Old 15th January 2008, 14:13   #106
shuvd's Avatar
Originally Posted by Eddy View Post
Hmmm.. But this would have been a part of the 3 yr maintenance plan right ? BTW, what all was done for this amount ?
When I bought the car, there was no maintenance plan for the diesels.
Price breakup:
Oil Filter Kit Rs. 408.65
Engine Oil Rs. 909.35 (6.20 lt. @ 146.67/lt.) Strangely, the oil is specified as Opel Motor Oil
shuvd is offline   Reply With Quote
Old 15th January 2008, 15:12   #107
Eddy's Avatar
Thanked: 5,078 Times
6.2 L ? Thats a lot of oil.
Eddy is offline   Reply With Quote
Old 15th January 2008, 15:21   #108
shuvd's Avatar
Isn't it? Thats what I told them. Got a blank stare in return. GM A.S.S is going to be a problem. Sigh..
Old 15th January 2008, 15:22   #109
reignofchaos's Avatar
Thanked: 1,304 Times
Never heard of 6.2L oil being required for a 2L engine before. Are you sure or do you think you were taken for a ride?
Old 15th January 2008, 17:57   #110
shuvd's Avatar
Question
Uh-oh! You could be right. AFIR, the Octy takes 4.5lt.
Magnum owners - Could you guys please clarify this?
Old 15th January 2008, 18:03   #111
Yup 4-4.5ltr is the norm generally.
Old 15th January 2008, 18:04   #112
Eddy's Avatar
The amount of oil used when the filter is also changed is greater than the amount used if only the oil was replaced. So that might be the case. The difference in case of a swift vdi is about 1 L.
6.2 L still sounds a little too much.
Old 15th January 2008, 18:04   #113
Isn't the oil filter always replaced with an oil change?
Old 15th January 2008, 21:37   #114
@shuvd: IIRC it's 7L and not 6.2L. Please do check this out.
Deepu
deepug is offline   Reply With Quote
Old 15th January 2008, 21:44   #115
HotChillyPepper's Avatar
Thanked: 215 Times
I got a news that Captiva engine and Magnum engine is the same. But magnum electrically limited to 121Bhp. By remapping the ECU u get 150 flat . . . Will get more info soon
HotChillyPepper is offline   Reply With Quote
Old 15th January 2008, 21:45   #116
shuvd's Avatar
Deepug - The bill says 6.20 @ Rs. 146.67 = Rs. 909.35.
HotChillyPepper - The engines are same. But, the Captiva has a VGT and different ECU mapping.
Old 15th January 2008, 21:53   #117
Thanked: 215 Times
HotChillyPepper - The engines are same. But, the Captiva has a VGT and different ECU mapping.[/quote]
That is true... But APMK VGT will affect only your lower end (mostly at low RPMs VGT reduces the flow than normal, so constant density mixture thro out the rav band ) if I am right. So Max power would be the same right ???
Old 15th January 2008, 22:03   #118
BUSA's Avatar
Swift takes in 3.3L
My Optra 1.8 takes in 4L
Innova takes in 7L
So how come the Magnum takes in 6.2L? Imagine putting synthetic, you will need to buy a 4 liter can and 3, 1 liter cans. Thats around 4500 in oil change alone.
Old 15th January 2008, 22:42   #119
@shuvd you need to check with this with the service center . In the manual it says 7L and my service bill says 7L. How come they put only 6.2 L for you?
Deepu
Old 16th January 2008, 04:31   #120
guys i have a question for all Magnum owners.
That car was being criticized for the build quality (of course as compared to Octavia). So please comment on the following:
1. Does the door still close with a solid thunk sound? or something rattles?
2. Are the interiors still calm and quiet or the diesel engine is creating ripples inside the cabin?
3. Rattling noise inside the cabin? because something has gone loose?
4. Exterior Paint quality?
5. Howz the AC? still having a solid cooling?
tanmay_ambre is offline   Reply With Quote
Ownership report : Chevrolet Optra Magnum LT 2.0 TCDI drive_or_die Test-Drives & Initial Ownership Reports 207 9th January 2017 08:32
