| Long-Term Ownership Reviews Ownership reports, of Indian cars, spanning over several years and thousands of kms |
| | LinkBack | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Aug 2006 Location: Chennai
| Completed the first 1000 kms (1100 actually) peacefully and just completed the first free service. Car was given for service with two complaints. 1. Central Door Lock / Unlock not working either from the switch by the Driver Door Side or through the manual key since fitting the Remote Door Opener. 2. Slight vibration when AC is on and vehicle is idling. Post Service: 1. Dealer maintains that Central Door Lock / Unlock will not work through switch or key if Remote Door Opener is installed. They maintain that this is the way even with VXi which comes with stock Remote Opener. If any VXi Owner can let know, it will be of help. 2. Vibration is reduced. 3. All scratches (Scratch # 1 caused by auto on the passenger side door and scratch # 2 seems caused delibrately by someone on the Right rear side) have been removed by the Dealer through polishing. 4. Engine Oil and Oil Filter have been changed (Rs.710). 5. Changed to 90/100W (GE Bulbs and PMP Relay). Difference is quite evident and inspiring. The 1100 Kms have been done mostly in city (750 kms) and 350 (high way). THe city driving is mostly on dense traffic. I consider myself blessed if I could reach 4th gear. A/C on 100% of the time. So far, filled in 100 litres of petrol and FE stands at 11 kms (combined). I have not measured the FE by Highway / City separately. All driving limited to 2500 RPM (max) and 90 kms/hour (max). Plan to do the next 1000 kms on 3000 RPM (Max) and 120 kms / hour (max). Vehicle running is very smooth. Gear selection is quite slick now. However, first gear feels little rough when compared to others. Tire noise intrusion (since switching to alloys and tubeless 185/65/R14) is still there. Else, traffic noise is very minimal inside the cabin. Currently running with tire pressure of 29 psi. A/c works very well and cabin cools down quite fast. Suspension feels taut and is able to take most of the small pot holes with ease. Getting used to the car is till happening since I have been driving a M800 for the last 8 years. However, driving around both on the highway as well as in the city, is quite a pleasure. ![]() |
| | #3 (permalink) | |
| Senior - BHPian Join Date: Dec 2005 Location: Weekdays at DetroitOfIndia (Chennai) & Weekends at VeniceOfTheEast (Alappuzha).
| Nice review, Subbu. And good to know that you are enjoying the experience. Quote:
The headlamp intensity is one thing I found inadequate in the Baleno and would like to do something about it.
__________________ Suzuki Baleno : 91bhp @ 5500rpm, 130.5Nm @ 3000 rpm, 14kmpl in city @ 100% a/c. Fun & economy needn't be mutually exclusive. | |
| | #4 (permalink) | |
| BHPian Join Date: Dec 2006 Location: Bangalore
| Quote:
No Cuts required for installation I just got mine done with 130/100 Philips Halogen and PMP Relay with the relay cable, it's just disconnecting and connecting. @Subbu, Nice review yaar, Try using the 5th Gear at 40Kmph it works just fine for me... You can run on 4th gear even if you are doing 25kmph. Try this and let me know I do this on my car and it just works fine. Thanks, Mega | |
| | #5 (permalink) | |
| Senior - BHPian | Quote:
| | #6 (permalink) |
| Supremo... Got it changed at Khivraj Motors itself. Paid Rs.1000/ for the same. May be slightly higher but did'nt have the time to go to the market. The GE Bulbs carry 6 months warranty. No cutting / slicing etc. They install in 15 minutes flat. |
| | #7 (permalink) | |
| Quote:
| | #9 (permalink) | |
Try 27psi .. recommended is 25 for city and 29 for highway.
__________________ PIGZILNKILJBSCOMB | |
| | #10 (permalink) | |
| BHPian | Quote:
__________________ Life is a learning and Change is the law of nature ! | |
| | #11 (permalink) | |
| BHPian Join Date: Mar 2005 Location: goa
| Quote:
My stock VXi with remote has no such issue. I can use the central lock with a key or with the remote. I often do lock it with the key only, especially if it's going to be overnight in my lock-up garage, saves the battery since the alarm is not armed.
__________________ Baleno Vxi 05 Ritz Zxi 09 | |
| | #13 (permalink) |
| Yes it is Halogen. Bulbs cost Rs.150 per bulb (Rs.300 for 2). Relay / Wiring plus fitment charges. I paid Rs.1000/ totally and it was fitted by the dealer during service. You should be able to get it done cheaper outside. |
| | #14 (permalink) |
| Senior - BHPian | Most of the stock cars in the market these days really have inadequate lighting power..maybe this is one is in the list of manafacturers cost cutting list I changed mine stock ( 55/60) to 90/100 Phillips Blue Vision and paid a total of 1400 bucks with no cutting the wires, quick installation and now there is a world of difference
__________________ I have terrible reflexes- I was once run over by a car being pushed by two guys !!!!!!! |
« Product Complaint:Indica V2 Petrol MPFI, LXI EII
10000 KM report on the Suzuki Swift - updated to 20000km »
| Thread Tools | |
Similar Threads | ||||
| Ford Fiesta 1.6 sxi ABS--1yr review at 8500 kms -- Now updated to 2 yrs 14000 kms | vnabhi | Long-Term Ownership Reviews | 134 | 28th January 2010 00:27 |
| My Logan DLE: Updated to 52000 kms | pugram | Long-Term Ownership Reviews | 109 | 15th January 2010 13:33 |
| My New ANHC: 1000 Kms Review | Fstlndrive | Test-Drives & Initial Ownership Reports | 19 | 12th January 2010 15:28 |
| Safari Dicor 2.2 VX – Updated 7,500 kms | Highway Star | Test-Drives & Initial Ownership Reports | 30 | 17th April 2009 16:55 |
| Is it advisable to travel about 700 Kms to/fro after 1000 Kms before first service? | TrueDreamer | Route / Travel Queries | 14 | 16th April 2008 21:42 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653
