Old 30th May 2016, 14:26   #46
Dr.Naren's Avatar
Thanked: 7,873 Times
Default Re: My Maruti S-Cross 1.6L Alpha - Pearl Arctic White
The entire headlamp unit is sealed, hence replacing only the projector is not possible as per OEM standard. I feel the projectors would easily accommodate a 35W unit but from where can we source the D5S type HID since I believe it's one of the rare ones.
Stock HID bulbs are Osram D5S. Culprit is non clear leans and small reflector bowl of stock projector. I am planning to change the entire projector setup from Xenon Planet after few months.
Dr.Naren is offline   (1) Thanks Reply With Quote
Old 30th May 2016, 14:39   #47
Thanked: 94 Times
Changing the entire projector assembly is a waste IMO, as it definitely spoils the OEM look of the stock headlamps and if you are finding vibrations in a Manufacturer's unit, I am not sure of workmanship of a Third party installation.
PS: If you had a thought of going for aftermarket projectors, you could have gone for Zeta(Losing Rain sensing wiper, Leather seats,Leather wrapped steering wheel and Auto IRVM etc) you could have saved nearly ₹1lac !!
Cheers !!
kashyapz8055 is offline   Reply With Quote
Old 30th May 2016, 14:58   #48
Dr.Naren's Avatar
Cheers !!
I am planning to keep up the OEM look. New projectors can be fit into stock shrouds itself. I can get a good quality projector setup within 20K from Xenon Planet with warranty.
Zeta 1.6 is very low on production and dealer adviced me to go for Alpha.
Old 30th May 2016, 15:05   #49
Sree73's Avatar
Thanked: 761 Times
Cheers !!
Please note: 1.6 Zeta is not the same in features to that of 1.3 Zeta.
In 1.6 Zeta, you will miss out Cruise control also.
Sree73 is offline   (2) Thanks Reply With Quote
Old 30th May 2016, 15:23   #50
Dr.Naren's Avatar
Auto AC is also skipped in 1.6 Zeta. I do not regret buying top of the line Alpha variant. I have spent 24K on alloys and will spend another 20K for better projector setup in few months .
Dr.Naren is offline   (2) Thanks Reply With Quote
Old 30th May 2016, 15:45   #51
Thanked: 94 Times
Ya, sorry I missed listing CC, an useful feature in highway rides.
No regrets buddy !! You have a Pearl with you and adding few more diamonds will make the Jewel more attractive !! Do keep us updated on your projector upgrade.
kashyapz8055 is offline   (1) Thanks Reply With Quote
Old 30th May 2016, 15:53   #52
Gosu's Avatar
Thanked: 37 Times
Heartiest congratulations on finally getting home the 1.6 S Cross. The Breeza alloys did make a huge difference to the side profile of the car. Looking so much better.
So which of the five cars do you drive most now? (i'm guessing the 1.6 DDIS! )
Gosu is offline   (1) Thanks Reply With Quote
Old 30th May 2016, 16:03   #53
Dr.Naren's Avatar
Thanks buddy!!
My daily drive is around 80 KM and I alternate between Baleno and S-Cross. Kwid/SX4/Grand i10 I drive once a week .
Dr.Naren is offline   Reply With Quote
Old 31st May 2016, 10:12   #54
Dr.Naren's Avatar
Pics & Price of few accessories
Sports Pedal (295) & Designer floor mats (1390)
Areon gel car freshener(300)
Silicon key fob (200) & Key chain (150) from Amazon
Dr.Naren is offline   (3) Thanks Reply With Quote
Old 1st June 2016, 16:42   #55
Dr.Naren's Avatar
UPDATE : FE
I have got FE of 17.5 KMPL (tankfull method) for last 300 KM drive. MID showed 17.9 KMPL. AC was on full time in auto mode. Majority of the drive was on highways with moderate traffic.
Old 2nd June 2016, 18:39   #56
Dr.Naren's Avatar
Today I got to try 6 th gear for a stretch of around 2 KM. Car does around 1600 /1700 RPM in 6 th gear at 100 KMPH. I was surprised to see how well the car pulls above 100. Car was literally picking up speeds even in 6 th gear. I love my 1.6 more after each drive . I just can't wait for the run in period to get over. I have decided not to revv above 2500 RPM during run in period. Current ODO is 550 KM.
Old 2nd June 2016, 19:56   #57
Sree73's Avatar
Thanked: 761 Times
I can understand your impatience for the run in period to get over
One thing I really like about the S-Cross is the stability it provides at higher speeds. This car really masks the speed. You may not realize the actual speed if you are not looking at the speedometer.
Also, cornering at high speeds is also pretty good. Very little body roll and the confidence it gives for the driver is tremendous.
I have driven my 1.3 at higher 3 digit speeds just to check the performance. (Do not advice any one to drive above the permissible speed limits on our roads). Another aspect about this car is that driver / passengers will never feel the fatigue even during long trips.
Old 2nd June 2016, 19:59   #58
Dr.Naren's Avatar
I second that. There is good performance backed by rock solid stability at higher speeds. As mentioned in my review, this car drives like an European car .
Old 5th June 2016, 01:38   #59
swiftnfurious's Avatar
Thanked: 6,571 Times
.... I just can't wait for the run in period to get over. I have decided not to revv above 2500 RPM during run in period. Current ODO is 550 KM.
I think you should raise the bar (rpm) now. I did a 300 km-300 km-400 km interval on my Swift D for raising the rpm limit while running in. I used to get phenomenal FE even after 80,000 kms on the ODO. Not sure the trick worked, but am sure it didn't hurt (the engine). And the works manager of AVG MA$$ told me that the internal components were in top condition at that mileage.
300 kms - upto 2000 rpm
301 - 600 kms - upto 3000 rpm
601-1000 kms - above 3000 rpm (whenever and wherever possible).
PS : There is no scientific backing for the above process, I just wanted to raise the rpm limit for the car during the run-in and did this on my own. I still have a feeling at the back of my mind that I read about this somewhere.
swiftnfurious is offline   (1) Thanks Reply With Quote
Old 5th June 2016, 11:38   #60
Dr.Naren's Avatar
Thanks for the suggestion!!
Owners manual also says not to maintain steady speed during run in period. I think I can go till 3000 RPM . This engine is so free revving and pulls cleanly above 1700 RPM.
My Brown Little Hippo: Maruti S-Cross DDiS 200 Alpha sandygordon Long-Term Ownership Reviews 170 19th May 2018 21:52
Unlimited Desires into One Arctic White Maruti DZire ZDi: My Review CRtorquefan Test-Drives & Initial Ownership Reports 22 20th December 2013 00:11
What Color in swift VDi?Metallic Sunlight Copper or Pearl Metallic Arctic White. Poll SumitBahl Hatchbacks 54 4th May 2009 14:26
