Closed Thread
Old 24th November 2008, 19:28   #856
Taz-On-The-Road's Avatar
@geeksrik you are mighty right! The rattles are back but are more subtle than before. Before the service, the inside of my car felt like a BMTC bus without the music switched on However, the suspension noises have vanished and have also been amply tuned so the ride quality is much much better. Guess will have to live with the minor rattles till I sell this car off
Taz-On-The-Road is offline
Old 26th November 2008, 13:05   #857
kunal2202's Avatar
Originally Posted by finneyp View Post
The Technology is from FIAT!
this engine was a joint development of Fiat and GM
kunal2202 is offline
Old 28th November 2008, 09:16   #858
GeekSrik's Avatar
Originally Posted by Taz-On-The-Road View Post
@geeksrik you are mighty right! Guess will have to live with the minor rattles till I sell this car off
My point is the same too! but just that this car can see me complete 100000 with it if i am in proper frame of mind!
GeekSrik is offline
Old 1st December 2008, 15:03   #859
Jaggu's Avatar
Thanked: 8,687 Times
Check your tire pressure, dealers usually reduce them to give a better ride and less rattle, during service. I prefer stiff handling and rattles compared to worn out tires, thats just me
Jaggu is online now
Old 1st December 2008, 18:49   #860
SOUM's Avatar
Originally Posted by kuttapan View Post
in fifth gear, 1000 rpm~45kph. So when you are doing 100kph in 5th gear, it is little over 2000 rpm.
My VDi tacho shows exactly 2100 rpm with the speedo at 100 kmph.
SOUM is offline
Old 4th December 2008, 11:11   #861
GeekSrik's Avatar
I have stopped seeing both my tacho and fuel meter. the only thing i notice is the speedo
the clutch and gear shift are really good on my knees. and its been sometime since I had that crippling pain on my knee cap, thanks to this maruti/fiat/whatever.
other than that my car is slowly inching to 20k..... normal indianoil diesel and mineral oil just work great. always eager to pull !
GeekSrik is offline
Old 5th December 2008, 00:57   #862
austere_sly's Avatar
Thanked: 9 Times
I am having a "feeling" that turbo pull is not what it used to be. The pull still is great, but I feel some punch is missing. Since I don't have a tacho, I am not sure, what speed I am doing at what rpm. Just wanted to ask that whether turbo can be checked for problems without opening up everything ? I might ask people at MASS to those checks next time I go. I usually travel alone or with someone, but today while going somewhere I had total of 5 people in my car (total weight must be around 400), should an increase in weight affect pulling power drastically ? (May be drastic is a stronger word than what I meant to write)
austere_sly is offline
Old 5th December 2008, 06:28   #863
Awaiting Email Confirmation
Thanked: 20 Times
with a full load- the aceleration will definitely come down.
other possible problems
1.dirty air filter
2.low tyre pressure
3.dirty accelerator position sensor
4.clogged intercooler
try these common and easily fixed probs first, before going for the turbo itself
rippergeo is offline
Old 5th December 2008, 23:33   #864
Thanked: 9 Times
1.dirty air filter
2.low tyre pressure
I am sure that 1 & 2 are fine. Will check about 3 & 4. Where is the acceleration position sensor located ? I guess intercooler is somewhere near radiator, is it ?
Old 6th December 2008, 20:06   #865
GeekSrik's Avatar
ripper is right on 1 and 2. also try using normal indian oil diesel. with that much load, be light footed and in right gears to enable the pickup you desire. revving this car slows it down momentarily. this is my experience whatever the load.
GeekSrik is offline
Old 6th December 2008, 20:11   #866
GeekSrik's Avatar
well yesterday my headlight dim position stopped working. the high beam was doing well though. which means at dim, there was no light output at all. it was off. went to konark koramangala, and asked my guy whats wrong, he rectified it in just a few minutes. was some loose connections that led to this issue. while there he said the most powerful lamps were 100/130 from philips, currently i have 90/100.
also i bought a windtone horn from roots the skoda types and it should be installed by tuesday from UM cars. they said they need some extra wiring and relays for that. i also bought a dashboard mat for swift, which will hold things on top of it securely without it falling off all the time. these cost me 550 bucks overall.
GeekSrik is offline
Old 6th December 2008, 21:12   #867
Thanked: 9 Times
I had my minds both on Roots horn and 90/100. Rs 550 includes Horn as well as its wiring and dashboard mat ?
I use either normal BP or Indian Oil, whichever has smaller queue. I read somewhere that fuel shouldn't be allowed to empty in diesel engine otherwise some fuel purge has to be done. Does it stand true for new CRDI engines as well ?
Old 7th December 2008, 08:11   #868
DieselFan's Avatar
Thanked: 234 Times
You do not need additional relay in Swift D it already comes with a built in excellent relay for 2 horns. It may result in ECM blow up. This is what the electrical mechanic at MASS told me. Beware.
DieselFan is offline
Old 7th December 2008, 14:23   #869
GeekSrik's Avatar
can u elabroate which mass told you this? also please let me know if the situation can happen if i have only one horn overall. and remove the other existing one. i did hear UM cars telling me that they need to fix up a relay and stuff. but he seems to have an experience in that.
GeekSrik is offline
Old 7th December 2008, 14:36   #870
white_vdi's Avatar
Thanked: 18 Times
@ GeekSrik : i have also heard that there is a relay for horn in swift D. i guess all horns come in pair as in High and Low. i have roots installed at the stock location only. dint play around with the wiring.
OT : why do you want to keep just one horn? it will sound weird.
white_vdi is offline
Closed Thread
Swift Diesel.Vdi - Ownership report.Facing problems -Maruti refuses to honor warranty Mevtec Test-Drives & Initial Ownership Reports 98 26th February 2018 23:19
Long Term Ownership Report: Swift VdI- 2 lakh kms, Cost of ownership on Pg 3 epicenter.rulez Long-Term Ownership Reviews 150 30th May 2017 20:35
Maruti Swift VDi Ownership Report - 50,000 kms clocked naveen.raju Long-Term Ownership Reviews 35 2nd September 2014 11:53
(Yet another) Swift VDI(2009) ownership report debugged Long-Term Ownership Reviews 12 16th December 2009 17:45
Swift Vxi & Swift Vdi - Ownership/Service/Running costs dcetech Hatchbacks 4 26th October 2009 22:28
