Old 25th March 2016, 16:54   #46
Thanked: 366 Times
Default Re: Shibujp's VW Polo GT TDI
During the last service I had got the suspension bolts retorqued and this seems to have reduced the steering rack sound and generally tightened up the suspension response. I have decided to keep an eye on the rattle for a month or so before taking this up as a warranty repair.
Meanwhile the Polo also covered a milestone, my third car to do so.
Drive on,
Shibu.
shibujp is offline   Reply With Quote
Old 30th March 2016, 00:29   #47
avinash_clt's Avatar
Thanked: 592 Times
Default Re: 24000 kms up - DIY oil change
Hello Shibu,
Good to know that you are crunching up miles in your GT and enjoying it without at any major niggles. I used to drive a GT 1.6 TDI (bought in Sep-2013) before I moved abroad. Had clocked close to 30,000 KM by Aug-2014. These days the car is used by my brother and sits at 78,000 KM.
Can relate a lot to you regarding the service experience at VW. Good cars, but unless you are an informed customer, the service centres are likely to charge you for random unnecessary add-ons.
Originally Posted by shibujp View Post
I bought the oil before checking the manual and as per the manual it recommends VW 505 01. Mobil 1 meets the VW 505 00 standards. I proceeded to do some research on which engine oil meets this standard in India and found that the so called recommended Castrol Magnatec does not either. If fact as per online information Castrol Edge or Castrol GTX seems to be closest as their data sheets explicitly specify that they meet the VW 505 00 standard while the Castrol Magnatec does not specify it.
I am not sure whether the Castrol Magnatec OE conforms to the VW 505 01/API CJ4/ AMEA C3 standards but wouldn't be surprised if this is another crapshoot.
Drive on,
Shibu.
Since our car was remapped at 10,000km itself, we had shortened the oil change intervals to 11-12k KMs. We also keep stock of a spare bottle of Castrol Magnatec Professional OE 5W40 in the boot. Identical grade of oil used across VW/Skoda workshops.
The Magnatec OE confirms to VW 505 01 standards (see picture below). However it has an API 'SM' rating. At times when we couldn't procure sealed bottles from the ASC, we had also procured Castrol Edge 5W40 as a backup. It isn't VW 505 01 rated, but has a higher API 'SN' rating.
Cheers,
Avinash
avinash_clt is offline   Reply With Quote
Old 1st April 2016, 18:07   #48
Thanked: 366 Times
Originally Posted by avinash_clt View Post
Hello Shibu,
30K in 11 months is a pretty good pace.
Where do you get the Professional Grade oil from? Do you procure it from the dealer ship? I was unable to find that grade in the Castrol lube shops.
This time the SM also mentioned that the oil has been changed and is now golden in color as opposed to the greenish color that the old one had. Never actually saw the Castrol oil so can't comment on the color. According to him, that have noticed much less smoke on cars that use this.
Drive on,
Shibu.
Old 1st April 2016, 20:45   #49
Thanked: 592 Times
Default Magnatec Professional OE oil
Drive on,
Shibu.
You are right. I was never able to source Professional OE from the open market either. I normally buy these extra bottles for backup, when needed, from the dealerships themselves. Last time when I procured couple of bottles in Dec'15, it was the same green color Professional OE oil. Don't know if they have changed afterwards.
Avinash.
Old 7th May 2016, 15:13   #50
Thanked: 366 Times
Got my PUC done. There has been a change in procedure that I have detailed here (Diesel PUC: At full throttle?!).
Here are the reading. Not sure what to make of them but its a pass. Anyway VW holds the dubious distinction of suddenly making diesel a suspect.
Name:  puc reading.jpg
Drive on,
Shibu,
shibujp is offline   (1) Thanks Reply With Quote
Old 21st July 2016, 07:44   #51
Thanked: 366 Times
Replaced my cabin filter with an aftermarket filter from Altech. The filter looks fluffier and the filtration element seems softer and thicker than the stock filter. Anyway let us see how this holds up.
Ordered it from Amazon for 695 rupees.
Here is the old filter. Looks pretty saturated.
The Polo is at 57800 kilometres.
Drive on,
Shibu.
shibujp is offline   (3) Thanks Reply With Quote
Old 31st July 2016, 09:59   #52
Thanked: 366 Times
Default Koni rear shocks installed
One of my grouses with the Polo is that the rear suspension while very comfortable is a bit too soft. I always wanted to sort this out on my GT. With this in mind I placed an order for a pair of Koni yellows on carpowergrid.com. Well I ordered yellows but when the order arrived I found that they were a pair of Koni Specials instead. Carpowergrid gave me a refund as the specials are cheaper than the yellows.
The Koni part number for the shocks are 80-2815. Specials are not as aggressive as Koni yellows so I was not too disappointed that I did not get them yellows as it would be a gradual introduction to suspension changes. I was nervous that I would end up with a very hard suspension.
I will detail the installation procedure in a DIY post and will focus on the adjustments and my current experience with the shock over the past two weeks. According to the literature available online, the adjustment mechanism must be turned clockwise for firmer and counter clockwise for softer.
Initial setting
I set it to one turn (360 degrees) below full firm and proceeded on a test drive. Here is where I realised that the advice to tune the suspension on bumps/bumpy roads and low speeds was spot on. On well paved and level grounds the car was flat and poised. However on bumpy B roads it was what I term "jiggly pop". You hit a bump and it would jiggle a bit a bit then come down with a sharp rebound. Not a very comfortable setting for a daiy driver. I quickly removed the shocks and made them - unknowingly - even firmer. The dang instructions on the package were the other way round and told me clockwise for soft and anticlockwise for firm.
Predictably this made the behavior even more pronounced and the car started the "jiggly-pop" behavior for every small depression or bumps even on good roads. But at the same time I did appreciate the firmness of the suspension. There was little of the rear end weight transfer on acceleration and braking. So much so, I tried it out for a week. But it's a difficult setting to live with on a daiy basis and you find yourself babying it on bumpy roads.
Current Setting
Over the weekend I removed the shocks and readjusted them. The current setting is 1.5 turns (360 + 180 degress) below full firm and the bumpiness has been completely dialed out. The suspension seems firmer than the stock at the same time delivering as ride that is comfortable. However only a week will give me a full picture of how it really is as I take it through the rigours of a daiy drive. I think I may be able to get away with a quarter turn (90 degrees) towards firm as well. But thats for another day.
Observations
Compared to the OEM shocks the Koni shocks are a bit heavier and a couple of milimetres larger in diameter.
The OEM bump rubber seems to be made of some mattress foam like material and the lower end has started disintegrating as seen in the shot below. Will have to get a repacement for this. Same condition on both sides. Perhaps I should try for those polyurethane ones.
The inner tube OEM shock when compressed and left starts pushing out immediately while the inner tube of the Koni shock does not. It has to be pulled out to extend.
Looking forward to one complaint sorted out.
Drive on,
Shibu.
shibujp is offline   (2) Thanks Reply With Quote
Old 10th September 2016, 23:12   #53
Thanked: 366 Times
Arrow Re: Shibujp's VW Polo GT TDI
Well so the Polo is past the 60K mark - 62K actually. Conducted a DIY oil change. Replaced the oil filter and used Mobil 1 0W - 40 fully synthetic oil. However the sourcing of parts is a serious headache and VW should either start OEM parts shops like Maruti or ensure that we can source it from their workshops.
The front suspension has now developed a tak tak sound on anything but a smoothly tarred road. Showing this at a VW service center produced a 30K estimate. Parts proposed to be replaced were the stabilizer links, steering box and the lower arm. Freakiing daylight robbery.
I decided to do some troubleshooting of my own in the meantime. Started by removing the stabilizer links and checking out the impact on the noise.
Drive on,
Shibu.
Old 12th September 2016, 21:44   #54
Thanked: 366 Times
Finally got down to trying to pin down the source of the tak tak noise on uneven road.
First I removed the front stabilizer bar links from both the left and right. The noise completely disappeared. However back from the drive I realized that I should have taken some precautions. The anti-roll bar should be tied up otherwise it will touch the front drive shafts. Luckily no lasting damage was done with the driveshaft surface being scratched a bit.
I had my previous links that were in decent condition when I replaced them with the TRW links. I refitted them back and test drove the car. Well - touchwood the noise has gone. A few hundred kilometers will prove how good the fix is. Suspension noises and their inadequate solutions remain a great avenue for service centres to fleece customers.
Drive on,
Shibu.
Old 2nd October 2016, 08:30   #55
Thanked: 366 Times
Default Diesel filter replaced
The diesel filter was the one item pending from my 60K service as I was trying to source an OE. Ordered one from spareshub.com and received it last week.
Filter made by UFI. Made in Germany.
OE cover indicates it is used for all VW group vehicles.
Connector pipes with the inlet and outlet marked. The inlet is usually covered with a cap as seen.
Name:  OE connector pipes.jpg
Installed!!
Removal
To remove the connector pipes, push and hold in the tabs on the fuel hose indicated by the red arrows above, push the fuel hose forward in the direction of the yellow arrow and pull back the hose to take it off. REMEMBER THE POSITION OF THE INLET AND OUTLET hoses. Do not mix them up.
Push out the black clips indicated by the green arrows holding the filter in place. Pull out the filter.
Installation
To install reverse the procedure. Pull the new filter in till you hear a click as the black clips lock into place. Then simply push the fuel hoses back over the respective inlet and outlet pipes on the filter. You should hear a small click as the connector locks in.
Post replacement, you may have to crank the car a couple of times to get diesel into the filter before you start up. There is also an option (the better one IMO) in the VCDS software to activate the diesel pump to fill in the filter before installation. However that option is not enabled on my version of the software.
Other updates
- Suspension fix still holding good after around a thousand kilometers.
- One of the Yokos developed a bulge after 20K kms, so waiting to get that replaced.
Drive on,
Shibu.
Old 9th December 2016, 07:20   #56
Thanked: 366 Times
Default Rear bump stops replaced
While swapping out my rear OE shocks for Konis I had noticed that the rear bump stops had reached their end of life with a deep crack(for want of a better word) developing at the lower portion where the bump stops hit the shock.
Sourced a new set of bump stops through sparehub.com. Cost me 1580/-. Got a pair made by Febi-Bilstien. (part no : 23410 Catalog : http://www.febi-parts.com/?lang=GB)
I had contemplated going in for PowerFlex Purple brand of bump stops as earlier suggested by Shankar but decided against given the cost and also since I could get more stiffness since my rear Koni shock were adjustable. They would have been a good option perhaps, had I been running OE shocks.
Old v/s new
Installed
Sorry about the picture quality. Was using my mobile covered with a plastic bag which was masking the camera.
Post Installation
After installation, the ride has actually become softer which means I need to dial in more stiffness into the shocks. Unfortunately I also ended up slightly stripping the thread on the one of the top mount bolts. Not having a replacement, I had no option but to use it. Just hope I have not damaged the thread of the nut too much. So that is something else I need to get sorted out.
Drive on,
Shibu.
Difference between Polo R Cup's 1.6 TDI and Vento/Rapid's 1.6 TDI kryptonite Technical Stuff 21 12th February 2015 01:05
shibujp's Swift Diesel Long term report - 1,30,000 kms update shibujp Long-Term Ownership Reviews 186 13th January 2014 23:12
