| | Thread Tools |
| | #61 (permalink) | |
| Team-BHP Moderator ![]() | Quote:
__________________ .--- ..- ... - - .-- --- -- --- .-. . -.. .- -.-- ... - --- --. --- !! | |
| | #62 (permalink) | |
| BHPian | Quote:
http://www.autoshop101.com/forms/h61.pdf I'm having similar smoke problems with my Dicor (Feb'07 model, done 3000kms). Will let you know after my visit to the service station about my experience.
__________________ Testdrive...Go 4X4 it! | |
| | #63 (permalink) |
| BHPian Join Date: Sep 2005 Location: Pune
| Well Bad News.....(My Bad Luck i pressume...) While diaganosing smoke problem when accelerating..workshop and I noticed leaking turbo Findings: Complaint:When I push down on the gas pedal, black smoke comes out the exhaust pipe and it feels like the car is dragging or being pulled back and it stops accelerating. Amazing Findings :( Turbo is leaking Oil Intercooler is filled with oil and turbo hose back to crankcase was leaky as well (its ok to have a some oil in the Intercoolers by design ( bless blowby hot gases vapours)) like a quart or so . This caused poor acceleration or running rich. The breather box has the gasket blown off (faulty oil seperator), & clogged the breather causing the turbo to blow oil through its seals when i accelerated or I'd say when the boost was high. (from google: unrelieved blowby increases the oil pumped to the turbo and not drained, causing excess oil in the turbo, increasing crankcase pressure, and forcing this oil out the exhaust. ) This caused turbo to leak oil under pressure into exhaust (cause of my dark clouds of smoke left behind when hard acceleration). I was already planning a long trip this coming weekend and feeling lucky that it was seen by workshop in time otherwise it would have been a horrible experience stuck in middle of no where. SUV is with them and they are working hard on it to resolve the problem. In the mean time i can just wait and watch (LOL) Latest update I got was that they had inspected turbo and found it OK. Cleaned intercooler with gasoline to get rid of bloody muck. turbo seals ok.. hose pipe refitted properly. replacing faulty oil seperator. CAUTION: Don't drive with the turbo blowing oil as it will clog the cat converter or as well poison it permanently. No wonder why my catcon was choked with carbon like hell. More updates as soon as I get ... Any thoughts ? what more to have checked.... (by the way I religiously follow idling for 1 min before rolling off and during parking) Last edited by Rahulk76 : 16th May 2007 at 20:52. |
| | #65 (permalink) |
| nope.. you have a look at your under carriage cover and voila they are covered with some foam material on the side facing the inside towards engine bay ....no leaks will fall to ground untill those foams are soaked wet.. even if minor.. which serious.. i assume that i was running leaky turbo for some time now...How long i really dont know |
| | #66 (permalink) |
| allrighty, had a word with regional tata office and worshop managers following issues corrected @9300KMS 1. Latest software/firmware upadated to the ECu by delphi 2. smoke was due to egr being open at the wrong time.(corrected now) 3. oil leak apparently seems to have poisoned the catcon (replacement on the way) 4. all major complaints in vehicle well attended to except that i guess i need to live with hard engagement of 1st and 3rd gear, unlike 2,4,5th and reverse gear.(may be a point to raise later as I am not satisfied.) (ZEROCOST) well lets see, i hope sincerely that the major faults have come to their end. Later...when 10k srv is done. |
| | #67 (permalink) |
| Second Service has been completed today without much fanfare. total cost incured was Rs 1000 approx, owing to wheel rotation alignment oild filter etc and etc. I myself brought Castrol GTD from castrol dealer and gave it to workshop to be put in the safari. so another 1025.00 for 6.5 ltr of engine oil delphi tvs people were called in to check the ECU again in static and dynamic conditions and found the egr solenoid vaccum switch(drat padmini make was acting funny.. sometimes working and sometimes not) green signal from all concerned technicians was given at approx 7:30pm that all was fine Some things underwarranty which were changed catcon @14k egr solenoid switch @326.00 Paid were rotation, alignment and oil filter. Something i liked about the car after it was serviced that it runs much better and feels tighter . Hope it continues like this until next serviceStill to be watched out are the turbo leaks etc incase there are any or excessive smoke problem. I think i need to keep the rpm >1500 and aadapt to this technique and its only when rpm is less than 1500 in gear >2 at speeds of 30-40, it gives baloons of smoke. (senior members can advise on this) thnks |
| | #68 (permalink) |
| BHPian Join Date: Jul 2004 Location: Madurai
| Rahulk, that humming noise when you switch on the AC is the bloody AC condensor fan. Get it replaced. All you need to do is switch on trhe AC wait for the hum and then physically disconnect the fan. Voila, the hum is gone. Useless Sanden!!!!
__________________ Live Life King Size! |
| | #69 (permalink) |
| BHPian | As posted on my ownership report thread, black smoke at low rpms is caused by engine knocking. Usually while going over a speed breaker if you dont shift into 1st or if the momentum is not good enough for 2nd, there will be engine knocking which causes black smoke as you accelerate. This was explained to me by the TASS Sr.Wks Mgr
| | #70 (permalink) |
| BHPian | I see smoke only when I'm at sub 1000 rpm in 3rd or 4th AND I'm trying to accelerate. I should be downshifting as per the manual. My 10000 km service was done 2 weeks ago. No issues. I've been selected for this year's JD Power survey for initial satisfaction - the interview is in a couple of days time. |
| | #72 (permalink) |
| Team-BHP Moderator ![]() | @dicorex4x4, since your workshop allows you to choose your own oil, next time get the "castrol GTX diesel" instead of GTD. Its a higher standard oil than the GTD.
| | #74 (permalink) | |
| Quote:
Therefore I went with castrol GTD only. Last edited by Rahulk76 : 1st June 2007 at 17:01. | |
| | #75 (permalink) |
| Team-BHP Moderator ![]() | I think they were talking about Castrol GTX. Castrol GTX diesel is a higher grade oil, and is very rare. Not available with most dealers. GTD is also a good oil, and they get a good discount on GTD as the workshops buy drums.
| Thread Tools | |
Similar Threads | ||||
| Safari DICOR 2.2 VTT - Ex 4x2 - Artic Silver | dadu | Test-Drives & Initial Ownership Reports | 383 | 30th June 2008 10:59 |
| My Red Cherry - Swift VDI : 15000 KM Report | DieselFan | Long-Term Ownership Reviews | 43 | 5th May 2008 19:09 |
| My New Safari Dicor EX 3.0L 4x2 LTR Thread | reachmash | Long-Term Ownership Reviews | 52 | 11th February 2008 18:19 |
| Tata Safari Dicor LX 4x2 (Feb2007) ownership report EDIT: 11500kms update | testdrive | Long-Term Ownership Reviews | 105 | 3rd January 2008 13:43 |
| For Sale: Tata Safari DICOR VX 4X2 | speedmiester | Shifting gears | 10 | 12th October 2007 16:35 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
