| | Thread Tools |
| | #332 (permalink) |
| BHPian | GeekSrik, I stuck to IOC regular and especially after BUSA s advice, never would go for premium fuels. btw I run 195 profile tyres and I have checked my fuel efficiency twice on highways and got the following results.1) 23.5 2) 25.5 Do you find any improvement in response or smoke from using shell?
__________________ It ain't 'bout how hard you hit; it's about how hard you can get hit, and keep moving forward - Sly in Rocky Balboa. |
| | #333 (permalink) |
| BHPian | thanks for answering me. its strange why I got only 18kmpl with same tyres and same loads. with shell the response is much more linear and I get better pull too. but other than that nothing else!
__________________ blog.chowchowbath.com the Bengaluru blog |
| | #334 (permalink) |
| BHPian Join Date: Nov 2007 Location: Bangalore
| @GeekSrik: Have you tried experimenting with different air pressure? From my experience, I feel having a bit more air in the front tyre (due to the engine load in a diesel) is advisable especially on the highway. Could even make a slight difference in your mileage figures, for the better.
__________________ Blessed are those who can laugh at themselves coz they'll never cease to be amused. |
| | #336 (permalink) |
| Team-BHP Moderator ![]() Join Date: May 2004 Location: Bangalore
| yup swift d is sensitive to psi when it comes to FE with wider rubber and front require more psi, keep a 2 psi diff between F n R for good handling.
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin |
| | #337 (permalink) |
| BHPian | is this only for highway or can i use that for city too? strangely I didnt know about this! also could anyone let me know what all should be done for second free service? also about synthetic oil and stuff.... srikanth
| | #338 (permalink) |
| BHPian | GeekSrik, You can maintain the same for city too, but i guess the ride will be a bit harsh in potholed roads. I try to keep 32 all around in city. Dont think of synthetic oils until 10k is done (am not an expert but got the expert advice here)
| | #339 (permalink) | |
| Senior - BHPian | Quote:
__________________ Life is Analog. Digital is an approximation. Last edited by condor : 30th November 2007 at 08:58. | |
| | #340 (permalink) |
| Yes front at 34 and rear at 32 for my car, for city and highway. and no it the rear that starts to jump around when you increase the psi.
| | #341 (permalink) |
| BHPian | alright, I ve finished another 1.1k kms with this car and it still fails to get tired . Also I have had no surprises with this car too. The ride has been good, the engine is getting too noisy at 100 kmph now, am not sure why. Other than that I had taken it to mysore and back almost 350kms and there was no indication of it being sluggish too. it just performed like what its supposed to - a dream! am awaiting my third free service and would like to hear from all of you what should be done and what not for this 10k service which is coming up. the rattles are a feature you see, so i ve left them untouched for now. but this car has given me other things too, vertigo (ear fluid imbalance leading to severe dizziness and faints), knee and backache to some extent, though I would say driver seat is pretty good. The sound of the engine drives me crazy sometimes and I am forced to play music in an otherwise silent car. the suspension is a bit hard and inmates of the jail can feel the bumps ![]() I ll have to try and make this car quieter somehow. would anyone know how to reduce NVH further, have anyone done any mods to this car for this purpose? Pete's is something I d love to install but sometime later on! the windows sure make me claustrophobic if closed always.
| | #344 (permalink) |
| Senior - BHPian | Please go through this thread, if you already haven't. Hope it'll help. ![]() http://www.team-bhp.com/forum/produc...ping+dampening (The Damping Material and Sound Deadener Thread)
__________________ I'm far from perfect. I hope i can improve. Thats why i'm here! |
| | #345 (permalink) |
| BHPian | Another 1000 lapped up and the odo reads 8200 km+. At this stage I am gearing up for the third service, so its perhaps an apt time to pout out my woes with this car and ask for expert advice. 1. The engine has a hoarse noise anything above 70kmph speed, and the distinct roar (i even wonder if i can call it that) gets more prominent around 80+ and irritates at 100kmph I need to know if an oil change would bring down this noise by any chance or anything more needs to be done 2. The oil change itself - I need to know whether any special oil needs to be used (sorry but i need the name, and quantity - i am bad at this! - mobil ? synthetic? .... ??) 3. Soapy layer on windscreen - While casually talking with my friend who owns a swift and had the same problem, I believe it was traced to the windscreen water tube having lots of foam within it which forms a frothy layer and brings it on each time you spray water (even if the water has been changed) and i believe i hear the only way to correct this is to change the tube that leads upto windshield. any options here? 4. Foul smelling Ac at times - of late i have observed at times the AC smells a bit foul and the only thing I do is to down the windows and take in air before I pull them up again. I am not sure why this is occuring but its not really the sulphur kinda foul smell, its more the plasticky kinda smell but whatever it is its awful enough but lasts for quite less a time. 5. I installed the neck supports on each head rests (the TYPE-R ones) but I fail to understand what exactly its purpose is, as a driver my neck hardly rests on the headrest and even if it does the neck support hardly helps. Perhaps the biggest three cons I didnt like with this car are (there are more to say even then): 1. Rattles Rattles Creaks and Rattles 2. Hard suspension gives a throw around each time 3. The car by itself is quite claustrophobic - gives you a feeling of being choked in a closed dungeon More: 4. bad rear space, even two people have a problem sitting freely with legs stretched out, wonder which car satisfies that atleast? To sum it up - good FE, stiff ride, coarse engine, claustrophobic car, quite some body roll and free rattles.
« My Ford Fusion 1.4 TDCi Diesel EDIT:first service at 1200kms
Optra Magnum TCDi ... My new love ..!! »
| Thread Tools | |
Similar Threads | ||||
| My Red Cherry - Swift VDI : 15000 KM Report | DieselFan | Long-Term Ownership Reviews | 55 | 30th August 2008 15:45 |
| Swift VDI (ABS) - Ownership Report EDIT: Now Updated for 26,000 kms | Eddy | Long-Term Ownership Reviews | 159 | 26th August 2008 13:30 |
| Swift VDI or Getz GLX-6L Budget EDIT: Bought VDI | agm | Hatchbacks | 29 | 11th April 2008 22:56 |
| Maruti Swift -Vxi (ABS) 1000km ownership report | raghutk | Long-Term Ownership Reviews | 0 | 27th August 2007 14:23 |
| Swift Vxi & Swift Vdi - Ownership/Service/Running costs | dcetech | Hatchbacks | 1 | 16th August 2007 14:21 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
