Old 7th May 2009, 17:27   #136
Buy brake pads from outside, they are available for ~ 1500/-
bhp1 is offline   Reply With Quote
Old 9th May 2009, 09:27   #137
Thanked: 139 Times
It seems that the brake discs are also worn a bit and may need skimming (the Toyota pick up driver said scanning). I know brake pads cost~Rs. 6K. What about brake discs (all 4). He said 2 pairs are cheap.
vasudeva is offline   Reply With Quote
Old 10th May 2009, 07:53   #138
ImmortalZ's Avatar
Thanked: 312 Times
Honda Civic brake discs are around 6K a pair. Skim them and use them. You have nothing to fear as long as the minimum thickness is maintained.
Old 10th May 2009, 18:10   #139
Thanked: 139 Times
Finally got all the four brake pads changed at around Rs. 6K and 2 rear discs at Rs. 4.5K. Around means all taxes which I am too lazy to calculate and post the exact cost in Rs.
Old 25th May 2009, 12:10   #140
Thanked: 139 Times
I have a small query regarding service intervals. Corolla has a recommended interval of 1 yr/10000 km. That was fine when I used to drive around 18K per annum. However, now I drive at an average of around 7K per annum. Thus, following a 1 yr interval would mean 3K still to go. Should I follow 1 yr (regardless of mileage in that period, which would most probably be 7-8K) or 10000 km (even if it means a service interval of 15-16 mths).
Old 25th May 2009, 12:53   #141
trrk's Avatar
Thanked: 13 Times
It is usually whichever is earlier. If in warranty, you have to stick to that.
trrk is offline   Reply With Quote
Old 25th May 2009, 13:54   #142
Thanked: 139 Times
Originally Posted by trrk View Post
Purchased the car in 3/2007 and so warranty expires in 3/2010. Last service done in 5/2009. So next service is 5/2010 (if going by 1 year) or 9/2010 (if going by 10K interval and based on my present driving). In either case, warranty would have expired. So what to do???
Old 25th May 2009, 14:26   #143
MAS
MAS's Avatar
Thanked: 1,211 Times
Default Servicing once a year is Complusory
Hi Vasudeva,
Just spoke to the service advisor in Lanson Toyota. He said that it is compulsory to service the car once a year or every 10,000 kms, whichever is earlier. According to him, the viscosity of the oil goes up and has to be changed.
This is a wake up call for me, as i had serviced my Corolla (H4 Auto) in March 2008 and the car has run only 4000 kms since the service.
Booked for service for tomorrow @ 8 am.
MAS is offline   Reply With Quote
Old 25th May 2009, 14:42   #144
Thanked: 139 Times
Thanks everyone. It seems 12-13 months will work for me.
Old 25th May 2009, 18:26   #145
trrk's Avatar
Thanked: 13 Times
Your problem is minimised. You are on your own if warranty is not a factor.
Contrary to popular thoughts here, I like ot conserve precious resources and allow them to be used to their fullest. So finish your 10000kms befoer you take it for that oil change. The oil iin a petrol engine has less degradation.
You can (and should) keep an eye on the level and nature of the oil in between as I do in my Marina (I have shifted from the required 7500 to 10000 oil change interval).
The City anyway requires a change every 5000kms.
Old 11th June 2009, 17:08   #146
ScorpMan's Avatar
Thanked: 125 Times
Hey Vasudeva. Just'd a query! How much air pressure do you keep in your Corolla's tires for a comfortable ride? Yesterday got it done from a Petrol Pump to 30 in all four, as recommended. But the suspension became too thrashy and every bump on the road was noticable, so reduced it to 25 and things seem to be much more comfortable. Are these petrol pump monitors not good enough? Have been getting it done on my other cars for years, and everything is fine. So what is different with Corolla?
ScorpMan is offline   Reply With Quote
Old 11th June 2009, 20:11   #147
FlyingSpur's Avatar
Thanked: 1,335 Times
25 is too drastic a drop !! I wouldn't suggest going below 28 at the minimum, my '05 Corolla rides at that pressure or higher but never below.
FlyingSpur is offline   Reply With Quote
Old 12th June 2009, 16:11   #148
ScorpMan's Avatar
Thanked: 125 Times
Thanx Spur. Increased it to 27 and it feels just perfect at that level.
Old 20th June 2009, 12:19   #149
Thanked: 139 Times
I get the tyre pressure to 30 as recommended, and get it checked every 3-4 weeks (mostly). In fact, I think that substantially higher than that (not substantially lower) makes for a more bumpy ride. At 30 and roundabout, it glides over most surfaces.
Another point that may save you money: go with regular fuel (my service advisor says there is no need for premium fuel which now costs +Rs. 2/litre) if you are not already doing so. Also I get fuel from an IOC company owned fuel station. Previously it was once a week, regardless of mileage (which anyway used to be 250-440 k/week), but now every 2-3 weeks (mileage dropped to 120-180/week). When fuel empty light comes on, I have calculated from numerous refills that the car has used up 36-38 litre, so a safe estimate is 10-12 litres remaining.
Old 20th June 2009, 13:11   #150
Thanked: 45 Times
No two petrol pump air pressure meters will give same reading. It is best to use either only one pump or buy your own air pressure meter. I want to buy one. Can anybody suggest which are the good brands available.
I used to fill up my Matiz always with premium fuels, but for Toyota I am using only regular fuel. I always get the tank filled up as it saves me repeated trips to pump.
akj53 is offline   Reply With Quote
2009 Toyota Corolla Altis 1.8 GL - 74,000 kms 9th year ownership report Vid6639 Long-Term Ownership Reviews 317 14th June 2018 10:26
Toyota Corolla Altis 1.8 AT - 4.5 years, 51000 kms. Running well...very well! geronimo Long-Term Ownership Reviews 39 12th May 2017 17:59
300,000 kms in 7.5 years on my Esteem Diesel. EDIT: Sold @ 3.4 Lakh kms benzinblut Long-Term Ownership Reviews 72 8th March 2014 01:54
Toyota Corolla Altis Automatic now available in 2 variants Vid6639 The Indian Car Scene 23 27th February 2012 00:12
All new Corolla coming soon EDIT: Corolla Altis now Launched extreme_torque The Indian Car Scene 295 19th September 2008 23:48
