Closed Thread
Old 12th November 2008, 11:28   #841
Eddy's Avatar
Thanked: 4,781 Times
I would advice the following:
Get all 5 tyres rotated.
Get them balanced and aligned from a specialist and not the MASS.
Brake pad cleaning would definitely help.
Do not touch up the paints till after the trip. Same for the rattles. Get both of these fixed at 20k service.
Eddy is offline
Old 12th November 2008, 11:46   #842
Jaggu's Avatar
Thanked: 7,676 Times
Originally Posted by austere_sly View Post
1. Wheel Alignment & Balancing.
2. Tyre Rotation
3. AC Vent cleaning
4. Air Filter cleaning
5. Brake Pad checking (Not sure)
6. Paint touch ups on the lower side of front bumpber.
7. I would want them to check up front door minor rattles, but not sure of the fear that they might end up causing more rattles.
1) When did you do the job last? 5-7 k kms both the setting will hold good. Yes better done outside at a professional wheel alignment shop.
2) Again how many kms since last rotation 5-7 k kms is a good time, all 5 wheels if you have the same size and thread pattern.
3-4) Is there any issues? Otherwise dont bother.
5) Good idea to check and clean, if possible.
6-7) Wait for next service after the trip.
Jaggu is offline
Old 12th November 2008, 12:23   #843
austere_sly's Avatar
Thanked: 9 Times
1. Tyre alignment, balancing and rotation has not been done yet.
2. AC Vent - When I shift from Inside Air to Fresh air or vice versa there is some odour for some some time. Thought AC vent cleaning might help.
3-4. Air Filter - I haven't driven any other swift diesel apart from mine so I am not sure about this, but I feel that there is a slight drop in acceleration. That Turbo feel is missing slightly but this might be all psychological.
There isn't much wearing of running tyres but its sure going to be more than spare tyre. Which tyre should I get replaced with spare tyre. And since mine is a Ldi it doesn't have left OVRM as std, so I finally bought one from some shop for Rs 400. Will be getting that fixed too.
Thanks Jaggu & Eddy.
austere_sly is offline
Old 12th November 2008, 13:00   #844
Jaggu's Avatar
1) Go ahead with alignment, rotation and wheel balancing. The rotation sequence will be mentioned in the manual.
2) If the odor is due to dampness in the AC console cleaning might not really help.
3-4 Air filter cleaning is a simple job and go ahead.
Jaggu is offline
Old 12th November 2008, 20:59   #845
Thanked: 9 Times
Where is AC Console located ? Can it be not cleaned ?
Old 13th November 2008, 07:53   #846
horsepower's Avatar
Rs. 400 for an ORVM, Where did you buy it from? At MASS, it is priced around 1200-1300.
horsepower is offline
Old 13th November 2008, 11:15   #847
Jaggu's Avatar
It sits behind the dash, yes it can be cleaned but its just matter of time before the smell returns, if you frequently use the ventilation mode. Again if its just dampness that causing the stench, its matter of few minutes of AC running for the smell to return.
I never use external ventilation mode and this has helped me to a great extent to avoid the leaves/twigs and what not entering the box, leaving a stench later on.
Jaggu is offline
Old 13th November 2008, 13:33   #848
Thanked: 9 Times
Last year when I bought this car, at MASS it was around 1400. At Grey market it was around 900. Around last month when I checked it in Mayapuri and Kashmere Gate, it was for 400 and I bought it.
@Jaggu - I use AC only in palces of high traffic. When on New Delhi roads, I switch to ventilation as the air outside is relatively fresh from rest of Delhi.
Little OT: I am also thinking of getting fog lamps, but I am not inclined towards original Lumax fog light. I wanted something more powerful, though original switch looks cool.
Old 13th November 2008, 16:54   #849
horsepower's Avatar
You can change the bulb in the fog lamps, to get more light.
Old 14th November 2008, 19:46   #850
Taz-On-The-Road's Avatar
My Swift DDIS completed 20K this week(In 6 months and 18 days) and has gone to its "native" for a service. Engine is still holding up fantastically and doing its job extremely well considering the load and stress its been through, 16K+ on the highways and at real high speeds. No issues with exhaust, smoke or power lag as other members have mentioned. However, the entire car rattles and the suspension makes abnormal noises. The service assistant blamed bigger tyres(I have 15" wheels) and door mounted speakers for the abnormal rattles and noises.Guess I am not that lucky after all. Came upto Rs.4750 for the entire paid service and Pratham Motors have done a fabulous job with the rattles and the suspension. I just got it back from service this evening and the ride quality, comfort and noise levels are comparable to when I rolled it out from the dealership in April end this year. Hope it holds up well though.
Taz-On-The-Road is offline
Old 15th November 2008, 17:40   #851
d3mon's Avatar
Thanked: 584 Times
Default Got my swift Ldi
Hi guys
Got my swift Ldi yesterday. It's in sunlight copper colour and looks great.
I read a lot of talk about the LHS OVRM here. My car already came equipped with one. Looks like Maruti has finally got some sense in this regard.
One request please. As the car doesn't come with a tachometer, can jaggu or any other swift owner please fill me in on the kmph /1000 rpm figures for the car ?
Would appreciate any help.
d3mon is offline
Old 16th November 2008, 04:06   #852
kuttapan's Avatar
Thanked: 12 Times
Originally Posted by d3mon View Post
Hi guys
in fifth gear, 1000 rpm~45kph. So when you are doing 100kph in 5th gear, it is little over 2000 rpm.
kuttapan is offline
Old 16th November 2008, 09:36   #853
d3mon's Avatar
Thanked: 584 Times
isn't 45kmph /1000 rpm a bit on the tall side ? My esteem went around 38kmph/1000rpm in fifth.
Or is it because you have lesser rpm range to play with in a diesel?
d3mon is offline
Old 21st November 2008, 16:42   #854
GeekSrik's Avatar
i wouldve loved to update this thread with 20k post, but my cars going real slow. now about 19300. also after 20k service done at 18k, and back to mineral oil, and indianoil diesel normal, i find the car really eager to give me the power when needed. so i am happy again. sometimes i did try turbojet, but barring the day i fill diesel turbojet, the days after that day the car behaves rather lacklustre. no real eager pulling exhibited. switch to normal diesel from indian oil and the story is much different!
GeekSrik is offline
Old 21st November 2008, 17:15   #855
GeekSrik's Avatar
@taz - wait until a few days and let me know if your rattles are really gone.
@d3mon - though i dont have exact figures and would not want to get too technical, i would suggest that as a general rule of thumb change the gear to next higher one, when you feel that you must (without stressing or revving the car more) and when you think the car would go to the next higher one easily without compromising on the speed going low due to that change.
GeekSrik is offline
Closed Thread
Long Term Ownership Report: Swift VdI- 2 lakh kms, Cost of ownership on Pg 3 epicenter.rulez Long-Term Ownership Reviews 150 30th May 2017 20:35
Maruti Swift VDi Ownership Report - 50,000 kms clocked naveen.raju Long-Term Ownership Reviews 35 2nd September 2014 11:53
Swift Diesel.Vdi - Ownership report.Facing problems -Maruti refuses to honor warranty Mevtec Test-Drives & Initial Ownership Reports 97 7th October 2013 15:02
(Yet another) Swift VDI(2009) ownership report debugged Long-Term Ownership Reviews 12 16th December 2009 17:45
Swift Vxi & Swift Vdi - Ownership/Service/Running costs dcetech Hatchbacks 4 26th October 2009 22:28
