Closed Thread
Old 25th January 2008, 12:06   #511
Ajaybiz's Avatar
Thanked: 141 Times
I think so i am one of few owner here who has not yet faced any ratteling issue .
Ajaybiz is offline
Old 25th January 2008, 14:53   #512
austere_sly's Avatar
Thanked: 9 Times
what else can I say...Lucky you
austere_sly is offline
Old 25th January 2008, 15:58   #513
GeekSrik's Avatar
nikunj and humyum
the roads i ve travelled on were quite good, not bad/uneven or potholed. however the issue could be due to tires which are 195s. strange, but anyways, right now the noise isnt there, and i am glad with a quiet cabin.
blueraven here i come
srik
GeekSrik is offline
Old 25th January 2008, 16:25   #514
Thanked: 200 Times
Slightly off topic: I was just looking through the prices on the Maruti website and notice that the prices are kind of illogical
MARUTI SWIFT VDI (BHARAT STAGE III WITH ABS)533782.78
MARUTI SWIFT VDI (BHARAT STAGE III WITH ABS and IMMOBILISER)
524282.79
I thought this was only a typo, but even the ZXI prices are similarly posted.
any idea why?
prashanthyr is offline
Old 25th January 2008, 17:02   #515
nikunj_cal's Avatar
195'S ?? . Then i better take care as i go through a lot of rough roads with a few stretches of them being potholed . I am also running 195's on my DDis !!! But did the service guys say the reason was the fatter tyres ?
nikunj_cal is offline
Old 26th January 2008, 19:54   #516
BUSA's Avatar
But is this a permanent solution to cure door rattles ?
Yes, with damping your doors shouldnot rattle anymore. My doors are damped, they dont rattle, but the boot is not damped and that door rattles like crazy.
BUSA is offline
Old 27th January 2008, 00:30   #517
Apart from removing the rattles, does damping reduce the engine noise filtering into the cabin? After damping how does noise within the cabin compare to the petrol swift?
prskumar is offline
Old 27th January 2008, 00:32   #518
Jaggu's Avatar
Thanked: 8,674 Times
finally i found time to hear the sound track, its sounds like a prop shaft aircraft !! and yes it was your wheel bearings, and lets not debated on bearings, as far as my understanding goes they are unpredictable, unless i am richie rich with diamond roller bearings.
@Geek: either you recorded on a smooth tarmac or ur car doesn have much rattle to complain off
Jaggu is offline
Old 27th January 2008, 00:35   #519
BUSA's Avatar
If you damp behind the dash then engine noise should reduce, otherwise road noise does reduce.
BUSA is offline
Old 27th January 2008, 00:36   #520
Jaggu's Avatar
boot (door) rattling ?? thats one part which doesnt rattle no matter what, since it doesnt have much inside for orchestra, it might be something else.
Damping will save door rattle and maybe to an extend sound deadening, filtering road noise from entering the cabin. But if you really want engine sound filtering then, engine bay firewall and floor is where you need to attack with deadening, which is really difficult task.
Jaggu is offline
Old 27th January 2008, 09:34   #521
Thanked: 9 Times
My boot also doesn't rattle. I found it once rattling which was due to tool box was lying around freely on boot. So every time bad patch of road came, the tool box used to bounce around. I found its solution by placing it tightly between rear seat and boot floor.
Old 27th January 2008, 10:17   #522
GeekSrik's Avatar
jaggu i did record this in a straight stretch of 4 kilometres on outer ring road between marathahalli bridge and kr puram bridge. my rattles are dependent on my car. if my car wants to rattle it starts off, else its quiet. so its kinda selective!
and yes i do agree that boot door will not rattle no matter what! i m planning to take it to blueraven after my 3rd service and when i have that extra bit cash. lets see what magic he does on my car!
GeekSrik is offline
Old 27th January 2008, 11:27   #523
Thanked: 32 Times
Srik, According to me thats how Diesel engine sounds, I travelled and tested lot of Diesel cars I found every car has more noise inside the cabin compared to Petrol ones. Always use regular Diesel (I suggest IOC) never try super Diesels and drive with light foot which will make less noise.
Also Diesel cars will loose charm after few years. so I suggest maintain your beauty as best as you can.
Damping will make less noise intrude inside. So try out that for sure
Ravi.
ravibhat is offline
Old 27th January 2008, 11:31   #524
BUSA's Avatar
Mt boot door rattles for sure. Makes a khar-khar noise continously, damn irritating. Will be damping that soon and let you guys know.
BUSA is offline
Old 27th January 2008, 11:35   #525
Vid6639's Avatar
Thanked: 21,042 Times
More often than not it won't be the boot but the foldable back seats which become loose and rattle.
Vid6639 is offline
Closed Thread
Swift Diesel.Vdi - Ownership report.Facing problems -Maruti refuses to honor warranty Mevtec Test-Drives & Initial Ownership Reports 98 26th February 2018 23:19
Long Term Ownership Report: Swift VdI- 2 lakh kms, Cost of ownership on Pg 3 epicenter.rulez Long-Term Ownership Reviews 150 30th May 2017 20:35
Maruti Swift VDi Ownership Report - 50,000 kms clocked naveen.raju Long-Term Ownership Reviews 35 2nd September 2014 11:53
(Yet another) Swift VDI(2009) ownership report debugged Long-Term Ownership Reviews 12 16th December 2009 17:45
Swift Vxi & Swift Vdi - Ownership/Service/Running costs dcetech Hatchbacks 4 26th October 2009 22:28
