Go Back   Team-BHP > Indian Cars > Team-BHP Reviews > Long-Term Ownership Reviews
Thread Tools
Old 2nd December 2007, 19:53   #61 (permalink)
nitrous's Avatar
It is an unhealthy practice.
Why did they not change the oil filter in the previous service?
__________________
Maruti - Everyone comes home with rattles!
Old 2nd December 2007, 20:50   #62 (permalink)
Eddy's Avatar
It is not supposed to be done as per maintenance schedule.
__________________
Car is no longer a luxury; parking space is.
Eddy is offline   Reply With Quote
Old 3rd December 2007, 11:06   #63 (permalink)
Eddy's Avatar
Originally Posted by Eddy View Post
Hey Guys,
4800 km done and almost time for the second service. Planning to get the oil and filter change.
Need advice on the foll:
-- Changed oil in the first service. Used Mobil delvac super 1300 15 w 40. Is this good or do you recommend some other brand ?
-- No filters were changed in the first service, so should I press them for a change this time ?
-- I believe that wheel balancing is also a part of the second service.
Also need some inputs on System D ? What is it and how is it useful ? Is it advisable to use it this early ( 5k kms )
__________________
Old 3rd December 2007, 14:52   #64 (permalink)
nitrous's Avatar
U mean they didnt change oil too in the first service?
__________________
Old 3rd December 2007, 15:15   #65 (permalink)
Eddy's Avatar
They changed the oil but not the filter. On hindsight, I do find it a little strange but I didn't contest the decision then.
Just want to know the correct thing this time.
__________________
Old 4th December 2007, 14:42   #66 (permalink)
DieselFan's Avatar
Recommendation from reputed manufacturer of a car can't be unhealthy practice. Now a days engines are manufactured with good tolerance levels. VW and Audi recommend first oil change at 10000 Miles.
The engine oil used on Swift D is of high quality and very durable. It can be used easily for 10000 km without any worries. There is no need to change the oil in the second service.
I have started using System D just last couple of refills (after 10000 KM). Just wanted to be safe. I have not found much improvements in the performance of the car. It may be too early to notice. Maybe after using it for 5 tank fills we will see some improvements. Will keep posted on the same.
__________________
If you have not failed you have not tried enough.
Swift Diesel VDI - Feb '07 onwards
Santro LS- Mar '01-Feb '07(59000 KM) Sold.
DieselFan is offline   Reply With Quote
Old 4th December 2007, 14:46   #67 (permalink)
Eddy's Avatar
What is System D and what is it supposed to do ?
__________________
Old 5th December 2007, 15:43   #68 (permalink)
nikunj_cal's Avatar
System D is supposed to smoothen your ride , increase pickup as well as mileage , supposed to be put in when u fill diesel ( normal diesel only). There is a measuring system for the same , don't remember it at the moment .
__________________
RIP, RIP, RIP AND AWAY.................
nikunj_cal is offline   Reply With Quote
Old 5th December 2007, 15:48   #69 (permalink)
nitrous's Avatar
A 165 size hard-compound tyre on a 1.1 ton,190Nm car is an unhealthy practice too.
But, it IS recommended by the same cheapskate manufacturer.
Im not going to argue,bro.But, never have I come across any manufacturer skimping on an oil filter change. If its practised elsewhere, Ill be convinced.
Peace
__________________
Old 5th December 2007, 17:34   #70 (permalink)
Team-BHP Moderator
Jaggu's Avatar
yeah the maruti manual says no need to replace filter. maybe coz they are long duration green thingie
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 5th December 2007, 17:42   #71 (permalink)
Eddy's Avatar
Does it actually work or is it a gimmick ? How often should it be used ?
__________________
Old 5th December 2007, 18:18   #72 (permalink)
Team-BHP Moderator
tsk1979's Avatar
It actually works, though by how much is debatable. Use it with normal diesel.
I used to use it, and sometimes still do it. Good way of cleaning injectors
__________________
Old 5th December 2007, 18:19   #73 (permalink)
Team-BHP Moderator
Jaggu's Avatar
yeah i guess once in a while tanking up along with system d can help to some extent, more info IFTEX OIL & CHEMICALS LTD.
__________________
Old 5th December 2007, 18:44   #74 (permalink)
condor's Avatar
nikunj cal : There is a measuring system for the same , don't remember it at the moment .
The measuring system is built into the bottle. In the neck of the bottle are markings for the quantity (5ml & 10ml). You hold the bottle upright, loosen the cap enough to allow air movement through the cap (dont remove the cap). Then squeeze the bottle. The liquid will settle in the neck of the bottle. You squeeze the required quantity and pour it into the tank.
__________________
Life is Analog. Digital is an approximation.
Old 6th December 2007, 14:41   #75 (permalink)
DieselFan's Avatar
Peace
Sure it is not a best practice to have 165 size tyre on Swift D in highways if you are travelling at 120 to 140 kmph but in India the assumption is to do lot of city driving @ 60-80 kmph. Even Honda gives you undersized tyres. Can we say then honda is a Cheapskate manufacturer?
Anyway coming back to the point on Engine oil filter. I have seen the filter with my own eyes when it was changed at 10000 km and believe me it is rugged. It wasn't deformed at all. surprisingly there was not much of muck in it (now-a-days the CRDI or DDIS engines are really precision machined). I think both oil and filter used in swift D are of excellent quality (I have seen manufacturers specification of Mobil Delvac 1300. It is made for heavy duty trucks and some folks have used this oil for 30 K KMs).
__________________
Thread Tools
Swift VDi ownership: A Running report GeekSrik Long-Term Ownership Reviews 794 16th July 2008 15:51
Logan 1.4 1500km report EDIT: now 15,000 kms ashutoshb Long-Term Ownership Reviews 139 8th June 2008 00:07
Verna CRDI (ABS) 30,000 Kms report on problems sag_kv Long-Term Ownership Reviews 23 28th February 2008 07:28
Peted Swift VDi ABS 10000kms Review. EDIT : Updated to 20,000 kms BUSA Long-Term Ownership Reviews 39 21st February 2008 17:47
Swift Vxi & Swift Vdi - Ownership/Service/Running costs dcetech Hatchbacks 1 16th August 2007 14:21
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
