Old 2nd September 2010, 09:18   #31
v&v
v&v's Avatar
Thanked: 1,067 Times
Getting my Baleno's front suspension and timing belt change - FNG near my office.
1. Front Shockers @ Rs 3300/- pair
2. Axle - new rubber boot and checkup.
3. Timing Belt & Bearing. - Powergrip
3. On inspection found water pump malfunctioning. Replaced @ 900/-
4. Power steering & rack lathe work.
Work got halted yesterday as the power steering pump malfunction. its not generating required pressure at idle. If not resolved, will have to hunt for new/old one ?
v&v
v&v is offline   Reply With Quote
Old 2nd September 2010, 09:56   #32
Thanked: 43 Times
Originally Posted by v&v View Post
Getting my Baleno's front suspension and timing belt change - FNG near my office....
v&v
What is your odometer reading now?
How did you decide the suspension was gone?
filcord is offline   Reply With Quote
Old 2nd September 2010, 10:27   #33
v&v
v&v's Avatar
my baleno odo is 93k.
I had slight sound from steering rack and i was getting a swinging effect from the front. At speeds excess of 80kmph some time the tyre was scraping the fender lining. Under body scrapping on speed bakers became more frequent. Got inspected at FNG , they also confirmed it time to change !
Old 4th September 2010, 22:07   #34
Thanked: 90 Times
FUEL AVERAGE
MY USUAL TREND IS FOR FILLING GAS FOR Rs 1000 AND IT GIVES ME AROUND 270 TO 290KMS
JAN 2007
HIGHWAY - DELHI - CHANDIGARH - KASUALI - SOLAN - DELHI
I THINK IT GAVE ME 18+
CHEERS
V&V
Have you fitted LPG/ CNG kit?
(Alok) is offline   Reply With Quote
Old 5th September 2010, 08:45   #35
v&v
v&v's Avatar
No Alok my Baleno doesn't have any kit. If you drive around 80 - 100 on 5th gear it will give good mileage.
OK now update on the power steering pump failure. My mechanic arranged a used pump for 6.5 k. New one is costing 18k.
Got my car back.
Update on cost.
1. PS Pump - 6.5 k
2. Steering Overhaul - 2600/-
3. Axle Repair & Boot Change - 3200/-
4. Others & Labour Charges for - 3000/-
Total Cost all including parts - 22k. Had the PS pump not failed the bill would have be under 15k.
Last edited by .anshuman : 21st December 2010 at 22:44. Reason: Back to back posts within 20mins. Please use edit button if posting again within 20 mins. Thanks
Old 25th September 2010, 08:20   #36
v&v
v&v's Avatar
Yesterday evening Tavera hit my Baleno while reversing at residence .
Need to get re painted.
Old 25th September 2010, 20:09   #37
wanderernomad's Avatar
Thanked: 777 Times
Thats bad. In the break up the parts add upto about 15K. Rest was all labour?
wanderernomad is offline   Reply With Quote
Old 17th October 2010, 10:19   #38
v&v
v&v's Avatar
Got repaired @ 4k.
Also did a minor modification for the tail light.
Old 17th October 2010, 13:40   #39
v&v
v&v's Avatar
Did the longest family trip this puja holidays. Delhi to Kerala
Route - Delhi - Udaipur - Ahmedabad - Surat - Pune - Bng - Teni - Kumili - Kotayam - Pandalam.
Total Driving time - 46 hrs
Actual Days - 4 days of driving. Only from 5-30 am to 6 pm.
Total Distance - 3250 Km
Total Fuel - 225 L
Average - 14.4
Engine Oil consumption - 400 ml.
Longest continues drive - Delhi - Baroda - 14 hrs - 1050 kms.
Best Average - 15.9 kms -> Jaipur - Udaipur
70% drive was with A/c.
NH8 and NH4 on can easily cruse - 100 - 130 km/ph
Top Speed Clocked - 165 Km/Ph - Jaipur - Kishangarh, NE1, Pune Exp highway
Was a bit apprehensive before startup. A ten year old vehicle but in top condition. All out trips were in our SUV. Now after completing the trip, now i am super confident than ever before. Not a single problem faced. Post trip checked with Maruti service center every thing is fine only a quick wash was only required.
Few pics of our tirp
Old 19th October 2010, 16:14   #40
Thanked: 90 Times
Congratulation for a successful journey & wishes for return trip.
14.4 KMPL is a satisfactory (even good) return but I am worried about engine oil consumption. Car has even not completed 1 Lace Kms and eating oil??
If you have more snaps of journey, please start a separate thread in tavelog section.
Old 20th October 2010, 11:43   #41
v&v
v&v's Avatar
Thanks alok. it was a one way trip. I left my baleno there. Regarding oil, i think its normal to consume little bit of oil when your 80% of 3500 km is driven above 120 kmph. Had the car eating oil, then i would have needed more than 1 liter for the the tirp.
There is nothing much to pen as a travelogue. I will be updating the stats on the query thread.
Old 21st December 2010, 19:39   #42
v&v
v&v's Avatar
Default Re: Baleno @ 10 years & 90,000 kms
Went for a routine service and front left bearing change at AVG, Tiruvalla. The noise has increased a lot after our recent Delhi - Kerala trip. Costed Rs 1900 + Rs 400 labour.
My dad was also saying AC too is not working. Does any body suggest a good FNG around Pandalam - CGNR - TVLLA to check the A/c
Old 3rd June 2011, 10:40   #43
v&v
v&v's Avatar
Update : at 98000 kms.
Jan 11 : Ac - Gas filling done. Compressor packing conked. Gas refilled. Compressor Serviced and packing changed. FNG has warned , they compressor is in bad condition, will not last long. Present status : Now working.
March 11 : Battery Died. Changed to AC Delco @ Rs 3100/- (Mrp 3300 - 200 for old battery). Engine oil & filter changed @ 96000/- kms costed Rs 1350/-
Apr 11 : Had a mysterious starting problem. Finally diagnosed to problem in ECU wiring harness. A separate thread was created for the same.
http://www.team-bhp.com/forum/techni...fuel-pump.html
Damages : 1500/- all inclusive. Wiring Harness costed : Rs 450/-
Jun 11 - Completed 11 years in 15 may 11. Had to go for an urgent visit to Kochi. On return journey compressor conked. Now needs a replacement. Will cost 10k+ as per FNG.
v&v is offline   (1) Thanks Reply With Quote
Old 21st March 2012, 15:07   #44
v&v
v&v's Avatar
Default re: Baleno @ 14 years & 107000 kms
Another update,
Recently my baleno had a radiator leakage problem. This leakage occurs only while driving only. Got the radiator checked and repaired by a local FNG. Again with in couple of days the same problem recurred.
Then on a detailed checkup, was finally diagnosed to conked gasket. Due to compression leakage the pressure in radiator was leading to leakage.
Changed the gasket with SGP one costed Rs 1720/- . Still under observation. Hoping that radiator leak does not recur. Otherwise radiator too needs to changed.
Old 21st March 2012, 15:27   #45
Fordmanchau's Avatar
Thanked: 291 Times
V&V, though you not updated the Odometer figure of your car, I believe it should have crossed the 100,000 mark ?
So congratulations beforehand!!
Do we get to see some fresh pics of your Baleno?
What's the current odometer reading now ? How long do you plan to keep it ?
Any updates/mods planned for the car ?
Fordmanchau is offline   Reply With Quote
Which is better - A car which has driven 1 lac kms in 4 years or 35,000 in 6 years syravi Technical Stuff 41 7th May 2016 16:21
300,000 kms in 7.5 years on my Esteem Diesel. EDIT: Sold @ 3.4 Lakh kms benzinblut Long-Term Ownership Reviews 72 8th March 2014 01:54
1.5 years & 15,000 kms in my first car, Maruti Wagon R San Phrangmung Long-Term Ownership Reviews 5 4th February 2011 19:05
Scorpio CRDe @ 70,000 kms! 5,000 of Agony & 65,000 of bliss smats Long-Term Ownership Reviews 17 8th May 2010 17:37
Baleno 50000 Km in 3 Years 2 Months - Review (Now clocked 50,000 kms) BlackPearl Long-Term Ownership Reviews 131 15th February 2009 12:01
