Closed Thread
Old 20th September 2007, 16:00   #256
sathya_nars's Avatar
Thanked: 52 Times
Originally Posted by kick.throttle View Post
i am so sorry my friend sathya, but i guess we were talking about the headlights and not the cabin light. well all cars have the "ON,DOORS,OFF" modes on the cabin lights. and as its directly connected to the batter, the keys "in or out" makes no diffrence at all ....
In Door position: When key is taken out, the cabin light comes on and when I lock the car it goes off. Same way, when I put keys in, light goes off.
Originally Posted by Venkatesh.C View Post
@Sathya, I guess the talk was about the beeps we hear on leaving the head lights on and remove the key ring? Then it went on to why does the headlight even stay on when the key is removed when cars like Santro switch them off automatically when the keys are removed.
I don't hear any beep sound when I leave headlights on while taking key out - thats why I was confused what lights you guys are talking here.
sathya_nars is offline
Old 20th September 2007, 17:19   #257
gopinathann's Avatar
Thanked: 20 Times
You will hear the beep when the key is taken out leaving the headlights on. Check again.
gopinathann is offline
Old 21st September 2007, 08:23   #258
kick.throttle's Avatar
how foolish is that
you put off the engine or take the keys of and still the headlights are on..
oh my god!! thats a wast technology Maruti ppl use... i seriously dont understand what is the logic behind this thing..
all car owners exept maruti must surely be happy on this part.. that the lights go off when the engine is off or key are out....
kick.throttle is offline
Old 21st September 2007, 08:51   #259
Thanked: 52 Times
how foolish is that
There is mechanical switch/slider you have to turn on/off headlights, I guess it was difficult to restore it to off position when keys are removed. Yet they could design to switch off headlights when keys are taken out & when key is put in again lights will come up since switch position was on - is this how it happens in other cars?
Old 21st September 2007, 09:56   #260
Smile
i m so sorry sathya.. i would't agree with what ever switch designe they go for. i think that the switch thigh is just of no use.
Come on --- its so simple..
keys off/engine off with Headlight-switch on --->>> Headlights off
keys on/engine on with Headlight-switch on --->>> Headlights on
what do you need another unwanted swith to keep toggleing between modes...
i wish - this so called thing never come on other cars......
Old 21st September 2007, 10:13   #261
Thanked: 37 Times
Default Its simple
What is there?
That is only matter of a relay in series with headlight bulb wires, keeps it operated from headlight switch connection and draws power direct from battery.
1. power for actual headlight and
2. power to operate relay itself.
How it works?
Headlight switch just triggers the action of ON/OFF relay which connects battery to bulbs.
What can be done?
Now I will be talking about item 2 from above. Remove its (relay operational) power connection from battery and connect it to power line of other accessory which turns on only when keys are in and accessory is on. That means relay will be operational from headlight switch only when keys turned in. It draws not more that 300mA current for 12V relay operation.
Do you still think its very complex technology involved here?
But don't do this, why?
Because this has a drawback. Once you switch off engine while headlights ON, realy will cut off headlight along with all accessory. But while starting engine again you will find headlights are turned ON if not switched off from headlight switch. This is what I always try to avoid. I switch off AC, headlights and ICE before starting engine. (You can think of problems.)
So better to keep it reminding us for switching off headlight using switch. I think headlight is for car driving only and not required when car engine is switched off. So switch off headlight while taking keys out ( or SX4 will remind you).
regards,
omishra is offline
Old 21st September 2007, 10:32   #262
Thanked: 13 Times
kick throttle - in most cars & other LMVs - some of the lighting elements like - headlights, hazard lights & cabin lights - are directly connected to battery and NOT linked to ignition. This I believe is done with a purpose to help navigate during emergency situations - irrespective of ignition switch. So its not unusual. Most maruti (& I guess other cars) as well have the warning beep that is quite audible to alert you when you remove the ignition key with headlights on. So I can't quite understand what the problem is - when this should be a benefit...
nssrini is offline
Old 21st September 2007, 10:59   #263
Venkatesh.C's Avatar
Thanked: 30 Times
Default Yes you are right
Yes Sathya you are right that's the way it works. You remove the keys with headlight Switch in the ON position, the lights still go off
When you put your keys back in and turn the engine on, the lights come back ON automatically coz you left the switch in the ON position.
Only Maruti leaves the Lights always ON. And if you forget to switch it off, GOod luck pushing your car to start whenever you come back
Venkatesh.C is offline
Old 21st September 2007, 11:28   #264
Thanked: 20 Times
I too own a Santro and it's good that the head lights turn off when engine off or key taken out, but some times I felt irritated during signals when the lights go off and come on when I switch off the engine.
In santro, when the key is taken off only the headlights go off and not the parking/city lights. Where is the logic gone here ???
One incident happened in our office. In the morning one guy has parked his Santro with the headlights turned on (without knowing). When the key taken out, headlight switched off but parking lights still on. In the evening the battery got dried and he had to call the help line to restore it.
Moral: Each one has its own advantage and disadvantage.
Old 21st September 2007, 11:44   #265
Thanked: 30 Times
Parking lights are essential sathya. It is a good practice to leave parking lights on especially when you are parked on a road-side with little light. It is a good habit to leave hte parking lights on always but in the city more often than not you will find enough lighting. So, it is an essential (and maybe a legally required too) thing to be able to turn on the parking lights even with the keys out. However there is no reason why one would want to leave the head lights ON with the keys out.
Thats the bottom line.
Old 21st September 2007, 12:59   #266
VBV
Completely agree with your argument and moral.
The other day, I was driving on a highway with another car. The other car got a flat and we were about to replace it. We could do it from the headlights of my car. And I did not have to waste petrol on that. On the highway, its especially useful. I can think of many contexts. I've even used the headlights to change my son's diapers.
Leaving headlights on is kinda stupid. (I know, 'cos I am stupid in this way many times). But I don't think I'll blame the design for that. I mean, if I were the designer, I would probably think of somebody w/ avg intelligence as my end customer and not somebody who's stupid like me. I really don't think its a car design issue...
VBV
VBV is offline
Old 21st September 2007, 13:33   #267
Thanked: 30 Times
I raised this topic earlier and let me raise it again. What is the deal with one reverse light in SX4. I hate it for it looks plain silly for such a big car to have just one reverse light. They could have placed the stupid rear fog lamp elsewhere and given a pair of reverse lights instead of just one. What is the majority opinion here.
Old 21st September 2007, 13:49   #268
Default k
alright i go with you.. but still wanna comment that.. parking lights dont drain much of the battery as much as headlights..
Old 21st September 2007, 13:55   #269
Thanked: 20 Times
Yes Venkatesh, it is just a cost cutting, but I don't know how much they will save doing that. Looks weird when taking reverse as if one of them is not working. Them same is being followed in Logan and some other cars also.
Old 21st September 2007, 14:09   #270
Thanked: 28 Times
Folks,
I find it very strange as well.
The reverse fog lamp works "ONLY WHEN THE HEAD LIGHTS ARE ON".If it is to used only when reversing it is a criminal waste.Why will you want to ride with a fog light switched on in the rear
Any experienced DRIVER will tell you to switch off the head ligths while reversing at nights.
PRADEEP KUMAR is offline
Closed Thread
Bajaj Pulsar 200 NS : Ownership Review, 2200 Kms preetam_KORG Motorbikes 174 22nd February 2018 21:17
Maruti-Suzuki SX4 Zxi: Running Report amit Test-Drives & Initial Ownership Reports 507 14th August 2014 00:43
Maruti SX4 ZXi - EDIT: Updated for 9000 Kms sathya_nars Long-Term Ownership Reviews 112 4th May 2009 20:10
