Old 6th March 2009, 12:33   #121
Thanked: 139 Times
Originally Posted by Sahil View Post
My Altis A/T isn't as fuel efficent for some reason. It's returning around 8.5kmpl, has done 1200kms to date. Although driving is in heavy traffic AC on 24c and gear shifts at around 3000rpm on avg.
Do not know your driving preferences but the answer is in your post and my reply:
1. I think Corolla returns the favour if you make an effort to improve FE.
2. My driving style: mixed traffic now (reason for FE dropping from 12 in Jan. to 11-11.5 now). AT shifts gears efficiently. Use AC at 27-28C with intermittent switch off. Try shifting at lower RPM and increase AC temp for a week, and see how it does.
vasudeva is offline   Reply With Quote
Old 6th March 2009, 13:53   #122
Sahil's Avatar
Thanked: 2,714 Times
27-28 in Mumbai heat thats hovering over 35c now is not possible.
Shifting at lower RPM is definatly a good way to increase FE but I have a very heavy right foot and already toned it down for the Altis
The major drawback is the traffic, my avg speed is around 17km/hr !
The triptronic option would have helped if the damn thing was effective. I never see myself using it because its lazy and continues to shift at it's own sweet pace.
Old 6th March 2009, 14:01   #123
Thanked: 139 Times
That is one possible explanation. I have calculated that with average speeds of 30 kmph, Corolla AT should give >11 kmpl. Reg. AC, Delhi temps are even higher (>40) with lesser humidity. I use 27-28C intermittently when traveling alone as on most days) and 25-26C (80-90% on) when traveling with family. That is quite comfortable here. Try to at least calibrate your AC temp and use to your comfort and see if FE improves (that is if you feel that increasing FE is worth the effort of increasing AC temp).
Old 6th March 2009, 15:10   #124
Sahil's Avatar
I'll try putting the temp at 25-26 with a higher blower speed to see if it's as comfortable as 24 with blower one first level. Def would not sit in discomfort to increase FE, even 8.5 kmpl is decent IMO in given conditions.
Avg speed of 30 is far fetched. Even my BMW's avg speed ain't often above 25km/hr even though I have frequent high speed runs of up to 140km/hr at nights. The Altis is mostly used in the daytime for regular commuting hence it get the worsest of the traffic.
Old 6th May 2009, 11:48   #125
Thanked: 139 Times
I had noted in earlier posts how my Corolla AT's brake pads had to replaced in 2/2008 at a cost of Rs. 5.6-5.7K for all 4. It seems that the time has come again after close to 39K (or 20-21K usage life). Car is due for service in end-May/early-June, and I have recently noticed some screeching when it brakes. Is it time to get these replaced again (at Rs. 6K approx) or something else can be done. Only authorised dealer for me!!! As it is, 40K service is a bit more costly, and I have no problem in spending on brake pad replacements if it is justified. Good news is that considering my present driving of 6-7K per annum compared with 18-19K till 2/2009, the new replacement could last me more than 2.5 yrs (compared with present replacement interval of 12-15 mths).
Old 6th May 2009, 16:31   #126
Thanked: 103,441 Times
That's about right for an automatic in our driving conditions.
No ways, there isn't any other option. If you drive on squealing brakes, the brake discs will get damaged (more $$$). Better to get the pads replaced ASAP (as in today or tommorow).
With Toyota's quality after-sales, I can see why.
Old 6th May 2009, 16:52   #127
Thanked: 139 Times
Last time it kept on squealing occasionally for 2,000 km before I got them replaced. It has just started, tomorrow is election day.
However, if the advice is to get it replaced ASAP, service is anyway due so it is just a question of visiting the dealer on the next 1-2 weekends.
My sister-in-law has an Accord in the US, and she has a substantially longer replacement interval (~30-40,000 miles). Driving conditions (no scud missiles, lot more predictability) or something else.
Old 6th May 2009, 17:41   #128
neeld's Avatar
Thanked: 101 Times
Post
In our Indian driving conditions I have also seen the brake pad needs to be replaced after 20000-25000 km in AT where as in MT it can go up to 50000 km.
neeld is offline   Reply With Quote
Old 6th May 2009, 17:57   #129
ImmortalZ's Avatar
Thanked: 312 Times
More predictable driving conditions. And the fact that their driving is on endless freeways on cruise control for hours with nary a touch on the brake pedal.
Old 6th May 2009, 18:29   #130
trrk's Avatar
Thanked: 13 Times
My CVT has 32000+kms in its odometer and brakes are fine.
trrk is offline   Reply With Quote
Old 7th May 2009, 08:44   #131
Thanked: 139 Times
Talked to Toyota service and shall get the car serviced and brake pads checked/replaced on Sat/Sun. Will post later.
The screeching is higher at braking to stop rather than decelerating slightly. Right now it is more of a nuisance and better to remove that problem quickly.
trrk, drive in Gurgaon at peak time (as I did till Feb) and you will see brakes being used at least 5 times/minute for more than 15-20 mins. With that problem no longer being there, I am hoping this time they last more than 20-22 K (2-3 years).
Old 7th May 2009, 09:59   #132
sgiitk's Avatar
Thanked: 3,883 Times
Squealing front brakes are almost invariably due to the wear indicator. This is a small piece of metal which starts to rub on the disk when the pads near their useful life.
It is true that Autos go through their brakes faster. As Auto's do not have any engine braking (except in low - which is necessary for going down hills safely) this is but natural. I remember in the past AT cars also came with upgraded braking systems for this reason.
Old 7th May 2009, 12:52   #133
As Immortalz posted, really about the freeways and endless cruising miles. That said, brake pad wear is directly related to your driving style. Do you high-revv? Stomp on the brakes at the last minute (versus gradually slowing down)? More of city versus highway?
For instance : My Vtec's brake pads last VERY long. Despite the car being crazy high-revved. Reason? I have a habit of using engine braking all the time. Thus, if I'm slowing down from 50 kph on marine drive, I'd probably get to 10kph on engine braking alone and only then tap on the brake pedal. I don't recommend this to everyone but it's just a component of individual driving styles. And I'm habituated to heavy engine braking.
Old 7th May 2009, 13:11   #134
trrk's Avatar
Thanked: 13 Times
Not much difference in our town. We are blessed with canals and the average distance between 2 junctions is about 200 metres.
Old 7th May 2009, 17:20   #135
Thanked: 139 Times
High-revv: not at all if it means going above 2500 rpm or hard acceleration. As I said, Gurgaon is not a good place to drive.
I do not drive fast (say >100 kmph), not the first one to get off the red light, and not the one to decelerate hard. Even my Corsa with all its problems had brake pads replaced at 35K (not sure if they were required but not technically competent). Corolla may seem sedate to many, but it accelerates fast with a light tap (has to be, in BHP/torque terms, it would be amongst the top 5% of cars on Indian roads). I have also noticed that when I take off the foot of the accelerator, it decelerates slowly, and so a lot of time, foot brakes are required. Cannot decelerate 0.5 km before a red light, can I??. The disadvantage of having a high BHP in a sea of compacts (with perhaps half the BHP and torque) is that not everyone can keep always in tune with their speeds (if you know what I mean). I can prolong brake pad life by about 5K if I drive a lot more sedately than I already do.
Right now, my daily trip takes 50 mins for 22 km. Gurgaon was 160mins for 70 kms, but a lot of braking in the last mile (BPO drivers, lot of traffic). No red lights, but even then, the last 1-2 kms took 20-25 mins. You would really have to experience that one day (at peak hours) to know how much brakes are used (no red lights, go 5 metres, stop, go 10 metres, stop, and so on for 1-2 km).
Forgot to mention that my acceleration and braking style is more a tap rather than a thrust.
2009 Toyota Corolla Altis 1.8 GL - 74,000 kms 9th year ownership report Vid6639 Long-Term Ownership Reviews 317 14th June 2018 10:26
Toyota Corolla Altis 1.8 AT - 4.5 years, 51000 kms. Running well...very well! geronimo Long-Term Ownership Reviews 39 12th May 2017 17:59
300,000 kms in 7.5 years on my Esteem Diesel. EDIT: Sold @ 3.4 Lakh kms benzinblut Long-Term Ownership Reviews 72 8th March 2014 01:54
Toyota Corolla Altis Automatic now available in 2 variants Vid6639 The Indian Car Scene 23 27th February 2012 00:12
All new Corolla coming soon EDIT: Corolla Altis now Launched extreme_torque The Indian Car Scene 295 19th September 2008 23:48
