Old 13th July 2017, 23:42   #706
Thanked: 103 Times
Infractions: 0/2 (10)
Hi anurag, was just going through your thread for the nth time, could see a significant drop in mileage figures across the 120000kms, I mean on the MID.
Has it actually happened too?
dhruvritzed is offline   Reply With Quote
Old 14th July 2017, 00:02   #707
Thanked: 12,755 Times
Default Re: The story of a Blue Streak a.k.a Maruti Swift ZDi (Torque Blue). EDIT: 1,20,000 km up!
SERVICE UPDATE:
Got in touch with my team mate (BHPian interc00led) and performed the DIY Service. Bought ourselves a plastic tray to collect oil (₹45) and two Funnels of different size (₹15 & ₹30).
Following things were bought prior:
  1. Engine Oil - Petronas Selenia WR 5W40
  2. Oil drain bolt
  3. Service Kit (Consists of Oil Filter; Engine Air Filter and Fuel Filter)
  4. Cabin Air filter
  5. Coolant
  6. Brake Fluid
Couldn't change the coolant and Brake Fluid as it started to rain. So postponing these two jobs.
Images of the Service:
Service Kit
The story of a Blue Streak a.k.a Maruti Swift ZDi (Torque Blue). EDIT: 1,20,000 km up!-img_20170713_164733.jpg
Fuel Filter
The story of a Blue Streak a.k.a Maruti Swift ZDi (Torque Blue). EDIT: 1,20,000 km up!-fuel-filter.jpg
Engine Oil Filter
The story of a Blue Streak a.k.a Maruti Swift ZDi (Torque Blue). EDIT: 1,20,000 km up!-oil-filter.jpg
Oil Used (Petronas Selenia WR 5W40)
The story of a Blue Streak a.k.a Maruti Swift ZDi (Torque Blue). EDIT: 1,20,000 km up!-oil-used.jpg
A/C Filter
The story of a Blue Streak a.k.a Maruti Swift ZDi (Torque Blue). EDIT: 1,20,000 km up!-ac-filter.jpg
Oil Drain Plug
The story of a Blue Streak a.k.a Maruti Swift ZDi (Torque Blue). EDIT: 1,20,000 km up!-engine-oil-drain-plug.jpg
Coolant (MGA)
The story of a Blue Streak a.k.a Maruti Swift ZDi (Torque Blue). EDIT: 1,20,000 km up!-coolant.jpg
Brake Fluid (TVS Girling DOT 4) - 750 ml
The story of a Blue Streak a.k.a Maruti Swift ZDi (Torque Blue). EDIT: 1,20,000 km up!-brake-fluid.jpg
A/C Filter (aka Cabin Air filter) - Old vs New
The story of a Blue Streak a.k.a Maruti Swift ZDi (Torque Blue). EDIT: 1,20,000 km up!-ac-filter-old-vs-new.jpg
Engine Air Filter - Old vs New
The story of a Blue Streak a.k.a Maruti Swift ZDi (Torque Blue). EDIT: 1,20,000 km up!-air-filter.jpg
27 mm socket used to open the Engine oil filter
The story of a Blue Streak a.k.a Maruti Swift ZDi (Torque Blue). EDIT: 1,20,000 km up!-27mm-socket-used-open-oil-filter.jpg
Fuel Filter - Old vs New. Old one had done 21K kms almost
The story of a Blue Streak a.k.a Maruti Swift ZDi (Torque Blue). EDIT: 1,20,000 km up!-img_20170713_203732.jpg
Old Battery Tray
The story of a Blue Streak a.k.a Maruti Swift ZDi (Torque Blue). EDIT: 1,20,000 km up!-img_20170713_202030.jpg
New Battery Tray
The story of a Blue Streak a.k.a Maruti Swift ZDi (Torque Blue). EDIT: 1,20,000 km up!-img_20170713_204909.jpg
Old draining in process
The story of a Blue Streak a.k.a Maruti Swift ZDi (Torque Blue). EDIT: 1,20,000 km up!-oil-draining.jpg
Old engine oil refilled in the Selenia bottles and given off to the FNG I visit always
The story of a Blue Streak a.k.a Maruti Swift ZDi (Torque Blue). EDIT: 1,20,000 km up!-old-oil-refilled.jpg
Odometer so far post service
The story of a Blue Streak a.k.a Maruti Swift ZDi (Torque Blue). EDIT: 1,20,000 km up!-img_20170713_210650.jpg
1,20,000 kms Service Costs
The story of a Blue Streak a.k.a Maruti Swift ZDi (Torque Blue). EDIT: 1,20,000 km up!-120k-service-bill.jpg
--x-x-x--
No as much as much seen. I reset the MID every time I do a fuel refill and the image clicked was just 20 kms post refilling fuel.
But yes, post the injector cleaning, I love to push the car much more due to its stress-free nature and slightly more silent drive.
a4anurag is online now   (6) Thanks Reply With Quote
Old 14th July 2017, 08:01   #708
Thanked: 103 Times
Just a few questions-
-What about underbody stuff?like cleaning the debris below and suspension components like bushes replacement etc that the service center guys have an idea after lifting?
-Engine oil flush?
-brake oil flush and cleaning?
-EGR? Where will you get that done if from now on you'll do all services yourself?
Old 14th July 2017, 08:13   #709
-...suspension components like bushes replacement etc that the service center guys have an idea after lifting?
Bushes replacement was done at 80K at FNG. I have the service manual of the car so it is easier for me if I am stuck at any place.
-Engine oil flush?
Don't do this since I change oil every 3 months or 10K kms, car doesn't need a engine oil flush.
Jack stands enough for this job.
I'll be getting a pair too which make it 2 pairs to lift the whole car for any job.
I guess you haven't gone through the threads,
Here's the EGR Cleaning - Semi DIY done @ FNG
http://www.team-bhp.com/forum/diy-do...-ddis-mjd.html (DIY: EGR Valve Cleaning (1.3L DDiS / MJD))
Intercooler cleaning - Full DIY by me at home.
http://www.team-bhp.com/forum/diy-do...tercooler.html (DIY: Cleaning the Intercooler)
a4anurag is online now   (2) Thanks Reply With Quote
Old 14th July 2017, 14:01   #710
Thanked: 103 Times
Will just go through them, man you certainly have ability w.r.t servicing.
Makes me feel so dependent on the centres
Old 3rd August 2017, 19:24   #711
Sneak peak into what's happening...
The story of a Blue Streak a.k.a Maruti Swift ZDi (Torque Blue). EDIT: 1,20,000 km up!-dsc_0082.jpg
a4anurag is online now   (4) Thanks Reply With Quote
Old 4th August 2017, 18:21   #712
Oil filled is Castrol Manual API GL-4 80W90
Quoting my own post where I had changed the Gear Oil in my car and all I can say it was the worst of the lot of ever.
When the oil is cold, 1st and 2nd gear are 'hard' to shift into. Downshifting from 2nd to 1st requires to come to a dead halt whereas earlier I could downshift at 5 kmph at least.
When the oil has reached the operating temperature life was slight better. I had covered almost 3,000 kms since the change.
Decided to change the oil and I was on search for 75W90 but as usual no availability then BHPian interc00led said lets get Petronas Tutela Technyx. Tried in the two main ASC's of Fiat here but they were adamant on me getting a Fiat car so the job card could be opened after which they will give it over-the-counter to me or I get a registration number of a Fiat car that I know.
Sincere thanks to BHPian Keynote who got hold of 3 litres for me from Bangalore and handed it over when we met. Thanks buddy.
The story of a Blue Streak a.k.a Maruti Swift ZDi (Torque Blue). EDIT: 1,20,000 km up!-dsc_0305.jpg
The story of a Blue Streak a.k.a Maruti Swift ZDi (Torque Blue). EDIT: 1,20,000 km up!-dsc_0304.jpg
Product Name: Petronas Tutela Technyx
Grade: 75W85
Compatibility: API GL4 Plus; SAE 75W85; Fiat 9.55550-MX3 C.T.R NF010.B05
Costs: ₹ 600 per litre x 3 = ₹ 1,800
Shipping: Free, on his S-Cross 1.6.
I have driven almost 180 kms post the oil change and all I can say is "She is Back!!"
Precise, smooth and sure-slotting gears like how it was when new. I can downshift from 2nd to 1st at ease even at 5 kmph.
The only downside(according to me) with 80w90 is hard shift(a bit) when cold.
Spot-on Sir!!
Old 4th August 2017, 19:00   #713
Keynote's Avatar
Thanked: 564 Times
Now that was funny.
Really glad to hear that. Hope she stays healthy until replaced with the new car in few months.
OT : Eagerly waiting to see the ICE upgrade - DIY details.
Keynote is offline   (2) Thanks Reply With Quote
Old 7th August 2017, 09:56   #714
AUDIO UPGRADE
Quoting my own post regarding the sneak peak posted few posts above.
This is what that went into the car:
The story of a Blue Streak a.k.a Maruti Swift ZDi (Torque Blue). EDIT: 1,20,000 km up!-img_20170729_212609.jpg
Here's the thread with the full details:
Link: Blue Streak's ICE Upgraded!
a4anurag is online now   (1) Thanks Reply With Quote
Old 14th August 2017, 09:45   #715
Odometer Fancy Reading
1,23,456 kms
The story of a Blue Streak a.k.a Maruti Swift ZDi (Torque Blue). EDIT: 1,20,000 km up!-img_20170814_0704001600x900.jpg
Black Streak Tale - TVS Scooty Streak Ownership Review Mr.Boss Motorbikes 17 24th June 2017 18:51
BumbleBee: First Maruti Swift ZDI in Pune & Team-BHP EDIT: 20,000 km Update on Pg 12 Racer_X Test-Drives & Initial Ownership Reports 198 26th April 2017 16:19
Maruti Swift ZDi Torque Blue CLIX Test-Drives & Initial Ownership Reports 25 28th May 2013 07:38
