| | Thread Tools |
| | #46 (permalink) |
| BHPian | testdrive, your problem sounds very similar to mine with respect to the "Check Engine" light. These posts may help: http://www.team-bhp.com/forum/techni...tml#post413430 (My Safari Suffer...ings!) http://www.team-bhp.com/forum/techni...tml#post414467 (My Safari Suffer...ings!) http://www.team-bhp.com/forum/techni...tml#post415695 (My Safari Suffer...ings!) http://www.team-bhp.com/forum/techni...tml#post417674 (My Safari Suffer...ings!) |
| | #47 (permalink) | |
| Senior - BHPian | Quote:
OT: Are you a member of The City Club, though I saw your Dicor there a few Saturday's back but wasn't sure? | |
| | #49 (permalink) | |
| BHPian | Quote:
yes! i'm a member of city club... we should meet up sometime.
__________________ Testdrive...Go 4X4 it! | |
| | #51 (permalink) |
| Newbie Join Date: Jan 2006 Location: Gurgaon
| My Friend also has a safari run 9k. It also emitting smoke like a loaded genset. we looked to engine series. i was somthin MTZ.... i am not able to make out. we got the cat converter cleaned. it was gud for 3-4 days then again it is same. anyways the service at nawab sucks. its going good for my indigo but not for my friends safari. i am thinking of logging a stinker to TATA and see what happens. Guys anything we should check with safari dealer for smoke probs except ECU/EGR that is in list. ![]()
__________________ 07 Santro 06 Indigo tDI 05 Bullet Electra 350 02 Calliber 98 Kinetic Honda 96 M-800 |
| | #52 (permalink) |
| BHPian | hey testdrive, you paid quite a lot of money for it. Normally the price here in bangalore varies between 12k to 13k with all the dealers. After bargain you can get it even for a bit less...i think they have charged you a lot..
__________________ Cheers Babu The only constant in life is change |
| | #53 (permalink) | |
| BHPian | Quote:
2805142. [/SIZE][/FONT]
| | #54 (permalink) |
| BHPian | Check Engine issue update: After waiting for almost 2 weeks, the wiring harness arrived on July 4th 2007 evening from Pune, 2 days late than committed. The wiring was ordered on June 25th 2007. I handed over the Safari to Dhingra Motors on July 5th. Was told later that evening they would need 1 more day to fix the problem . One of the wiring connectors was broken in transit. Luckily Tata had this part in-stock in their Gurgaon/NCR warehouse. Anyways, got the vehicle back on July 6th evening. The wiring harness costing Rs.10000 was replaced under warranty (but ofcourse)...Driven the Safari for 2 days and the problem seems to be rectified.Engine Oil Leakage issue update: Well after multiple visits and oil sump gasket being replaced, the oil still leaks! The story of the Tata Safari LX problems continues...
| | #55 (permalink) |
| BHPian | Well... my safari went in for yet another round of repairs for the oil leakage problem on 10-Jul-07. This time the entire sump was changed. Got the vehicle back the same evening. However, the next morning to no surprise the oil was STILL LEAKING... Have given Tata Motors enough opportunity to solve for this, but they are simply taking me for a ride. I got hold of the following checksheet which they seem to be using (1 by 1). TATA MOTORS: CheckSheet for Engine Oil Leakage - Symptoms/Cause/Remedy C/S No: CLT-24 Revision No: R0 May-06 A. - Leakage at upper side of engine 1. Cause: Leakage from front cam seal Remedy: Inspect cam seal. Replace if cut or defect due to wrong fitment observed 2. Cause: Leakage from rear cam seal Remedy: Inspect cam seal. Replace if cut or defect due to wrong fitment observed 3. Cause: Leakage from cylinder head cover gasket Remedy: Inspect Cyl.head cover groove for gasket fitment and gasket also. Clean groove properly. Replace gasket if cut of defect is observed. DO give proper time to settle the gasket in Cylinder Head Cover. 4. Cause: Leakage from oil separator Remedy: Check air filter condition, check oil separator. Replace if necessary. 5. Cause: Clamp at cylinder head cover/ oil separator not tightened Remedy: Tighten. Replace if necessary. 6. Cause: Blow by hose cracked Remedy: Replace it. B. - Leakage at lower side of engine 1. Cause: Leakage from crank shaft front oil seal Remedy: Replace if not sealing properly 2. Cause: Leakage from crank shaft rear oil seal Remedy: Replace if not sealing properly 3. Cause: Oil feed line (to turbo charger) loose connection at cyl.block end Remedy: Tighten 4. Cause: Leakage from oil cooler gasket Remedy: Replace it 5. Cause: Leakage from oil sump gasket Remedy: Tighten sump bolts. Replace gasket if required. 6. Cause: Drain plug loose Remedy: Tighten C. - Leakage around turbo charger 1. Cause: Oil feed line (to turbocharger) loose connection at turbocharger end Remedy: Tighten 2. Cause: Oil return line loose connection (at turbocharger end) Remedy: Tighten 3. Cause: Oil feed / return line twisted / damaged / cracked / clogged Remedy: Fix it. Replace if necessary 4. Cause: Oil return line clamp dislodged Remedy: Fix it. Replace if necessary
| | #59 (permalink) |
| BHPian | I'm now dealing with Tata Motors directly and making sure all communication with them is in writing. I have asked them to send me in detail what they intend to do next. then only will i send the vehicle for repairs. Also, asked them for assurance that things will be sorted out this time around (even though they have been assuring me in the past)... and what if things are not repairs now - what next?
| | #60 (permalink) |
| BHPian | testdrive, its good that you are keeping all your communications in writing. i hope that you don't require them for anything legal since till now we have seen very good service from Tata. I think this time if they can't fix the issue, then they need to give you a replacement.
| Thread Tools | |
Similar Threads | ||||
| Safari DICOR 2.2 VTT - Ex 4x2 - Artic Silver | dadu | Test-Drives & Initial Ownership Reports | 383 | 30th June 2008 10:59 |
| New Tata Safari 2.2 VTT EX 4X2 EDIT 5000kms service done | harjeev | Test-Drives & Initial Ownership Reports | 285 | 31st March 2008 10:25 |
| My New Safari Dicor EX 3.0L 4x2 LTR Thread | reachmash | Long-Term Ownership Reviews | 52 | 11th February 2008 18:19 |
| Passion Red Safari Dicor LX 4x2 - @ 15000 kms | Rahulk76 | Long-Term Ownership Reviews | 121 | 4th February 2008 18:46 |
| For Sale: Tata Safari DICOR VX 4X2 | speedmiester | Shifting gears | 10 | 12th October 2007 16:35 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425
