Old 14th July 2015, 17:26   #361
shashank.nk's Avatar
Thanked: 709 Times
Default re: The story of a Blue Streak a.k.a Maruti Swift ZDi (Torque Blue). EDIT: 90,000 kms up
Aim now is to reach 1,00,000 kms faster so that the S-Cross can be put in the Swift's place.
Congrats on hitting 50k mark in less than 2 years! that's a lot of running.
Looks like you are smitten by the S Cross. I'm waiting to check it out too,especially the 1.6 engine.
shashank.nk is offline   (1) Thanks Reply With Quote
Old 14th July 2015, 18:18   #362
a4anurag's Avatar
Thanked: 9,802 Times
Thanks buddy.
Smitten is an understatement actually. Waiting for my car to click 1 lakh now.
a4anurag is offline   (2) Thanks Reply With Quote
Old 14th July 2015, 19:16   #363
Darth Sid's Avatar
Thanked: 74 Times
50,000 km in a year and a half is a lot! The most I have done on any vehicle in a short span is 30,000 km in that same amount of time on my P220. I would have done the same on my Duke but with all the trouble it gave me it was parked at the service centre for a good amount of time. Three engine teardowns within the first 14,000 km or one year until the engine was finally replaced under warranty! But I know my Swift won't see that kind of mileage for a long time.
1,00,000 km won't take much time either. After another year or so I guess we will see a review of the 1.6 DDiS in your name.
PS: I have responded to both your headlight posts in the automotive light thread itself.
Darth Sid is offline   (1) Thanks Reply With Quote
Old 14th July 2015, 20:40   #364
Eddy's Avatar
Thanked: 3,581 Times
You remind me of my early days - 56k in two years.
Congrats on the milestone and drive safe. And target two lakh
Eddy is offline   (1) Thanks Reply With Quote
Old 14th July 2015, 23:12   #365
Thanked: 709 Times
^^ I agree
1 lakh kms is too small a milestone for you. You should aim higher
Old 14th July 2015, 23:41   #366
a4anurag's Avatar
Thanks Sid.
Here is the link to the post containing details on the headlight upgrade that I have done:
Light Upgrade!
a4anurag is offline   (3) Thanks Reply With Quote
Old 15th July 2015, 07:46   #367
Darth Sid's Avatar
Thanked: 74 Times
Thanks Sid.
Light Upgrade!
Thanks again for yet another useful piece of info! I think it is pretty much decided that the harness is going to be a Hella and the bulbs Philips Rally. Both appear to be easily available online so should be available in brick and mortar stores as well.
I also noted a couple of posts after the one linked above that the stock bulbs were Osram Bilux and you found them useless. They must be made in India then. I mention this because the stock H4 bulb in my Duke's headlamp was also an Osram Bilux but that one was made in Germany. I replaced it with a made in Poland Philips Xtreme Vision and found no perceptible improvement.
The above also leads me to believe that I will have to upgrade my Duke's headlamp once I upgrade my Swift's. No 100/90 option for that bike, though.
Old 15th July 2015, 21:22   #368
Thanked: 126 Times
50,000 kms UPDATE:
Finally the car does reach and clock another milestone in its life with me!
Hey .. just bounced upon this thread.
Congrats on the milestone and kudos on such detailed reports.
This particular post itself acts as a good recap on car care.
A quick question - your headlights are looking extra bright post the DIY. Do they cause any side effects??
And hoping that drivers from the other direction have not been cussing around!!
deepv is offline   Reply With Quote
Old 15th July 2015, 21:30   #369
Thanked: 7,747 Times
Don't go by the pics. He's installed what most of us have and running on the much recommended Philips Rally 100/90 H4 bulbs.
In reality, it would be as bright as any of our cars with a similar set-up.
I have the exact set-up in the WagonR (already 7 years, 175,000 kms with the set-up) and Ertiga ( 21 months, 60k kms). If you make use of these diligently like Anurag has mentioned in his earlier posts, the reflectors won't really fade or become dull.
I have not seen that happening in the WagonR which still have stock headlight units and the Ertiga despite the fact that I have regular been on all night drives spanning at least 10 hours in both these cars.
Low beam is more than sufficient for typical cruising speeds even on the highways with intermittent high beam for pro-active assessment when in doubts.
paragsachania is online now   (1) Thanks Reply With Quote
Old 15th July 2015, 23:40   #370
Darth Sid's Avatar
Thanked: 74 Times
Great! Another testament to this upgrade. Honestly, I am surprised that modern plastic headlamps can withstand the extra heat. Well, each such input is reinforcing my decision to make this upgrade.
Darth Sid is offline   Reply With Quote
Old 24th July 2015, 21:46   #371
a4anurag's Avatar
SERVICE UPDATE: 50,000 kms
Have sent the car for routine servicing. Got the Wheel Alignment, Wheel Balancing and Wheel Rotation.
Total costs incurred: ₹ 6733/-
Here is the bill:
The story of a Blue Streak a.k.a Maruti Swift ZDi (Torque Blue). EDIT: 90,000 kms up-untitled.jpg
The current odometer reading is 51,446 kms.
Old 29th July 2015, 09:17   #372
sumeethaldankar's Avatar
Thanked: 740 Times
Hi Anurag, a question for you. Since you do a lot of running in your car how often you check the tyre pressure? A week or fortnightly etc? Also do you use nitrogen in the tyres?
Thanks.
sumeethaldankar is offline   Reply With Quote
Old 29th July 2015, 09:46   #373
a4anurag's Avatar
Mostly I check pressures weekly and have a inflator at home hence I do the top up and set off. Earlier used to top up at petrol stations but found the difference in gauge readings.
I use normal air, not nitrogen.
Old 29th July 2015, 10:25   #374
Thanked: 740 Times
Ok. Can you tell me what brand of inflator/pressure guage you use? Typically hand held guages conk off in a short period. Also i am bit apprehensive in over filling or worse bleeding the air myself so i refrain from using such devices.
Old 29th July 2015, 11:03   #375
a4anurag's Avatar
Tyre Pressure gauge - Coido 6071.
Tyre Inflator :
Hope it helps.
Maruti Swift ZDi Torque Blue CLIX Test-Drives & Initial Ownership Reports 25 28th May 2013 07:38
My new set of 5 wheels: Maruti Swift ZDI - 20,000 kms update beast_within Test-Drives & Initial Ownership Reports 44 18th May 2013 17:25
My Maruti Swift ZDi: 3rd service & 10,000 kms up funkyp Test-Drives & Initial Ownership Reports 71 11th April 2013 14:33
Copyright 2000 - 2016, Team-BHP.com
