Go Back   Team-BHP > Indian Cars > Team-BHP Reviews > Long-Term Ownership Reviews
Long-Term Ownership Reviews Ownership reports, of Indian cars, spanning over several years and thousands of kms
Thread Tools
Old 30th September 2007, 08:14   #1 (permalink)
afg
Default Optra-second hand-initial experience
Hi
I bought a second hand 2004 Optra 1.6 base version (30,000 kms usage) about a couple of weeks ago from a friend and here is my experience with the car so far. My earlier car was a Palio 1.2L.
I have driven about 250 kms so far - mostly to Lonavala and back. Till now, the car has really impressed me. Though it is not a high performance car, it is definitely easier to drive compared to the Palio. I do not have to constantly downshift gears at low speeds or when climbing. It easily picks up from 30kmph in the 4th gear or from 20 kmph when in the 3rd gear )(unlike the Palio which was a pain). So this makes city driving a lot easier. On the highway, I limited the speed to a max of 110kmph and it was purring. However, I did notice that at 100kmph, the RPM was 3,000. For the Optra 1.6 owners out there, is this normal for the car? Should'nt it have been around 2,500? At 80-90 it was at around 2,500RPM. I have yet to take the car for servicing, but is it possible to get the RPM down with the servicing? I generally change gears at around 2,000 RPM.
Anyway, the engine is quite except on starting when there is a growl before settling down (this is contrary to what I experienced when I test drove the car earlier before delivery, when I thought the engine was noisy, so this is good). There is hardly any intrusion of noise in the cabin when the windows are rolled up. However, when the windows are rolled down, tyre noise was perceptible.
Another problem I had was the car pulling to the left. The earlier owner had done the wheel alignment just before handing the car to me, and at that time the car was tracking fine. But on my trip to Lonavala, the car just wanted to go to the left. So on my return from Lonavala, I got the tyres checked and according to the tyre dealer, the tyre treads had worn off. I got the Pirelli P6000 tyres fitted (I came to know later that these tyres do not have a great review) and the car now seems to be moving straight but I have not yet done a proper test drive yet. I did notice that one of the wheel rims was dented slightly which was rectified by the dealer on putting the new tyres. Does this cause air to leak with tubeless tyres and is therefore causing the car to move to the left?
Apart from the above problem, the car seems to be fine. Ride quality is great with potholes being despatched without any problems to the occupants. The car is extremely well built and comfortable with no rattles whatsoever. There is ample space for the passengers and in the boot. Handling did seem to be a problem, though, on sharp turns (with the old tyres) when I felt the grip was not up to the mark but this could be the tyre problem.
I have not checked the fuel efficiency yet but a little less than 1/2 the tank was used up in these 250 kms.
I am taking the car for servicing on Oct 10th at National Garage and am planning to do an engine decarb, oil change etc as suggested by BUSA.
I have installed parking sensors and I must say this is a boon when parking.
Adil Gotla
afg is offline   Reply With Quote
Old 30th September 2007, 13:43   #2 (permalink)
beanstalk_230's Avatar
congrats adil
yeah i agree to you optra is not a driver's car but its very easy to handle in the city, the gear ratio really helps in easing out the pressure on the driver and one does not have to downshift regularly. I think a servicing would help in the higher rpm case you mentioned. just try it pulling to around 150 and you would start loving the car all over again (i have driven the palio deisel at 140, you'd feel the diff ) , the car is just so stable at those speeds..
about the car pulling to the left is a bit strange because both of my chevvy's love moving forward in a dead straight line and it really helps on the highways especially at high speeds. i don't think it would give you a FE of more than 12 (an okay FE for 1.6, 1.8 gives around 10-11). BTW for the FE i am personally considering the CNG module provided by GM for the optra (and the warranty of the car would also be intact) and it would be a boon for this sweet car
noise reduction (deadening) is one the best in optra no doubt
enjoy your car
cheers
__________________
Gaurav
beanstalk_230 is offline   Reply With Quote
Old 30th September 2007, 13:53   #3 (permalink)
skandyhere's Avatar
unless it happens to be merely an instrumentation error, there's no way a service can change the rpm for a certain speed - that being a function of only the gear ratios used in the transmission.
__________________
2-door coupe.RWD.Leather upholstery.Blaupunkt.Remote AirCon.Michelin tubeless,asymmetric tread,low friction tyres.ABS...The REVAi.
skandyhere is offline   Reply With Quote
Old 30th September 2007, 13:54   #4 (permalink)
BUSA's Avatar
hey afg, nice review.
About the car moving left, its a issue about alignment, jsut get it 4 wheel aligned properly and the issue will surely be resolved. Had faced the left drift issue and was very difficult sorting it out since Optra has AWIS, it needs 4 wheel alignment and very few workshops get it right.
__________________
Got Bhp? Team-Bhp.com
Thread Tools
Initial experience: Tata Indica Vista TDI Veer Test-Drives & Initial Ownership Reports 6 15th September 2009 13:30
My hyundai I20 initial experience puneetiitr Test-Drives & Initial Ownership Reports 20 3rd September 2009 14:04
Fiesta tdci zxi-Initial experience peugeot96 Test-Drives & Initial Ownership Reports 15 28th June 2009 15:41
The Mazda 3 comes home (Initial Ownership Experience) Saurabh M Test-Drives & Initial Ownership Reports 37 22nd April 2009 13:32
Chevrolet Optra 1.6 - Initial week veipe Test-Drives & Initial Ownership Reports 15 11th August 2004 00:10
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
