Closed Thread
Old 22nd February 2010, 10:56   #421
suman's Avatar
Thanked: 257 Times
Originally Posted by architect View Post
I think the maintenance issues seem reasonable considering your odometer reading. Autolinks does seem to be very co-operative.
They are very cooperative - I'm beginning to hear bad stuff about ABS Motors now so I intend sticking with Autolinks. I think they're the best in the NCR for 4x4 Safaris - in fact, one of their key 4x4 technicians had quit & joined ABS, I just heard that he's come back (along with a few others who'd gone).
How's the Fiesta going on and what is the likely replacement? Linea T-Jet?
She's doing OK but will be looking at replacing her sometime this year. Getting close to the 100k mark, check out my Fiesta thread which I've recently updated -
http://www.team-bhp.com/forum/long-t...ml#post1714201
Linea T-Jet is definitely one of the contenders, depending on whether or not the rear seat legroom & space is adequate. Going to start checking out some options in the next couple of months.
suman is offline
Old 22nd February 2010, 15:31   #422
unni.ak's Avatar
Thanked: 80 Times
Great to know that the Beast is running along well. I'm surprised that you got the discs changed under warranty. I have a shudder issue when braking, which has been diagnosed as warped discs, and warranty is not applicable since I've crossed 10k kms :-(.
Oh, just love the rev range of the 3lt DICOR. Engine is barely more than ticking even when running at full blast
unni.ak is offline
Old 22nd February 2010, 15:39   #423
suman's Avatar
Thanked: 257 Times
Unni, you should put pressure on the buggers. If you read my Fiesta thread, Discs were changed twice by Ford & both times under warranty. They cribbed like hell but they eventually gave in. The first time was at odo reading 9,037 (OK, below 10k kms) but the second time was at odo reading 45,668. I wonder if this is an achilles heel for them which is why they try not to acknowledge it. Of late, I can feel a slight shudder sometimes but this time around, I will try & take the local garage route to get them machined a bit!
You said it!
suman is offline
Old 22nd February 2010, 17:07   #424
unni.ak's Avatar
Thanked: 80 Times
Let me try pressure tactics then!! I'm yet to change them, so hoping it works. Wonder who is the disc manufacturer. We are going OT here , thanks for the tip.
unni.ak is offline
Old 3rd March 2010, 11:52   #425
suman's Avatar
Thanked: 257 Times
Default 80k kms around the corner.....
The Beast is approaching the 80k kms mark so I've decided that this is a good time to leave it with Autolinks to get the AC compressor replacement completed along with the service. Will drop in the vehicle tomorrow morning.
Apart from this, the steering has been feeling a bit hard of late if I try to steer full left lock while stationary (sometimes need to do this while turning in a tight space). Autolinks have recommended change of the Steering Gearbox under EW. This is also a time consuming process (unit taken out & sent to manufacturer for part replacement) so I guess the vehicle will be out of action till around the middle of next week.
Will keep you guys updated once its back.
PS: If anyone asked me what I hate about the 3.0 litre Safari, the answer would be simple - the goddamn Tailgate rattle. It just doesn't go away, it keeps resurfacing every 5k kms. I keep telling them to change the rubber beading (its worn out a bit & become hard) but they keep trying to save me money and try every other trick in the book - but nothing works!
suman is offline
Old 3rd March 2010, 12:25   #426
tsk1979's Avatar
Thanked: 16,421 Times
There is a solution mentioned on the 2.2 problems thread. Basically, you stick a think rubber sheet(available with cobblers) on the bottom where the tailgate meets the body. Bye bye rattle
tsk1979 is offline
Old 3rd March 2010, 12:30   #427
Rahulk76's Avatar
Thanked: 204 Times
That's our workaround to reduce tailgate rattles.. what about the manufacturer. I am getting tailgate rattles now in 21k done safari
Is tailgate rattle ki toh...
Rahulk76 is offline
Old 3rd March 2010, 12:38   #428
suman's Avatar
Thanked: 257 Times
Exactly! The other thing is - the positioning of the strikers & other hinges are very different in the 3.0 litre (vis a vis the 2.2) so some of the "jugaad" may not work. And I ain't going to put up a rubber sheet or whatever - maybe I'll just get the beading changed if its not too expensive.
suman is offline
Old 3rd March 2010, 14:37   #429
Thanked: 146 Times
Suman, One of the things done in the 2.2, for those with the rattle, was using the Sumo's rubbers. Did you go down that path?
And talking about "jugaad", even the mouse pad have been put to good use by one of ours!
HappyWheels is offline
Old 16th August 2010, 17:00   #430
suman's Avatar
Thanked: 257 Times
Default Fancy mileage!
On the way to work this morning.....
Tata Safari Dicor 3.0L VX 4x4 - Leh'd, 105k kms up & Auf Wiedersehen!-16082010044.jpg
Latest (not so good) news being that I walloped a metal barrier & shattered the glass (heated) of the right ORVM. The cover is fine, the mechanism is working perfectly & no damages other than the glass . The original Plate & Glass are not sold separately, and the options available to me were -
  • Buy complete OEM unit for Rs 4,000 plus painting charges of Rs 500
  • Go to Chawri Bazaar & look for original plate & glass (heated) & hope to find one for Rs 200 (as Tanveer had)
  • Fix complete Local unit (heated) for Rs 1,450 plus painting charges of Rs 300
  • Fix local non-heated mirror only for Rs 150 (not convex but 1:1)
After a lot of thought & after picking up the complete Local unit, eventually went in for the Rs 150 option on a purely temporary basis. Have requested a FNG (courtesy Gd1418) to try & get hold of plate & glass of Local make in the meantime. If not available, will head to Chawri Bazaar in a few days & try & get hold of one like Tanveer did.
The local Rs 150 one is obviously not a long term solution.......
Quite a bit more to update actually, will do so in a couple of weeks so watch this space
suman is offline
Old 16th August 2010, 17:24   #431
tsk1979's Avatar
I suggest for temporary use you also pick up a 50rs stick on convex mirror. It will help you get by as the 1:1 is horrendous. I have it on the indica, and its totally useless, as area shown is very limited.
If you can get a local make non heated "convex" mirror, it will be great!
tsk1979 is offline
Old 16th August 2010, 17:25   #432
mercedised's Avatar
Thanked: 177 Times
Fascinated more than you! Me it is. I always loved a 3.0 more than the 2.2 version because of its torque. Could you please elaborate if a 3.0 (without any extended warranty) is a cheaper and healthier vehicle after 50K kms.
Thanks.
mercedised is online now
Old 16th August 2010, 18:09   #433
rajismine's Avatar
Thanked: 252 Times
You said it!
well I got my Discs changed under Extended Warranty at 30K Kms
But these guys dont change the disc alone...they said u pay for the pads as they are wear & tear item and they will get discs in EW and I agreed...so paid rs 1750 odd and got discs of around Rs 2600 free
rajismine is offline
Old 16th August 2010, 23:31   #434
architect's Avatar
Thanked: 597 Times
Convex blind-spot mirrors stuck on 1:1 ORVMs work just fine. I have had them on my car (the original ORVMs are nearly 1:1) and it just takes a day or two to get used to them.
architect is offline
Old 17th August 2010, 12:27   #435
suman's Avatar
Thanked: 257 Times
Ya, I was planning on getting a stick on convex once the FNG was successful (or otherwise) in getting a local heated one.
I can live without the heated one but can't live without the convex!
Thanks mate. I would be wary of picking up a 50k plus run Dicor (be it a 3 or a 2.2) without extended warranty as you could have expenses arising out of wear & tear. Just to give you an example, post 50k kms, the following have been replaced in my vehicle under EW -
  • Differential Track Lock Kit
  • Wheel Cylinders - 2
  • Power Window Regulators - both rear ones
  • Brake discs (I was lucky they did this under EW)
  • Self starter
  • AC Compressor (more preventive maintenance than any issue as such)
  • Steering Box
As you can imagine, these items would have set me back by quite a bit of money had it not been for the EW. Heck, each Power window regulator switch would have set me back by 4k
As I approach the 90k kms service, I'm mindful that the Beast will be out of EW at the end of October so I'm going to be going over the vehicle with a fine tooth comb to see what else can be "claimed" under EW. I'm planning to push for a clutch replacement but I don't see them agreeing. Not that I have any issues with the clutch but its just "preventive maintenance" as they say
suman is offline
Closed Thread
January 2007 Tata Safari 3.0 DiCOR EX 4x4 Running Report dicorex4x4 Long-Term Ownership Reviews 128 27th October 2012 14:11
Tata Safari Dicor LX 4 X 2 or Safari Dicor EX 4 x 2 Digitalmafia SUVs, MUVs & 4x4s 55 1st June 2009 17:31
Tata Safari DICOR 3.0 4x4 4x4addict SUVs, MUVs & 4x4s 16 21st April 2009 02:55
Opinion wanted - Dicor VX 4X4 vs Endeavour XLT 4X4...updated Now Booked Dicor VX 4X suman SUVs, MUVs & 4x4s 80 1st April 2009 14:11
For SALE TATA SAFARI DICOR LX 4x4 nitinbhag Shifting gears 2 31st August 2006 13:38
