) Once stated driving til down all at downs for 2-3 minutes to key all hot air pad out, later on, switch ON the A/C at a higher blower setting (3-4 position) and after a while keep it at setpoint 2.
Classic, ain't it . This remains the best method to cool the cabin by letting the Hot air accumulated inside to pass out. Keeping the AC in Fresh Air mode for the initial minutes also helps introduce outside air (comparatively less hotter to In cabin air) and results in faster cooling too.
Old 27th May 2014, 11:54   #128
denver85's Avatar
Thanked: 229 Times
Wow, two Ertiga ownership thread discussing the same topic. The effectiveness of AC, that also in the last days if extreme summer
I felt the same thing, it takes time to cool the cabin if parked under the sun. But once the cabin is cool, it's really comfortable. Tested this in temperatures ranging 40-42 and never felt uncomfortable.
I does almost the same thing mentioned by you guys :
1) Open the driver side door (only if the door is not blocking anything)
2) Start the engine and roll down all the four windows (I done it standing outside if it's really hot after making sure the gear is in neutral and hand brake engaged)
3) Switch on the blower to speed 3 (including the rear one)
4) After 15 secs, switch on the AC in Fresh air mode
5) 1 minute of idling, you are ready to go (don't forget to close the driver side door if it's open)
6) After traveling around 500 m, close all the windows
7) Reduce the blower speed to 2 (and switch of the rear one if no one in the middle/last row)
7) Wait for another 1-2 minutes, and change the AC setting to Circulation mode
By following this, I found the AC effective within 5-10 minutes.
denver85 is offline   (3) Thanks Reply With Quote
Old 27th May 2014, 13:02   #129
Good that you follow this but hope the A/C is used only after the engine has reached the optimum operating temperature else you ruining the engine in long run.
Point 5 - I see your doing 1 minute idling, that is a lot of time buddy, you are wasting fuel and building up engine heat as no effective cooling is happening since the car is standstill.
Anurag.
a4anurag is offline   (2) Thanks Reply With Quote
Old 27th May 2014, 16:14   #130
C'mon now! More than the AC, there are various other factors that would ruin the engine in long run. Over revving, redlining quite often, Hard braking and acceleration, lugging or for that matter major misses like not changing fluids on time.
I am yet to know about a case where someone said his engine didn't last its life or lost refinement just because he was turning the AC on as soon he started the car. The AC attribute contributes very less when it comes to "ruining" the life of the Engine.
And in today's cars (even in my WagonR), even if you left the AC Switch in ON Position, when you crank the engine next, the Compressor starts working on after a second after the engine comes to life. It is designed that way to take care of such unwarranted loads.
That way, even when you turn the steering wheel to full circle when stationary, the Electrical (Alternator) takes a load. So is the case when you turn your electrical devices on. Imagine the case of cars with high wattage speakers and amplifiers - They obviously put load on the Battery (and hence the alternator).
Instead, I would say its better to drive sedately for 3-4 kms once you take your car out from the gate and then get into the regular commute mode. This will do more than good to your engine.
paragsachania is online now   (3) Thanks Reply With Quote
Old 27th May 2014, 16:17   #131
funkykar's Avatar
Thanked: 1,723 Times
Come on. Come on!!!!
Usage of AC = Load.
Does that mean, one shouldn't even drive the car till it reaches optimal temperature?
Does it mean, you will not have any luggage/passengers in the car until it reaches optimal temperature?
funkykar is offline   (1) Thanks Reply With Quote
Old 27th May 2014, 16:25   #132
Guys, Ok, let me rephrase my sentence of not using the A/C and running of the engine - all I meant was to wait for a while till the oil circulates out from the sump to all parts to lubricate it. Using the A/C before the engine reaches optimum temporaries will put unnecessary load not so much to brake it into pieces or seize the internals.
Drive around for 5-6 kms without any hard acceleration and after this using the A/C will be better.
Apologies if I have communicated a wrong method.
Anurag.
Old 27th May 2014, 16:36   #133
Anurag.
Oil Grades specified as stock these days are becoming more and more thinner. From 20w40 used in most cars earlier, we are mostly using 0,5,15w in most of the cars that we see.
I could easily notice a tremendous difference in the idle RPMs during every cold start in the WagonR when I moved from 20W40 to 5w30. While it was at 1500RPM earlier during a chilled morning start, it easily reached 2000-2100 with the thinner grade oil. The engine also felt more rev-happy with this. It was evident that this oil was circulating faster than the 20w40.
Now, coming back to putting unnecessary load to the engine with the AC - I would still say its totally OK to turn the AC On and drive after that Turbo Idle but ensure that you are gentle on the pedal at least for the initial 3-4 kms like you mention.
Old 19th June 2014, 12:41   #134
Default 20,000 KMS Done
The 20,000 Kms Update:
The Ertiga hit the 20k figure on the Odo yesterday night. Its about 8 months since we bought it and guess the running is neither too much nor too less.
Tallboy welcomes longer companion: Maruti Ertiga VDi - 120,000 kms update-odo.jpg
The additions/Modifications carried out so far:
  • 100/90w Philips Rally Bulbs with Relay Kit
  • White light LED for interior light(s)
  • Star-Mats 3D tray mats
  • OE Spoiler
  • Tire upgraded to Michelin XM2 (205/60/R15)
Apart from this, 2 simple DIYs over the last few months added some comfort and basic feature into the Ertiga:
Here are a few latest photos of my Ertiga taken in various locations over the last few months of usual errands and some weekend drives:
No prizes for guessing - Hesarghatta Grasslands
Tallboy welcomes longer companion: Maruti Ertiga VDi - 120,000 kms update-hesarghatta_01.jpg
3 of we colleagues at work picked our rides almost in the same month and we headed for a photoshoot:
Tallboy welcomes longer companion: Maruti Ertiga VDi - 120,000 kms update-hesarghatta_02.jpg
From a weekend drive to Belgaum and Goa few days back:
Tallboy welcomes longer companion: Maruti Ertiga VDi - 120,000 kms update-nh4_01.jpg
Tallboy welcomes longer companion: Maruti Ertiga VDi - 120,000 kms update-nh4_02.jpg
Taken from one of those beautiful western ghats near Karwar connecting Dandeli:
Tallboy welcomes longer companion: Maruti Ertiga VDi - 120,000 kms update-joida_01.jpg
Tallboy welcomes longer companion: Maruti Ertiga VDi - 120,000 kms update-joida_02.jpg
Tire Upgrade
The Good Years were noisy; All the more noisier on Concrete roads. I was pampered with XM2 running on my WagonR for the excellent experience I have had on that car with no ABS and so called unexpected handling expected out of a tallboy.
At around 16,500 on the ODO, I changed all the tires to 205/60/15 and installed them on the OE Alloys that I had bought from the ASC during delivery. I carefully evaluated this decision on the profile (195 against 205) ascertaining that it should not scrap the arches at rear or inner walls in the front on full load and hair pin curves.
I am glad everything is normal and the tires has no such side effects. We drove 4 adults and luggage to Belgaum-Chorla and the ghats connecting Karwar to Dandeli which has a lot of twists and turns and the XM2s performed impeccably over the corners.
There was no touching of wheel arches on hairpin curves (when the car rolls a bit under load) and neither did it scrape on those innumerable undulations before Tumkur on NH4.
For those who had apprehensions on how a 205 fits on stock Alloys (5.5J), here is a pic to help you:
Tallboy welcomes longer companion: Maruti Ertiga VDi - 120,000 kms update-tire_02-2.jpg
Note that the minimal size for Rim recommended for 205 is 5.5J but to effectively utilize the full width from this tire one needs 6.5J at least. However, I will stick to OE Alloys for now as I fear that the positive offset and 6.5J size from the aftermarket alloys will result in scraping under full load.
20,000 KMS Service will happen over this weekend which will undergo typical fluid replacements and the necessary health check. Will update this thread after the service once again.
paragsachania is online now   (10) Thanks Reply With Quote
Old 19th June 2014, 14:37   #135
Default Re: 20,000 KMS Done
Congratulations for reaching the 20K mark. Just shy of one '0' to reach near the tall boy's milestone.
The tyres do look bulged types, I hope you get what I mean and if you don't mind can you post a picture from the side with the car fully loaded to see how the rear wheel arch distance from the tyre circumference, thanks.
Anurag.
a4anurag is offline   (1) Thanks Reply With Quote
My Red Cherry - Maruti Swift VDI: 120,000+ kms up DieselFan Long-Term Ownership Reviews 177 20th June 2017 12:10
Maruti A-Star: A wonderful companion for the last 13 months & 6800 kms dheepak10 Long-Term Ownership Reviews 4 18th October 2016 10:22
For Taxi: 2012 Chevy Tavera vs Maruti Ertiga vs Chevy Enjoy? EDIT: Bought Ertiga ZDi M35 SUVs, MUVs & 4x4s 21 9th January 2015 06:48
Tallboy Tales: From a Hyundai Santro to a Maruti Ritz VDi ABS SlowRider Test-Drives & Initial Ownership Reports 35 28th January 2014 17:18
My Red Pimento - Maruti Swift Vdi Euro IV review - 40000 Kms update ontheroad Test-Drives & Initial Ownership Reports 19 9th June 2013 20:01
