Old 13th May 2009, 20:53   #406
hellstar's Avatar
Thanked: 17 Times
Originally Posted by potlaravi View Post
Anup,
Nice tactic yaar , Hope this tactic will work out for my Insurance renewal in next month .
This worked for me like a dream twice , and belive me in the process you also get to see some fun. But make sure the insurance reps are not aware of the other reps coming. and get every thing they offer that you want in writing. As for me the guys were caught totally off guard , thats what lands you a good deal.
All the best and keep us posted on your success..
hellstar is offline   Reply With Quote
Old 18th May 2009, 09:57   #407
hellstar's Avatar
Thanked: 17 Times
Here's an update guys , vehicle is now at 62500 KMS and the diesel filter warning lamp refuses to turn off even after cleaning out the tank , yesterday i was in pondicherry and the lamp started again with a eeire glow , not full intensity but still activated.
Took her straight to the Hyundai A.S.S - KUN hyundai on cuddalore Road. the pulled out the pump and found the water sensor on the diesel pump broken and diesel dripping out drop by drop when the engine ie running. Since they did not have a replacement they put the sensor back in and blocked the leakage so that i could get back to chennai , where KUN hyundai has already raised an intend to get the part and will inform me so that i can drive down and get the part installed.
Right now the warning lamp is not glowing and hence the engine is not rev limited to 3000 RPM.
Three things i noticed since i have been in chennai , is
1. No more Smoking !
2. Performance improvement perceived.
3. FE improvement.
I think i attribute both these desirable side effects to the increased density of air in chennai than at Bangalore.
Will update with pictures on the new sensor install. I have been told that the costing is around Rs 800 for the Sensor.
Old 21st July 2009, 17:38   #408
live2drive's Avatar
Thanked: 25 Times
Hellstar, any updates on this?
I also faced the same issue. Fuel filter warning light refused to go off during my Delhi-Mathura drive. Filter was cleaned thoroughly and put back. Since then the light glows once in a while for a few seconds, and goes off.
live2drive is offline   Reply With Quote
Old 16th September 2009, 15:41   #409
hellstar's Avatar
Thanked: 17 Times
Sorry pal for the very delayed reponse.
Yes the issue was rectified , there was residual water in the fuel tank , since that was cleaned out some water found its way to the fuel filter , OS it took the car to the A.S.S at pndicherry where due to incompetent workmanship the guy managed break the water sensor in the fuel filter.
Cost of the fuel filter water sensor is Rs 800 , this was replaced after a second round of evacuating the fuel system , by taking everything out , blow drying it and then putting it back.
Old 22nd September 2009, 12:21   #410
Maverick_x1's Avatar
One has to be really careful on where the car is getting serviced these days.
OT question though, does Verna puff off smoke during sudden acceleration?
I only noticed that yesterday when pulling away from traffic. Otherwise the car is being driven sedatley and rarely any smoke is seen.
Maverick_x1 is offline   Reply With Quote
Old 23rd September 2009, 10:35   #411
live2drive's Avatar
Thanked: 25 Times
What did the whole procedure of cleaning the tank and the filter cost you? I hope the water sensor in my case is all right.
Yes, it does smoke heavily under hard acceleration.
To reduce the smoke levels, rip the car more often and keep the air filter clean.
Old 23rd September 2009, 12:51   #412
hellstar's Avatar
Thanked: 17 Times
Smoke during hard acceleration is normal in TC diesel engines, this should stop once the turbo starts spooling.
Approx 1.5 k
I like this
Old 23rd September 2009, 13:59   #413
ph03n!x's Avatar
Thanked: 120 Times
Isn't the smoke a byproduct of Premium Diesels? My car never smokes (or I haven't noticed it yet)- and I have never filled in anything but regular Diesels, Shell for most part...
ph03n!x is offline   Reply With Quote
Old 23rd September 2009, 17:36   #414
hellstar's Avatar
Thanked: 17 Times
thats good , and also remember that cars would smoke lesser in Chennai than in Bangalore due to the increased density of air. There are several situation where diesel cars would emit smoke , hard acceleration being the most common one.
Old 27th September 2009, 17:58   #415
Thumbs up
LOL!! good suggestion. had the Air filter replaced as a part of the third service last week. Vehicle is more responsive now
Any idea where we can find the Pete's kit in Bangy?
Old 27th September 2009, 18:05   #416
ph03n!x's Avatar
Thanked: 120 Times
Check out this link- Pete's Automotive Products Pvt Limited
Old 29th September 2009, 10:31   #417
hellstar's Avatar
Thanked: 17 Times
thats correct , but i would still prefer that you give a call to turboindia / peter and have a chat with him before you install or buy .
Old 20th September 2015, 07:50   #418
bijubalan's Avatar
Thanked: 54 Times
Default Re: Hyundai Verna CRDI VGT - Updated at 35k-km,40k-km, 55k-km,60k-km, Plus A Minor Crash
I recently happened to see a particular Red Verna CRDI at Yeshwantpur , Hyundai A.S.S with its reflectors badly damaged due to an improperly installed 130W/110W, thats when i really decided to change the ceramic holders and wiring kits together with the relays.
Hi Hellstar & Others,
Sorry for bumping this old thread. I am having a similar problem with the headlamps on my Verna. The reflector is melt and the small shade inside is discoloured. Previous owner had upgraded the bulbs to 90/100. This had additional relays and wiring added. I am not sure whether holders were updated to ceramic. But melting is happening at the top upper edges of the reflector. There is a slight discoloration of the lens as well. These problems are more on the right lamp which was having a philips 90/100 but less on the left one which was having Osram 90/100.
To be safe I changed back the bulbs to 55/60 rating after buying the car. Can you guys please help me identify the exact reason for this problem.
Thanks in advance!
Biju
Hyundai Verna CRDI VGT - Updated at 35k-km,40k-km, 55k-km,60k-km, Plus A Minor Crash-rightlampfrontview.jpg
Hyundai Verna CRDI VGT - Updated at 35k-km,40k-km, 55k-km,60k-km, Plus A Minor Crash-rightlamptopview.jpg
Hyundai Verna CRDI VGT - Updated at 35k-km,40k-km, 55k-km,60k-km, Plus A Minor Crash-leftlampfrontview.jpg
Hyundai Verna CRDI VGT - Updated at 35k-km,40k-km, 55k-km,60k-km, Plus A Minor Crash-leftlamptopview.jpg
bijubalan is offline   Reply With Quote
Old 20th September 2015, 23:10   #419
hellstar's Avatar
Thanked: 17 Times
Thanks in advance!
Biju
Wow , that one hell of a bump !!!
Ok , from the images , i see that the damage is already done , no amount of reworking can correct this. Couple of things could cause this .
While i was running 130/110 W bulbs i never used to keep the hibeam on in stop and go traffic. The 130 W high beam was always reserved for the deserving and the regular highway and nandi hill runs. In city traffic there is no airflow cooling the headlights from the additional heat generated by the upgraded bulbs. The verna engine also tends to get headed pretty soon. It is probable that the previous owner did a lot of miles in stop and go traffic with the high beams on causing this extreme damage. In my seven years with this vehicle i have never had the reflector melt , i only had some fading of the glasses, that's after about 6-7 years of very rough use.
Upgrading to ceramic holders will only save the holders , it will not affect the reflector.
I would recommend that you change the headlight set , this would set you back by about Rs 7K at the HYUNDAI A.S.S.
Please please buy bulbs only from trusted sources , there are a load of fakes in the market , which could be one of the reasons for the extreme heating.
The verna needs a headlight upgrade if you are doing highway runs in the night so , if the previous owner has installed the relay and wiring kit do get it checked and retain if its from a good brand and if it is in good condition.
if you need to talk do drop me a PM and we can take it from there ...
Old 22nd September 2015, 16:43   #420
bijubalan's Avatar
Thanked: 54 Times
I think you are making lot of sense. I have also observed that he had adjusted the beam such that high beam is very low (screws inside the hood). Highly probable that he did not want to switch back and forth and always kept in high beam. I guess he might have also used some after market headlamp assembly if he had replaced which could not take the beating.
Is this price for one set or both? I think I will retain the left one and change the right one. What do you think?
Please please buy bulbs only from trusted sources , there are a load of fakes in the market , which could be one of the reasons for the extreme heating. The verna needs a headlight upgrade if you are doing highway runs in the night so , if the previous owner has installed the relay and wiring kit do get it checked and retain if its from a good brand and if it is in good condition.
Immediately after buying car I bought a pair of Osram Nightbreaker unlimited . The brightness and beam strength is better but could not judge correctly due to the unconventional beam setup previous owner maintained. Need to update that too and check again.
Will all these things in anyways affect the beam adjustment motor. Somehow I feel the motion is minimal or nill.
Thank you! I will do that.
Hyundai Verna VGT: 50000 kms in 5 years. Pleasant experience at Trident Hyundai SantoshPV Long-Term Ownership Reviews 1 25th June 2013 14:50
Hyundai Verna CRDi VGT: Long Term Ownership Report live2drive Long-Term Ownership Reviews 49 12th April 2011 22:16
Just another love affair: Hyundai Verna (SX CRDI VGT) Lancer.ized Test-Drives & Initial Ownership Reports 66 24th September 2010 04:50
Hyundai Verna(VGT) test drive(torture drive) tsk1979 Test-Drives & Initial Ownership Reports 67 3rd October 2008 20:20
