| | Thread Tools |
| | #31 (permalink) |
| Team-BHP Moderator ![]() | Simple Indigo RPM maxes out at 4500 or so. It has the same top speed as wagon R, so it will be achieved at lower RPM Why does it max out at 4500? Coz its a diesel and the max torque is from 1800-3200RPM, so gearing is designed for that. If you had a car which had lots of power but ony 3000RPM max you would see the same speeds at even lower RPM
__________________ My DCMAG Portfolio! |
| | #32 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
Now the Wagon R has to revv it's engine to 6800rpm in 1st and 2nd to hit those speeds i mentioned. Since the Wagon has a relatively higher revving engine, then gear ratios need to be short, to compensate for the lack of power and torque at low rpms. Now, the indica diesel "i think" redlines at 4500 rpm. Which means that max power and torque are produced below that engine speed. If i were to use the same ratios as that of the Wagon R in your Indica, you would have spent all your time concentrating on the gear shifts bcoz, the moment you redline in 1st and shift into 2nd, your engine speed would have already reached close to it's redline. Ok, i'll make it simpler, now imagine i'm driving a Wagon R with a rev limit of 4500 rpm. So, the max speed i'd be able to hit would be : 30.1 kmph in 1st 54.38kmph in 2nd 80.4kmph in 3rd 112kmph in 4th 136kmph in 5th Though these gear ratios would make the Wagon R peppy, whats actually happening is that your cruising rpm will suffer a lot, you'd be doing high rpms in 5th gear at 80-100kmph which will hamper your highway mileage, you won't be able to stay in one gear for long leading to a very irritating drive and i'f you've noticed, the top speed of the car has been reduced to 136kmph, where as the present Wagon R manages 145-150kmph. In such cases you have 2 choices, you either recalculate your gear and final drive ratios or, (if you want a peppy car) add another 2 gears such that your car manages it's top speed of 145kmph without sacrificing the peppyness of the car. If your Indica was to have 6-7 gears, it would have revved much faster to it's redline but, that would have reduced your max speed in each gear and your FE would have reduced. So, what TATA has done is that they've calculated the ratios such that even though the car doesn't feel all that peppy, it'll still hit it's top speed within those 5 gears and due to the tall nature of the ratios, you can cruise at 100kmph in 5th at a low engine rpm which not only makes the car very fuel efficient but, also increases engine life. Shan2nu
__________________ VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE | |
| | #33 (permalink) |
| BHPian Join Date: Mar 2005 Location: Mumbai
| stratos..... now that you have clocked some significant mileage on your indigo (which looks very well maintained & shiny by the way) can you tell us about 1. any increase in noise levels inside the cabin ;will appreciate that information pal... apart from that have you been exposed to any new likes / dislikes or good features/ irritants on the Indigo, now that you have been driving it for quite a while ? thanks, hell_rider |
| | #34 (permalink) | |
Things I have really liked about the car: 1: The seating position is very good and provides excellent all round view. 2: The steering wheel is very precise and light. 3: Overall ergonomics are very good. 4: A very good A/C system. 5: Lastly, Consistent Fuel Efficiency, space and comfort. In the its price, the Indigo is the biggest thing you can have.
__________________ To Izh thi Mex | |
| | #35 (permalink) | |
| Super-Admin | Quote:
__________________ GTO Self-imposed limits are the only type that exist. Break them....then, make it a habit. Exceed.
| | #36 (permalink) |
| thanks stratos, precisely the information i wanted. opinion of a owner of a indigo he has run for a while. but i think i have a different take on the all -round view thing. I think the design of the dash kind of hampers the visibility. will take another test drive though. i need to have another go at the indigo. ciao, hell_rider |
| Thread Tools | |
Similar Threads | ||||
| Details of tata indica /indigo diesel ECU | Vin Diesel | Technical Stuff | 10 | 20th June 2008 22:59 |
| INDIGO@170km/h(diesel) | karan561 | Street Experiences | 43 | 5th November 2007 20:13 |
| Diesel leakage in Indigo TDI | raptor3624 | Technical Stuff | 2 | 5th October 2006 15:55 |
| Tata Indigo LWB and Tata 1 lakh car | tsk1979 | The Indian Car Scene!! | 32 | 20th June 2006 18:10 |
| Indigo Petrol or Diesel | NewCar | Sedans | 6 | 6th November 2005 02:30 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425
