Old 25th June 2007, 15:33   #16
babureddy's Avatar
thanks arun for the VIN info, i heard that my vehicle is ready, but i will be getting the delivary only on thur, i will try and check out the VIN.
babureddy is offline   Reply With Quote
Old 26th June 2007, 17:59   #17
testdrive's Avatar
Default black smoke
I also faced the black smoke problem. It was reduced after the catalytic converter and air filter was cleaned. The Exhaust Gas Recirculation (EGR) Modulator connections were checked (u can google the term to know more about how EGR works).
I only notice black smoke now whenever I drive at low rpms (1000-1500rpm) and dont change the gears sooner. As a result there is knocking in the engine which causes short bursts of black smoke.
It might just be about getting used to a diesel gear shift.
As for the fuel, i have been advised to switch to normal diesel and add system-D, instead of using xtra / hi-speed variants.
I would also suggest that you turn off the engine while refuelling, as i suspect having the engine on while filling the tank might have damaged one off the injectors of my safari. Also, the vaccum created while filling an empty tank can condense moisture within the tank which can get into the fuel supply...
You can view my ownership report for more details on my experience
http://www.team-bhp.com/forum/long-t...ip-report.html
testdrive is offline   Reply With Quote
Old 27th June 2007, 14:56   #18
Thanked: 166 Times
Default things are improving
Hey guys, thanks a lot for all the responses. I had not been keeping well and hence could not respond earlier.
Some issues have been sorted out automatically. I have been observing the vehicle rather closely, and retrospecting my driving style. The black smoke has reduced considerably. I had once driven the vehicle in a couple of feet of rainwater for a distance of easily 100m. I think some water got into the fuel system and hence the black smoke. It was then that the AC also fused out. I got all these checked out with the service folks. He had mentioned that the black smoke would be there for about 1-2 tank fills and then disappear. Thats what has happened.
My dealer is concorde, he has been pretty helpful till now, and quite honest and open, so I do not think my vehicle was used as a test drive vehicle. Concorde does not do it as far as I know, while Manipal got me a brand new vehicle to test drive with the odo cable disconnected. Also Trident Hyundai got me a brand new Accent CRDi to test drive with the odo removed last year.
I got a D-series vehicle in the first week of may, so it was pretty fresh.
The door beadings had come off when they were installing the video cables for the reverse camera and they did a shoddy job of refixing it.
Now I want a simple MP3 headunit with 4 good speakers, I was suggested a Blaupunkt Maui or Mumbai. Could you guys please suggest me where I can install 4 speakers (I dont know if oval speakers can fit in the space provided in the doors).
Thanks again for your responses folks!
wanderlust is offline   Reply With Quote
Old 27th June 2007, 18:08   #19
testdrive's Avatar
Default music system
I have the following equipment in my safari. You can fit 6.5" round speakers in the space provided in the doors. I would recommend installing component speakers (which includes Tweeters and cross-overs) in the front doors. It is important to put good speakers in the front, otherwise will need to turn up the volume due to the engine noise (at high speeds). This will be uncomfortable for the passengers in the rear.
I prefer the pioneer display, effect and features over blaupunkt (which i had in my earlier car). I would recomment Blaupunkt if u are going in for a high end system. For low / mid range go with Pioneer / Sony etc. Speakers i would recommend JBL...
Head-unit: Pioneer DEH-P5850MP
iPod Interface Adaptor: Pioneer CD-IB100
Speakers (front): JBL Components GTO607 (6.5")
Speakers (rear): JBL 3-way GTO637 (6.5")
Bass Tube: JBL 1000w / 10"
4 channel JVC amp.
Coastal Karnataka and Goa in Swift D - 2000+kms in 9 days dreamdiesel Travelogues 75 16th December 2011 20:21
Dark Metallic Gray i20 Asta, 2000 Kms Review Shyamtanu Test-Drives & Initial Ownership Reports 20 27th October 2009 15:22
2000 Safari or a 2005 Indigo? Voido_kun What Car? 11 15th September 2009 15:22
Benz W210 Pre 2000 suspension vs post 2000 Mohnish Technical Stuff 2 21st January 2009 19:48
Info about "Safari turbo 2000" lohithrao SUVs, MUVs & 4x4s 7 29th October 2007 13:25
