Old 20th October 2017, 10:06   #46
comfortablynumb's Avatar
Thanked: 1,049 Times
Default Re: Toyota Corolla: Our pre-owned workhorse
Originally Posted by sukiwa View Post
Now we know where from this Corolla gets all the 'low-end torque'; blessed by power lines]
Lovely pics! Where is this location?
Btw, Suhas sir, do you conduct photo sessions of desi models too?
Cheers,
Vikram
comfortablynumb is online now   (1) Thanks Reply With Quote
Old 22nd October 2017, 10:04   #47
Thanked: 741 Times
Hinjawadi, Phase 3.
Why not, when is Scout available?
sukiwa is offline   (2) Thanks Reply With Quote
Old 23rd October 2017, 10:13   #48
She is available whenever I am, i.e. every weekend Will ping you as soon as I get the annual detailing done; just waiting for the rains to stop!
Cheers,
Vikram
P.S: Sorry for hijacking your thread, Asit!
Old 30th October 2017, 00:02   #49
asit.kulkarni93's Avatar
Thanked: 677 Times
Update-
The ODO is nearing the 83k kms mark(80kms more to go). This month the Corolla has run less because my brother had his vacations and he was in Bahrain so I was using the Nano since the last 15-18 days+ no outstation trips. The LED bulbs installed were initially having some alignment related issues, I had tried a few settings by adjusting it manually but it didn't feel right. Visited my local car electrician and he helped me out in setting them right. In December & January I will be taking a few road trips and then only can I give a final verdict on the reliability of these bulbs.
The high beam
The low beam
With BHPian YCJ clicking the pics
Aligning it in my parking
Asit
asit.kulkarni93 is offline   (5) Thanks Reply With Quote
Old 30th October 2017, 21:18   #50
R2D2's Avatar
Thanked: 2,198 Times
Asit, thanks for sharing. A question - which high beam LED bulbs did you procure and from where? I'm interested in using HB3/9005 LED bulbs for my Altis' high beam. The low beams are factory fitted HIDs. I'm looking at a plug-n-play solution.
Old 31st October 2017, 09:05   #51
Thanked: 677 Times
You can check out the Philips LED's. A fellow BHPian from Pune has been using them on his Vento since 1 year. The LED's I am using right now were ordered through aliexpress. Until now I haven't faced any issues with them but not too sure about their long term reliability. I have a few night drives planned in December. I will be sharing the details once I am sure about their reliability and durability.
Asit
asit.kulkarni93 is offline   (1) Thanks Reply With Quote
Old 31st October 2017, 09:22   #52
R2D2's Avatar
You can check out the Philips LEDs. A fellow BHPian from Pune has been using them on his Vento since 1 year
The VW Vento uses H4 IIRC which is in stock on Amazon India. Waiting for Philips LEDs to be available in the HB3/9005 model.
I have read about Chinese made parts being a little flaky, not something I'd like to risk with critical safety parts like headlamp bulbs. That said, I look forward to your review.
Old 4th November 2017, 09:53   #53
Thanked: 165 Times
A question to all petrol Corolla / Altis users - At what point does the temperature needle stay at in your cars during city / highway drives?
Can Purolator parts (air filter, oil filter, fuel filter) be used in the Altis and safely?
Swapnil4585 is offline   Reply With Quote
Old 4th November 2017, 12:39   #54
Thanked: 677 Times
The temperature needle normally stays at the 50% mark. Will check it again when I take the car out. I am currently using a purolator oil filter.
asit.kulkarni93 is offline   Reply With Quote
Old 4th November 2017, 12:44   #55
R2D2's Avatar
In the Altis the temp gauge needle remains at just about 1mm over the 2nd notch from Min/Cold. It has never shifted higher even in stop and go traffic, highway driving with or without AC.
PS - One may assume 2nd notch is the 50% mark, just like in the 9G Corolla. Here's a pic from a Pakistani website Altis 10G Instrument Cluster
I'd recommend OEM Toyota/Denso only. Always. Use Bosch or Purolator only in an emergency and shift back to Denso ASAP.
IMO Purolator India doesn't have the same standards of quality they do overseas. You can easily discern the difference in construction quality of a Denso and the cheaply built aftermarket filters available in India.
R2D2 is offline   (1) Thanks Reply With Quote
Old 6th November 2017, 12:33   #56
KK_HakunaMatata's Avatar
Thanked: 522 Times
Hello guys,
I am facing an issue with driver side seat belt on my 2006 Corolla.
From the past week, I am not able to pull the seat belt and it seems it has got struck inside and just not able to pull.
Could any of you throw light if you have come across this? Should I get the entire seat belt changed or is there any repair possible.
KK
KK_HakunaMatata is online now   Reply With Quote
Old 6th November 2017, 16:18   #57
R2D2's Avatar
I think you should take it to an ASC or FNG for an inspection. If it has been damaged or compromised in any manner you should replace it with an original part. Thing is, a seat belt is a life saver & I for one strongly believe there should be no compromises on safety.
Old 6th November 2017, 16:26   #58
Thanked: 522 Times
Yes, thanks R2D2. Planning to take it to FNG but couldn't manage this week. In fact, i am not using car for this reason alone, I borrowed my BIL car for a outstation trip as I didn't wanted to take any chance on this.
KK
Old 21st December 2017, 14:18   #59
yogeshnagpal's Avatar
Thanked: 81 Times
Asit, and other corolla owners here.
I got a call last week from Lakozy Toyota, Mumbai.
They mentioned my vehicle No, and said that the vehicle was a part of the airbag inflator recall, and they would do the replacement free of cost.
I've fixed up an appointment and will be going coming Sunday.
So - I'm the second owner of the vehicle and I always service the vehicle at an FNG. The previous owner used to go to the Authorized Service Center.
However, they were able to track down my number from the insurance company and proactively called me up.
I would highly recommend you guys to please check with the service center's if your car is a part of any such recall (if you haven't already got a call).
Good thing is that Toyota dealership went beyond their boundaries to track down my number and proactively called me up.
Cheers,
Yogesh.
yogeshnagpal is offline   (3) Thanks Reply With Quote
Old 21st December 2017, 16:51   #60
Thanked: 677 Times
...the vehicle was a part of the airbag inflator recall, and they would do the replacement free of cost.
Thanks for the update yogeshnagpal. Is this a new recall? I got the replacement of my Corolla's airbag inflators under warranty last year at dsk Toyota in July.
Our family workhorse: Pre-owned Maruti WagonR asit.kulkarni93 Test-Drives & Initial Ownership Reports 27 16th October 2015 21:17
Pre-owned Optra / Pre-owned Accent CRDi / New Tata Indigo ashthedivx Sedans 15 24th February 2007 14:03
pre-owned Baleno vs pre-owned Accent vs ikon flair rohantn Sedans 36 16th February 2007 20:27
pre-owned Wagon R or pre-owned Bolero - pls advice rohantn Hatchbacks 26 7th February 2007 17:02
Pre-owned Ford mondeo vs Pre-owned Skoda octavia azifali Sedans 6 24th July 2006 13:46
