Closed Thread
Old 16th October 2008, 21:46   #826
GeekSrik's Avatar
5k ? why? i thought going in for mineral oil, the service must come to about 2.5k max. i m not seeing the justification for 5k in this. even if you assume 900 for a filter, about 1000+ for mineral oil (its substantially cheaper isnt it?) + flush = well max about 3k if at all. i think i m opting for service the day after if possible. cant drag this more.
GeekSrik is offline
Old 16th October 2008, 21:55   #827
Jaggu's Avatar
Thanked: 8,674 Times
Lot of other fluids are also replaced, please check my thread for bill split up
Jaggu is offline
Old 16th October 2008, 22:22   #828
DieselFan's Avatar
Thanked: 234 Times
It would be around 4500-5000. here is what I paid for 20K service -
1. Air filter - Rs. 230
2. Fuel element - Rs. 842
3. Oil filter - Rs. 344
4. Coolant - Rs. 209
5. Brake Fluid - Rs. 276
6. Gear oil - Rs. 463
7. Engine oil - 537
Labour -
1. Service - Rs. 750
2. Brake bleeding - 95
3. Brake caliper greasing - 95
4. Brum brake cleaning - 190
5. Consumables - 100
All the above were taxed at around 12.5% (12.5% for parts and 12% + 3% cess on 12% for labour)
DieselFan is offline
Old 17th October 2008, 16:08   #829
GeekSrik's Avatar
dieselfan, thanks for those inputs. i ve booked the car to be serviced tomorrow first thing in the morning. it badly needs attention and i cant see my baby crying for it
GeekSrik is offline
Old 18th October 2008, 14:17   #830
GeekSrik's Avatar
finally gave my car for service. asked him to flush out the engine oil and go back to mineral. also the other points were asked to be taken care of. car must be ready in a few hours.
GeekSrik is offline
Old 19th October 2008, 11:39   #831
GeekSrik's Avatar
ok my car is in from 20k service done at 18.3 k. most problems rectified. changed air filter, oil back to mineral, gear knob now slots much better, engine power and pull restored after cleaning block in air filter. nothing done to tyres. fully cleaned up. total bill was 3775/-
also, i ll give the split up in the next post for those interested. one thing to note was that i had a BIT for removing the alloy wheel (its like a custom spanner) made to order from sai iyengars within my car. neither did i notice whether it was or was not there nor did they notice. so as of now thats lost. 250 bucks down the drain and an important part at that.
i ve ordered another one from sai's. will be available tuesday.
unfortunately i had take my little son to a marriage and on way back after he had his milk, he puked the whole thing on a fantastically cleaned car. now its stinking so badly (even after the wash after the wash) that i have to give it to another wash again looks like. problem was the puke was in between front two seats, gear knob and the channel below seat area. difficult to clean all the crap. spent 30 mins meticulously removing all of that.
today morning took the car on 50km drive, found it energetic and full of enthu. behaved extremely well.
still got to do tyre aligning and balancing sometime at sai's.
GeekSrik is offline
Old 19th October 2008, 11:50   #832
GeekSrik's Avatar
update, they managed to locate my bit and spanner set!! it was somehow pushed under the rear seat which made it difficult to notice where it was. anyways alls well that ends well!
GeekSrik is offline
Old 19th October 2008, 15:09   #833
white_vdi's Avatar
Thanked: 18 Times
hey good to hear that your car is back to her normal self again. anything special for a 20k service??
white_vdi is offline
Old 19th October 2008, 19:11   #834
GeekSrik's Avatar
white_vdi, i did not understand your question. can you be more specific?
GeekSrik is offline
Old 19th October 2008, 22:32   #835
white_vdi's Avatar
Thanked: 18 Times
break up of the service cost. was it the normal oil and filter change or they did something specific for the lack of power that you were feeling??
Old 19th October 2008, 23:17   #836
Eddy's Avatar
Thanked: 5,067 Times
Geek: What about the diesel filter ? Did you not get that changed ?
Eddy is offline
Old 4th November 2008, 22:31   #837
Vid6639's Avatar
Thanked: 21,042 Times
Hows the clutch holding up guys. Are there any clutch complaints on the diesel compared to petrol which has clutch issues.
Vid6639 is offline
Old 5th November 2008, 12:11   #838
Jaggu's Avatar
Mine aok dont have any issues so far, abuse on clutch has gone up with the crazy traffic scene in BLR on the rise :(
Jaggu is offline
Old 5th November 2008, 18:34   #839
DieselFan's Avatar
Thanked: 234 Times
I say Maruti has made sure about a couple of things in Swift D which was an issue in swift P. Clutch and suspensions. both are really good in Swift D. Clutch is really hard though.
Old 12th November 2008, 03:42   #840
austere_sly's Avatar
Thanked: 9 Times
My Siwft has done some 14000 Kms and would be taking her for mid service checkup. Basically I am planning to do a Delhi - Jaipur in Nov end and want car to be Ok for the journey. There are no major issues as such. I plan to do following things. Please fill out if I missed on something important.
1. Wheel Alignment & Balancing.
2. Tyre Rotation
3. AC Vent cleaning
4. Air Filter cleaning
5. Brake Pad checking (Not sure)
6. Paint touch ups on the lower side of front bumpber.
7. I would want them to check up front door minor rattles, but not sure of the fear that they might end up causing more rattles.
Since I haven't had any puncture in these 14K Kms (touchwood), my Spare tyre hasn't been used even once. Though I got air filled in it last time I wen to pump. Would you advise me to replace any of the four current tyres with this spare tyre ?
austere_sly is offline
Closed Thread
Swift Diesel.Vdi - Ownership report.Facing problems -Maruti refuses to honor warranty Mevtec Test-Drives & Initial Ownership Reports 98 26th February 2018 23:19
Long Term Ownership Report: Swift VdI- 2 lakh kms, Cost of ownership on Pg 3 epicenter.rulez Long-Term Ownership Reviews 150 30th May 2017 20:35
Maruti Swift VDi Ownership Report - 50,000 kms clocked naveen.raju Long-Term Ownership Reviews 35 2nd September 2014 11:53
(Yet another) Swift VDI(2009) ownership report debugged Long-Term Ownership Reviews 12 16th December 2009 17:45
Swift Vxi & Swift Vdi - Ownership/Service/Running costs dcetech Hatchbacks 4 26th October 2009 22:28
